ChickenMob 6th Gear April 15, 2014 Share April 15, 2014 My place to WS is about 6 km or so, so i will take a chance to drive it there. The coolant residue after 1 day (didn't drive today) seems to be something i saw before on engine bay.. wonder if that actually happened before. will drop by WS anyway. thanks. just monitor it, once overheat the gaskets will crack. hope its just a loose cap should be ok in awhile. ↡ Advertisement Link to post Share on other sites More sharing options...
Vyeron 4th Gear April 16, 2014 Share April 16, 2014 Today, drove about 1 km and radi leak like fountain . Lucky WS close enough and get radi replaced. Quoted about 650, but eventually i got my own radi part and total damage was like 450.. 650 for replacing standard radiator considered market rate? or tiok chop? Link to post Share on other sites More sharing options...
Pms 3rd Gear April 16, 2014 Share April 16, 2014 (edited) Mine 07 GD, replaced with a oem. Koyorad radiator $260 Labour $60(Got a couple of things changed so not exact labour cost) Coolant $35(Can bring your own coolant) So roughly it will be around $300. Edited April 16, 2014 by Pms Link to post Share on other sites More sharing options...
Vyeron 4th Gear April 16, 2014 Share April 16, 2014 Mine 07 GD, replaced with a oem. Koyorad radiator $260 Labour $60(Got a couple of things changed so not exact labour cost) Coolant $35(Can bring your own coolant) So roughly it will be around $300. only half from the quoted price. i will need to source around for WS then..thanks for sharing. Link to post Share on other sites More sharing options...
StefanK Supercharged May 6, 2014 Share May 6, 2014 Lai liao lai liao! Can get to see it tomorrow before I fly off! https://sg.news.yahoo.com/subaru-wrx-set-singapore-bow-163803996.html Same price as BRZ!!! only half from the quoted price. i will need to source around for WS then..thanks for sharing. Your $650 is original? I paid $660 for original including labour plus some minor replacement parts. Link to post Share on other sites More sharing options...
ChickenMob 6th Gear May 6, 2014 Share May 6, 2014 Lai liao lai liao! Can get to see it tomorrow before I fly off! https://sg.news.yahoo.com/subaru-wrx-set-singapore-bow-163803996.html Same price as BRZ!!! Your $650 is original? I paid $660 for original including labour plus some minor replacement parts. they called It evorex....... Link to post Share on other sites More sharing options...
StefanK Supercharged May 6, 2014 Share May 6, 2014 they called It evorex....... 2 for the price of 1. ok lah... Link to post Share on other sites More sharing options...
ChickenMob 6th Gear May 6, 2014 Share May 6, 2014 2 for the price of 1. ok lah... lol but the repair also 1 x 2 leh.... Link to post Share on other sites More sharing options...
Ake109 6th Gear May 7, 2014 Share May 7, 2014 I think Subaru quite jialat leh. One generation after the Evo X, the current STi is still behind in terms of the tech (compared to the X) Link to post Share on other sites More sharing options...
Vyeron 4th Gear May 18, 2014 Share May 18, 2014 Your $650 is original? I paid $660 for original including labour plus some minor replacement parts. Paid total about 450 bringing own parts fm stockist, yes its original. Link to post Share on other sites More sharing options...
AhWeePwn Neutral Newbie May 20, 2014 Share May 20, 2014 nice If 08 NA model, it should not have this.My knowledge not very good, but I usually see this with turbo charged cars. Maybe I'm wrong.If is 08 model, the setup should be similar to Peter's image, Legacy air intake towards the front. No wires.This should be the Impreza 07 NA engine bay layout:This is 08 Impreza NA engine bay layout: Link to post Share on other sites More sharing options...
Pms 3rd Gear May 25, 2014 Share May 25, 2014 Anyone got end of life stock/spoilt GD chassis/Hawkeye 5x100 shocks to donate? Link to post Share on other sites More sharing options...
320x240 Neutral Newbie June 12, 2014 Share June 12, 2014 Is there any way to enable chirping/horning when you lock/unlock the door on a 2010 Impreza? My dad went to install an after market central lock what chirps when you lock/unlock as he was having trouble finding where the car was parked without it. Link to post Share on other sites More sharing options...
stream_cool Neutral Newbie June 23, 2014 Share June 23, 2014 Any Body having the said issue as mentioned below for 2014 Forester XT: From China Suburu forum 2013/06月牽的XTP車主,至2014/04月更新082版ECU之前,大腳加速瞬間產生的短暫急促"答答聲"伴隨動力喪失的情況,約莫出現了三次,從第一次出現後就不太敢大腳加速了(自我安慰當做是國產小馬力車在開就好 T_T)。I personally facing such issue when using 'I' mode when travelling along highway of speed 60~70km/h, the "Tak,Tak" sound start appear when i accelerate hard for overtaking and the car will start to pulled back like engine lag problem and then move on again Link to post Share on other sites More sharing options...
Watwheels Supersonic June 23, 2014 Share June 23, 2014 Any Body having the said issue as mentioned below for 2014 Forester XT: From China Suburu forum 2013/06月牽的XTP車主,至2014/04月更新082版ECU之前, 大腳加速瞬間產生的短暫急促"答答聲"伴隨動力喪失的情況,約莫出現了三次, 從第一次出現後就不太敢大腳加速了(自我安慰當做是國產小馬力車在開就好 T_T)。 I personally facing such issue when using 'I' mode when travelling along highway of speed 60~70km/h, the "Tak,Tak" sound start appear when i accelerate hard for overtaking and the car will start to pulled back like engine lag problem and then move on again Most likely it's the wastegate opening and closing to regulate the amount of exhaust gas passing thru the turbo and limiting the compression boost. The Intelligent mode is the supposedly the eco mode, right? Better to go watch in Youtube to see how a turbo wastegate works. What you heard is probably the wastegate controlled flap that opens and closes to regulate the exhaust gas. Link to post Share on other sites More sharing options...
Blueblueman 4th Gear June 24, 2014 Share June 24, 2014 Hi bros, Anyone got a used set of ts 1.6 06/07 model suspension to clear Or knows where to get a set as mine gng chui Liao. Original should be able to get from Ubi but wonder any after mkt brands for Subaru And difference in price n handling TIA Link to post Share on other sites More sharing options...
ChickenMob 6th Gear June 24, 2014 Share June 24, 2014 Hi bros, Anyone got a used set of ts 1.6 06/07 model suspension to clear Or knows where to get a set as mine gng chui Liao. Original should be able to get from Ubi but wonder any after mkt brands for Subaru And difference in price n handling TIA U can check in the Subaru forum, many guys are selling their aftermarket suspension, WRX certain models should fit also. Link to post Share on other sites More sharing options...
stream_cool Neutral Newbie June 24, 2014 Share June 24, 2014 Hi Watwheels, Thank for the info and hope that the problems is wat you mentioned the wastegate issue. Cos reading the Subaru forum from China ,the said defect is quite happening there,and quite a number of drivers have commented the same problem and sent in to agent to repair ,like re-tune the ECU ( From 081 version to 082 ) etc Quite concern of this issue http://www.mobile01.com/topicdetail.php?f=336&t=3946920&last=50774658 ↡ Advertisement Link to post Share on other sites More sharing options...
W212 owners, please check-in
Mercedes Owners Thread
New Subaru XV
New Subaru XV
2015 Forester 2.0
2015 Forester 2.0
Advice on exhaust.
Advice on exhaust.
Nissan QashQai 2014 Part 2
