Mysportwish 1st Gear March 7, 2013 Share March 7, 2013 hello my friend car (auto, Nissan), facing a problem. When his car stopped at traffic light, the RPM will dropped and the engine died. Anyone have similar experience and what could be the issue? Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Rncw 5th Gear March 7, 2013 Share March 7, 2013 On 3/7/2013 at 1:22 AM, Mysportwish said: hello my friend car (auto, Nissan), facing a problem. When his car stopped at traffic light, the RPM will dropped and the engine died. Anyone have similar experience and what could be the issue? Thanks in advance. his car got install any piggyback ECU? or check throttlebody, air filter...etc Link to post Share on other sites More sharing options...
JackRabbit 3rd Gear March 7, 2013 Share March 7, 2013 I experienced similar issue before. Later found out that alternator faulty, was not charging battery properly. So battery died, and car stalled, and could not be restarted; until jumpstarted. Not saying above same issue; but this what happened to me. Just sharing. Link to post Share on other sites More sharing options...
Versatile 1st Gear March 7, 2013 Share March 7, 2013 Check your throttle body, battery, alternator (as mentioned above), air filter and ECU. Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear March 7, 2013 Share March 7, 2013 most likely is throtto body issue. Might be dirty or IAV fail. If charging system got issue should have the batt warning light lighted. Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear March 7, 2013 Share March 7, 2013 (edited) most likely is throttle body issue. Might be dirty or ICV fail but more likely is dirty. If charging system got issue should have the batt warning light lighted. Sorry for the double post. Edited March 7, 2013 by Ivanpaseo Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 7, 2013 Share March 7, 2013 His mech may have replace with plugs that have higher resitance. The next check is to make sure the plug cables are dry no kV leak to ground and are properly inserted to the spark plugs. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear March 7, 2013 Share March 7, 2013 i also have a problem with cold starting. need to step accelerator while starting and feather. if not start alr will stall.. hot start no problems. any ideas? Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 7, 2013 Share March 7, 2013 This problem can be due to low head pressure in the fuel delivery system. The cause maybe fuel leakage within the system or there are air bubble in the system. Link to post Share on other sites More sharing options...
Josephsatu 1st Gear March 7, 2013 Share March 7, 2013 On 3/7/2013 at 3:35 AM, Mllcg said: i also have a problem with cold starting. need to step accelerator while starting and feather. if not start alr will stall.. hot start no problems. any ideas? Fuel pump failure? Thats what happen to my Nissan (13yrs ago) Jerking, then have to step on gas and sometimes just die off. Link to post Share on other sites More sharing options...
Srt911 Neutral Newbie March 7, 2013 Share March 7, 2013 On 3/7/2013 at 1:22 AM, Mysportwish said: hello my friend car (auto, Nissan), facing a problem. When his car stopped at traffic light, the RPM will dropped and the engine died. Anyone have similar experience and what could be the issue? Thanks in advance. Could be misfiring of cylinders...if under warranty better bring it back to AD to check. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear March 7, 2013 Share March 7, 2013 On 3/7/2013 at 4:12 AM, Josephsatu said: Fuel pump failure? Thats what happen to my Nissan (13yrs ago) Jerking, then have to step on gas and sometimes just die off. but hot start no issues. neither does it randomly stall. its only during cold start Link to post Share on other sites More sharing options...
Brock 1st Gear March 7, 2013 Share March 7, 2013 I have this problem as well on my kimchi auto car. Checked throttle body. Washed. Changed new one. Check spark plugs. Checked alternator and battery. ECU seems fine. No Engine Check warning light. Engine pressure also checked. Will still occasionally vibrate heavily before dying of if left stationary for close to 5 min. Weird thing is that vacuum meter reading is 0. No cracks or leaks at hoses. My mechanic check until give up already. Link to post Share on other sites More sharing options...
Fitzy Neutral Newbie March 7, 2013 Share March 7, 2013 Try replacing your O2 sensor. Happen to my brother's Vios, mechanic check O2 sensor through ECU all working fine but still rpm drop till stall when car stops. Took a gamble and replaced both O2 sensor and problem solved. Link to post Share on other sites More sharing options...
Chongyong Neutral Newbie March 7, 2013 Share March 7, 2013 On 3/7/2013 at 1:22 AM, Mysportwish said: hello my friend car (auto, Nissan), facing a problem. When his car stopped at traffic light, the RPM will dropped and the engine died. Anyone have similar experience and what could be the issue? Thanks in advance. Nissan latio??? Link to post Share on other sites More sharing options...
Mysportwish 1st Gear March 7, 2013 Author Share March 7, 2013 thanks all for your help. i will convey to my friends appreciate it Link to post Share on other sites More sharing options...
Pklim82 Neutral Newbie March 7, 2013 Share March 7, 2013 how abt idle valve? get a trusted mech and have it checked. it maybe the cause as well as it happed to mi as well Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 7, 2013 Share March 7, 2013 Either yr mech have tap the vacuum from the wrong location ,the hose is leaking or the gauge is faulty. ↡ Advertisement Link to post Share on other sites More sharing options...
Pope Francis RIP/A new p(H)ope
Another doctor in trouble
RIP: Donald Sutherland
Calciphylaxis: An almost fatal disease.
Hawkers worry about stall design after fire at newly opened Bukit Canberra Hawker Centre
