How long to change Brake Pad ?
Spiderman302
You hv a rare mechanic.
Like that my agent should be extint! My last servicing at 200k still no need to change. Even brake pad changed once only, at 110k.
Wah lau, you use leg brake or what ? :D :D :D
My car 93000km, still have around 7mm of fiction material left, so its possible. But still it is better to change as your old brake pads have gone through a number heat cycles, new pads will definitely improve braking!
His car put parachute behind. Hahaha.
My front pads changed at abt 80k km. Rear pads at abt 135k km.
I also use parachute plus got sail also. Hahaha.
Turbocharged
Are all brake pads, be it performance or not come with a warning sound whenever you brake to tell you its about time to change brake pad?
I dun think all hv. Only some hv a layer of rough material to give a grinding sound when pads almost gone.
Some cars hv a warning light on dash wil come on also.
my kimchee pad will have a screeching sound emitted from the screws rubbing the rotors and its time to change. Am on my third brake pad and 2nd rotor. Mileage 182k. :D
Edited by Berncsp76
My front pad and disc ard 30k km got to change new set... [bigcry]
As for rear pad and disc can last till 70k km then change... [:/]
Last time used to go up and down genting frequently and never remember had to change brake pads at 30k.
If yr screws or rivets touch e discs....its already too late. Yr disc damaged liow.
Thats why ty design pads wh grinding sound to frighten drivers to quickly go change pads.
Maybe thats why u needed change yr rotors b4.
I inspect my pads...inside n outside pads...when i know ty getting thin.
Once i see its abt 3mm i change asap.
Just wait for the warning lights to come on. Once the sensor in the pad hits the disc, it meas you have to change. If you wait for the screeching sound, it means its too late to save your discs as the screws have scored it already.
