Beehive3783 Turbocharged March 11, 2013 Share March 11, 2013 There is still a physical connect between the rack and the steering wheel, just that the electric assist is so strong that it numbs the feeling. Of course I know there is still a mechanical connection What I'm saying is, the feel of electric power steering can be tweaked electronically, something which cannot be done for mechanical power steering. ↡ Advertisement Link to post Share on other sites More sharing options...
Rustyz 5th Gear March 11, 2013 Share March 11, 2013 Teana quite heavy steering. Wait till try a mit colt. Link to post Share on other sites More sharing options...
Silklee 3rd Gear March 11, 2013 Author Share March 11, 2013 So what type of a steering mechanism is the 2008 1.8l civic using? Link to post Share on other sites More sharing options...
VellfireS 4th Gear March 11, 2013 Share March 11, 2013 Have you driven the Subaru XV before? Steering so light it has absolutely no feel. i can safely say Avante also similar.. Link to post Share on other sites More sharing options...
VellfireS 4th Gear March 11, 2013 Share March 11, 2013 E90 is heavy, almost feel like no power steering at parking speed. But the feel and feedback when going through fast corner is solid hahaha.. true.. well.. German Engineering bro.. Link to post Share on other sites More sharing options...
VellfireS 4th Gear March 11, 2013 Share March 11, 2013 That time i compare with my A8, my friend 520i freakin heavy ah HAHA... BRO.. you compare with 7 nvm.. with 5 cannot compare le.. coz your A8 steering is quite light right? Link to post Share on other sites More sharing options...
Gohsj89 1st Gear March 11, 2013 Share March 11, 2013 stream and civic 1.8 have very responsive steering and they are based on hydraulic steering system Link to post Share on other sites More sharing options...
Silklee 3rd Gear March 11, 2013 Author Share March 11, 2013 stream and civic 1.8 have very responsive steering and they are based on hydraulic steering system Sorry. I probably should have asked this at one go. So, what steering mechanism does the latest Camry use? The feel seems somewhere in between the civic and the teana. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged March 11, 2013 Share March 11, 2013 To start off, as a benchmark, I am driving a 2008 1.8L civic. I have test driven a few cars and noted very different feels when it comes to the steering. To me, one of the main dislike when i test drive the Estima and Teana is how light the steering feels. It seems that from stationery or low speed, i need to turn the steering a lot before the car starts to turn. And faster speeds, it seems to be more 'responsive', thus the feel of the steering response being kind of inconsistent. The steering feel on my civic is different. The car seems to respond much better to slight turns on the steering. The latest camry is also fine. Is it that the implementation of the steering on the civic and camry is very different from that of the estima and teana. Can anyone shed some light (or some sort of technical explanation) on the different feel of the steering. I will however have to say that the test drives on the estima, teana and camry are for a short distance only. Hey bro! I thot jaws the only freak thinking about what u mentioned. I also think the turning ratio was different. I test driven fortuner n sylphy. I can't even manage to u turn to the lane I wanted without going slower than usual. N steering is so light that its scary, cos mayb used more strength so have tendency to over steer a bit. The feedback from fortuner also scary despite light feel, any feedback fr road transmitted to steering wheel so strongly. If don't grip tighter can throw light steering outta direction. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged March 11, 2013 Share March 11, 2013 Totally agree with you. Civic 1.8 is about 1 and quarter turn to lock, some of these bigger cars take more turns lock to lock. It's very similar feel to my current ride in term of turning, although Audi is well known (notorious) for its very light steering. But for me I like light steering Spot on! I turned fortuner steering as if it can turn "forever". Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic March 11, 2013 Share March 11, 2013 HAHA... BRO.. you compare with 7 nvm.. with 5 cannot compare le.. coz your A8 steering is quite light right? can adjust whether want comfort or dynamic, even dynamic still lighter, tried 7 series also not that heavy Link to post Share on other sites More sharing options...
Gohsj89 1st Gear March 11, 2013 Share March 11, 2013 (edited) Sorry. I probably should have asked this at one go. So, what steering mechanism does the latest Camry use? The feel seems somewhere in between the civic and the teana. lol nothing to sorry about.Camry I am not very, but at the same time... quite certain it's on electronic. There are a few kind of Power Steering. 1) Hydraulic Assisted Heavy or Light, depend on the car itself.When driving at hi-speed, you can feel the steering is significantly lighter than slow speed / stationery and that tells you your car is floating!! and i usually slow down. personal experience: Honda Stream, Civic (1.8 only), Toyota Vios (old), Corolla (1st gen altis), Hyundai Getz... 2) Electronic Motor Assisted. -Normal type: works the same as Hydraulic steering, usually much lighter than Hydraulic.Whether your car floats a not because of hi-speed it will still feel the same personal experience: Honda Civic (except 1.8), City, Toyota Vios (new), Hyundai Avante, Nissan Latio... 3) Active Electronic Motor Assisted (my analogy term)- When car is stationery, steering will be super light because the motor will work harder for you. -When car is in motion or hi-speed, the steering will be heavy because the motor makes it heavier which i find, gives you a false sense of security because you won't even know if you are floating. personal experience: Old Honda Jazz Not sure what's other forumer view on this.. these are my Point Of View. Thus, I would prefer Hydraulic steering anytime... I drive a Vios and i also frequently drive a Stream.Steering is definitely very different but no issue of adapting. Edited March 11, 2013 by Gohsj89 Link to post Share on other sites More sharing options...
Wormvirus 1st Gear March 11, 2013 Share March 11, 2013 well done for a 89, young boy very shiok already master so many jap car steering feel but can tell u never drive good conti car b4, good car at high speed power assist is nearly cut off so ur arm power is the new assist, if 1 arm dig nose & u drive very fast, very hard to turn steer but yet very sensitive to tiny lane change, thats why even at very high speed cars like porsche can easily outmaneuver typical car its not the steer that entire matters, its the suspension setup Link to post Share on other sites More sharing options...
Inlinefour Twincharged March 11, 2013 Share March 11, 2013 the E60 520i I tried quite light le.. E60 LCI with servotronic will be lighter Link to post Share on other sites More sharing options...
Tsr729 1st Gear March 11, 2013 Share March 11, 2013 Teana quite heavy steering. Wait till try a mit colt. Driven a mit colt plus. Steering super light. Can use one finger to turn. Link to post Share on other sites More sharing options...
Flameblade 1st Gear March 11, 2013 Share March 11, 2013 Volvo have the heaviest steering of all....in my opinion Have these 2 cars at home. My Alfa Romeo 159 has a even heavier steering feel compared to the Volvo S80 even at the "heaviest" setting that you can set in the car menu on the Volvo. Worst steering feel/feedback have to come from those Korean cars. Light, overly assisted and lack of feel and they tend to quickly snap back to self center after turning which is quite unusual and weird in my opinion. Link to post Share on other sites More sharing options...
ER-3682 Twincharged March 11, 2013 Share March 11, 2013 the E60 520i I tried quite light le.. Maybe equiped with "Active Steering". Link to post Share on other sites More sharing options...
ER-3682 Twincharged March 11, 2013 Share March 11, 2013 My 370z steering also very heavy... ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
A very touching story ..... truly love conquers ALL
Nice / Rare Vehicle Registration Number
Steering column
Steering column
High-tech jacket allows deaf people to feel the music
the newest Mercedes model slk plaid
