Navindran Neutral Newbie March 22, 2013 Share March 22, 2013 My Friend's Father was in the carpark and same thing had happened to him. The b#$tard driver actually claim my friends father is the one who hit his back. ↡ Advertisement Link to post Share on other sites More sharing options...
Vulcann 6th Gear March 22, 2013 Author Share March 22, 2013 I dont know which one is mine.. it is for my car cam.. I think it was a SD card? Go check before you buy. Likely to be microSD. Link to post Share on other sites More sharing options...
Vulcann 6th Gear March 22, 2013 Author Share March 22, 2013 My Friend's Father was in the carpark and same thing had happened to him. The b#$tard driver actually claim my friends father is the one who hit his back. Got car cam recording the whole process? If yes don't need to talk so much to the fella just submit the footage let insurance settle. But if not then its your friend father's word against the other party and how well you describe/draw liao... Link to post Share on other sites More sharing options...
Dscheng 3rd Gear March 22, 2013 Share March 22, 2013 Mine 32GB also not enough for a day recording. Waiting for my 64GB card and it is not cheap ! Link to post Share on other sites More sharing options...
Axela525 4th Gear March 22, 2013 Share March 22, 2013 Mine 32GB also not enough for a day recording. Waiting for my 64GB card and it is not cheap ! Make sure got support.... Link to post Share on other sites More sharing options...
Simplecar 4th Gear March 22, 2013 Share March 22, 2013 Mine 32GB also not enough for a day recording. Waiting for my 64GB card and it is not cheap ! it will depend on how long you are away from your vehicle. I would need one that can do at least 12 hours recording at Full HD resolution at lowest compression ratio (best possible for my in car cam). So far my 16GB SDHC can do about 7 hours of recording (IIRC). That means I should be able to do 14 hours with a 32GB. YYMV Link to post Share on other sites More sharing options...
Vulcann 6th Gear March 22, 2013 Author Share March 22, 2013 it will depend on how long you are away from your vehicle. I would need one that can do at least 12 hours recording at Full HD resolution at lowest compression ratio (best possible for my in car cam). So far my 16GB SDHC can do about 7 hours of recording (IIRC). That means I should be able to do 14 hours with a 32GB. YYMV Make sure you check your cam's specs before getting anything more than 32GB which seems to be the max for most cams. Link to post Share on other sites More sharing options...
Adrianli Hypersonic March 22, 2013 Share March 22, 2013 now if 32GB memory card roughly how much boss? Me no boss. Me lowly paid worker. From the recent IT Fair 2013 : Link to post Share on other sites More sharing options...
VellfireS 4th Gear March 22, 2013 Share March 22, 2013 Me no boss. Me lowly paid worker. From the recent IT Fair 2013 : no need so humble boss.. eh.. kum sia.. Link to post Share on other sites More sharing options...
VellfireS 4th Gear March 22, 2013 Share March 22, 2013 Go check before you buy. Likely to be microSD. Roger,.. thanks many many.. Link to post Share on other sites More sharing options...
Dscheng 3rd Gear March 22, 2013 Share March 22, 2013 it will depend on how long you are away from your vehicle. I would need one that can do at least 12 hours recording at Full HD resolution at lowest compression ratio (best possible for my in car cam). So far my 16GB SDHC can do about 7 hours of recording (IIRC). That means I should be able to do 14 hours with a 32GB. YYMV My dvr custom firmware recording at 12mbps. Each file per min about 80-100mb. Damn big but the video quality is good. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear March 22, 2013 Share March 22, 2013 Even cheapo China brands bought from Gmarket also can record after the car has stopped. Usually the term they use is "Surveillance Mode". To conserve battery, some can put it to sensor recording...ie when there is movement infront of the cam, then it will start to record. I am using this cam http://list.qoo10.sg/item/RODIS-NEW-ARRIVA...-FULL/407008373 But mine is the dual lens...aka one for the front and one to shoot behind. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear March 22, 2013 Share March 22, 2013 She drove w/o turning on her headlights Why I also dunno...usually I will turn on my lights even in the day if light is poor...night time no need to say..sure turn it on one. Initially I tot driver might have misjudge cos low light hence crash into the car...but after viewing...I think its the classic case of stepping on the accelerator than the brakes....and worst is...why she almost bang on it again seconds later... Link to post Share on other sites More sharing options...
Mockngbrd Supersonic March 22, 2013 Share March 22, 2013 Even cheapo China brands bought from Gmarket also can record after the car has stopped. Usually the term they use is "Surveillance Mode". To conserve battery, some can put it to sensor recording...ie when there is movement infront of the cam, then it will start to record. I am using this cam http://list.qoo10.sg/item/RODIS-NEW-ARRIVA...-FULL/407008373 But mine is the dual lens...aka one for the front and one to shoot behind. do u wire it to car batt? or does it charge up using the usb? Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 22, 2013 Share March 22, 2013 do u wire it to car batt? or does it charge up using the usb? i scared of hooking up to car battery cos my alternator is weak. at the end of day, dont know how much charging the alternator does to battery nia. Link to post Share on other sites More sharing options...
Vulcann 6th Gear March 22, 2013 Author Share March 22, 2013 ADRIAN, INCOME OPPORTUNITY!!!! [laugh] Seems quite a few folks still don't know much about dashcams so why not you conduct lessons to earn some $$$? If you need assistants, yours truly is available for a very, very modest nominal fee.... Link to post Share on other sites More sharing options...
Adrianli Hypersonic March 22, 2013 Share March 22, 2013 ADRIAN, INCOME OPPORTUNITY!!!! [laugh] Seems quite a few folks still don't know much about dashcams so why not you conduct lessons to earn some $$$? If you need assistants, yours truly is available for a very, very modest nominal fee.... No need lah. Me also busy wif other stuff lately. Only when I see questions here n there, I drop by to answer. Those who PM me, knows I will definately reply to them. Link to post Share on other sites More sharing options...
Newdrive 1st Gear March 22, 2013 Share March 22, 2013 (edited) another female driver looks like OPC car Edited March 22, 2013 by Newdrive ↡ Advertisement Link to post Share on other sites More sharing options...
Reckless Cyclist
Reckless Cyclist
Online purchase for car parts
