Adrianli Hypersonic March 11, 2013 Share March 11, 2013 My previous keyless system will auto lock after a few seconds. Even if key in the car. If u are locked out, just kick the tyre, thatz where the vibration sensor is installed. The alarm will sound and the system will sense the RFID key and unlock the door. Ask ur fren to kick the tyres. See if it works. Mine was by Soxxi. ↡ Advertisement Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged March 11, 2013 Share March 11, 2013 On 3/11/2013 at 2:48 AM, Kangadrool said: Doubt March has keyless entry; probably aftermarket fitted one. March does have keyless entry. Just that for this case, not sure whether the keyless entry system was fitted aftermarket. Link to post Share on other sites More sharing options...
Ben5266 Supercharged March 11, 2013 Share March 11, 2013 On 3/11/2013 at 12:44 AM, RadX said: Seems like Nissan not that smart ...my car impossible to lock if key inside So when you are driving, and you want to lock the car... you have to put the key outside??? Link to post Share on other sites More sharing options...
Wyfitms Twincharged March 11, 2013 Share March 11, 2013 On 3/11/2013 at 12:44 AM, RadX said: Seems like Nissan not that smart ...my car impossible to lock if key inside i can't lock the cefiro if the key is inside... Link to post Share on other sites More sharing options...
Rosschang 1st Gear March 11, 2013 Share March 11, 2013 I can't lock my IS250 from outsai if my key is insai... Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear March 11, 2013 Share March 11, 2013 Call Soxxi...they can unlock the car...but wont be cheap. Tel 6665 1605 Link to post Share on other sites More sharing options...
Maxus-MIFA9 Supersonic March 11, 2013 Author Share March 11, 2013 Thanks everyone, I found a way to unlock the door from Google video ..... Tried and its works... But very riskly as would be car theft would also do the same. All I need is an old hanger and a hard plastic to push in-between the door rubber sealant..... Link to post Share on other sites More sharing options...
Tohto Hypersonic March 11, 2013 Share March 11, 2013 On 3/11/2013 at 3:13 AM, Picnic06 said: Thanks everyone, I found a way to unlock the door from Google video ..... Tried and its works... But very riskly as would be car theft would also do the same. All I need is an old hanger and a hard plastic to push in-between the door rubber sealant..... Even though you currently solved the problem. It is better to know the root caused, why the door lock when keyless transmitter inside car? Link to post Share on other sites More sharing options...
Cars08 1st Gear March 11, 2013 Share March 11, 2013 On 3/11/2013 at 2:28 AM, Tungsl said: but if key is inside car when you drive off reaching more han 15km/h, the car doors automatically lock i had once when my keyless go refused to let me lock my doors resetting the master switch - no use need to drive with all passengers including myself holding to the door to keep the door close electronics are handy and useful if they work but we all expect them to fail sooner than later Sure bo bro...didnt lock doesnt mean the car door will open lah... need to hold on the door meh[laugh] u still can overwrite it by pressing the central lock system button in the car mah... Ur case could be bcos ur car sensor battery is weak or there could be other reason(s)... bring to AD to do a check.... door shouldnt spring open while you are driving.... even when i forgot to close the door properly while i drive on a highway...it didnt spring open...i jus hv to exit the highway stop by the side to close it properly... My only experience is my car boot opens up while I am driving bcos i accidentally press on boot release button as pants too tight... Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 11, 2013 Share March 11, 2013 nissan engineer can't be that lousy and its fool proof a after market alarm system must have been installed to create such problem Link to post Share on other sites More sharing options...
Maxus-MIFA9 Supersonic March 11, 2013 Author Share March 11, 2013 On 3/11/2013 at 3:16 AM, Tohto said: Even though you currently solved the problem. It is better to know the root caused, why the door lock when keyless transmitter inside car? Its my colleague car. Advised her to send back to check the sensor. Also advised her next time when coming out of the vehicle, do not close the driver's side door immediately, collect all her things first and then lock her car doors ... Link to post Share on other sites More sharing options...
Earthboy 4th Gear March 11, 2013 Share March 11, 2013 On 3/10/2013 at 11:59 PM, Picnic06 said: $100 plus .... I inform her that it is a common problem using 'keyless' system. The sensor should always on her body ... not true lei. when the sensor is in the car, the door refuse to be locked. at least mine is like that. Link to post Share on other sites More sharing options...
Earthboy 4th Gear March 11, 2013 Share March 11, 2013 On 3/11/2013 at 3:23 AM, Hamburger said: nissan engineer can't be that lousy and its fool proof a after market alarm system must have been installed to create such problem i think so too. factory fitted can be so screwed.. Link to post Share on other sites More sharing options...
Leepee 1st Gear March 11, 2013 Share March 11, 2013 Go home and get the spare metal key to open the door? If only one keyless fob...never mind. Surely she have a spare metal key somewhere? Link to post Share on other sites More sharing options...
Cars08 1st Gear March 11, 2013 Share March 11, 2013 On 3/11/2013 at 2:50 AM, Galantspeedz said: yes.. in a way.... usually if w engine on n ppl in the car, u can pass the key to the person in the car to lock the car from inside...nobody can open it from outside... you may also lock the car from outside with engine on using the car remote...either way also can...inside if wan to come out...can overwrite it by pulling the car release door handle or use the remote key.... releasing the door by pulling the door handle will only release that part of the door while the driver's door remained locked...using remote to release unless press twice (which will release my diriver's door only) and press once to release all doors....this is my encounter... Link to post Share on other sites More sharing options...
Pokyman 1st Gear March 11, 2013 Share March 11, 2013 On 3/10/2013 at 11:54 PM, Picnic06 said: Got a friend in distress when her 'keyless' sensor was inside her handbag and at the rear seat. She came out of the car and closed the driver's door and it auto lock. No spare sensor as she bought the car from 2nd hand dealer. Anyone know any method to open the door. Breaking the window will be the last resort. Model is Nissan 'March' ... hmm .. my car cant lock when key is inside the car de... hers is third party one ah Link to post Share on other sites More sharing options...
Tohto Hypersonic March 11, 2013 Share March 11, 2013 (edited) On 3/11/2013 at 3:26 AM, Leepee said: Go home and get the spare metal key to open the door? If only one keyless fob...never mind. Surely she have a spare metal key somewhere? Normally the metal key is build in the keyless transmitter. At least is for my previous Toyota and current ride. Edited March 11, 2013 by Tohto Link to post Share on other sites More sharing options...
Tungsl Clutched March 11, 2013 Share March 11, 2013 On 3/11/2013 at 3:22 AM, Cars08 said: Sure bo bro...didnt lock doesnt mean the car door will open lah... need to hold on the door meh[laugh] u still can overwrite it by pressing the central lock system button in the car mah... Ur case could be bcos ur car sensor battery is weak or there could be other reason(s)... bring to AD to do a check.... door shouldnt spring open while you are driving.... even when i forgot to close the door properly while i drive on a highway...it didnt spring open...i jus hv to exit the highway stop by the side to close it properly... My only experience is my car boot opens up while I am driving bcos i accidentally press on boot release button as pants too tight... my goodness! I hope it is not because something expanded dangerous ...... ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Mar 2025
Car of Politician
Car of Politician
Anyone missing a car plate?
Xiaomi EV is Coming
Xiaomi EV is Coming
