Kb27 Supersonic February 20, 2015 Share February 20, 2015 (edited) I tend to change battery base on mileage leh... not too sure whether its correct leh... I believe the lead-acid battery, like any others is based on the number of cycles. That is, how many times you can crank start. Mileage may be a good gauge if you crank once only and drive average distance. But if your drive is a short one, then you do more cranks per the fixed mileage, and that shortens battery life. Heat is a major problem, it kills the battery twice as fast. Those who live in northern US usually have battery life approaching 10 yrs, while the southern states is more like us, about 2 yrs+ Hi KB My battery is more than 2 yrs, let say bought spare battery and keep inside boots packaging unopened can damage the battery due to weather condition. You can keep spare battery but it needs to be charged periodically. Battery has internal resistance and leakage, even when not connected to anything. So the recommendation is to charge the battery every 3 months or so to full-charge. Otherwise the self-leakage which cause sulphation will eventually kill the battery, even when sitting on the shelf. That's also the reason why some people asked about how long the battery is sitting on the shelf. They tell you not to buy those. But actually, as long as the battery is kept in a fully-charged state, it doesn't go bad. It only goes bad when it's sitting on the shelf too long without being recharged periodically. Edited February 20, 2015 by Kb27 ↡ Advertisement Link to post Share on other sites More sharing options...
Azzurro 1st Gear February 20, 2015 Share February 20, 2015 I tend to change battery base on mileage leh... not too sure whether its correct leh... Dont worry about right or wrong. As long you never have to be rescued for baterry problem, to me you are doing it right. Link to post Share on other sites More sharing options...
TVT Supercharged February 23, 2015 Share February 23, 2015 I tend to change battery base on mileage leh... not too sure whether its correct leh... Then at what mileage do you change your car battery leh ? Link to post Share on other sites More sharing options...
TVT Supercharged February 23, 2015 Share February 23, 2015 You can keep spare battery but it needs to be charged periodically. Bro, how does such battery (not installed in a car) gets charged periodically? What equipment is needed ? Thanks. Link to post Share on other sites More sharing options...
flashbang Turbocharged February 23, 2015 Share February 23, 2015 What are the signs that battery is weakening and going to fail soon? Link to post Share on other sites More sharing options...
Adrianli Hypersonic February 23, 2015 Share February 23, 2015 What are the signs that battery is weakening and going to fail soon? When it takes more than once to crank start the engine. Link to post Share on other sites More sharing options...
thepirate Neutral Newbie February 23, 2015 Share February 23, 2015 What are the signs that battery is weakening and going to fail soon? Just start the engine on first attempt and if no response and have to start the engine again and the engine working on 2nd attempt, it is early sign of battery being "weak". Link to post Share on other sites More sharing options...
Kb27 Supersonic February 23, 2015 Share February 23, 2015 Bro, how does such battery (not installed in a car) gets charged periodically? What equipment is needed ? Thanks. You need a battery charger. It plugs into AC and output between 13.5 to 14.5V dc. They are many types. Those automatic type have algorithm to control voltage and current and they stopped charging once the battery is considered fully-charged. Many such brands are available, from a cheap 1A charger ($50) from Sim Lim to more expensive Ctek. You can also use DC power supply, (between 13.5 to 15V dc), but you need to control the charging time manually. Cheap power supplies are available. I'm also using this: http://www.aliexpress.com/store/product/Free-shipping-Wholesale-precision-Compact-Digital-Adjustable-DC-Power-Supply-OVP-OCP-OTP-low-power-32V5A/328763_1668592085.html?s=p Link to post Share on other sites More sharing options...
Kb27 Supersonic February 23, 2015 Share February 23, 2015 What are the signs that battery is weakening and going to fail soon? You might not feel the car "slow to crank". Your best bet is to go to a shop with a cca tester and have it checked. Example, your battery spec is 500 cca (SAE), if it's tested at less than 75%, that is around 350 cca or less, it's time to change. Many people use battery until they get stuck, unaware the cca is already very bad. Otherwise, use 2 yrs as an average time to change battery. Link to post Share on other sites More sharing options...
TVT Supercharged February 23, 2015 Share February 23, 2015 You need a battery charger. It plugs into AC and output between 13.5 to 14.5V dc. They are many types. Those automatic type have algorithm to control voltage and current and they stopped charging once the battery is considered fully-charged. Many such brands are available, from a cheap 1A charger ($50) from Sim Lim to more expensive Ctek. You can also use DC power supply, (between 13.5 to 15V dc), but you need to control the charging time manually. Cheap power supplies are available. I'm also using this: http://www.aliexpress.com/store/product/Free-shipping-Wholesale-precision-Compact-Digital-Adjustable-DC-Power-Supply-OVP-OCP-OTP-low-power-32V5A/328763_1668592085.html?s=p Then each charge is for how long ? Link to post Share on other sites More sharing options...
Divers 2nd Gear February 23, 2015 Share February 23, 2015 For push start button, if weak battery, will have tell tale sign also. Same like crank method. Push start a few times then start. If that happens, quickly go to WS to test battery condition or change battery. Do not off the car engine cos it might not start again. Luckily the battery die while at my house carpark. Link to post Share on other sites More sharing options...
Kb27 Supersonic February 23, 2015 Share February 23, 2015 Then each charge is for how long ? If you use automatic charger, there are indicators of when it's finished. If you use manual charger or dc power supply, it depends. Usually most people charge until (absorption) current is near to zero. Some website says between 1 to 3% So if you have a 100AH battery, when the charging current drops to 1A (1%), it's considered fully-charged. http://batteryuniversity.com/learn/article/charging_with_a_power_supply The correct method is to charge until specific gravity of battery no longer rises. But that requires you to have a hydrometer and is more inconvenient. Automatic chargers are known to be on the safe side. So they tend to stop charging before the battery is really "full". Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged February 23, 2015 Share February 23, 2015 4 yrs is amazing.. how did u do that? Nothing... just normal drive. Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 24, 2015 Share February 24, 2015 (edited) Then each charge is for how long ? Attached is taken from a battery charger user booklet for your perusal. Hope this helps. Edited February 24, 2015 by Yeobh Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear February 24, 2015 Share February 24, 2015 attached's a diagram depicting the various stages of charging and the estimated time for each stage using a 5A CTEK charger. CTEK Battery Charger.pdf Link to post Share on other sites More sharing options...
24hrsbatteryservices 1st Gear May 13, 2015 Share May 13, 2015 (edited) best is to change it every 2 years in Singapore car battery doesn't last more den 2 years due to the weather. if you need any replacement you can look for me . as a mobile recovery we don't have a physical shop so we doesn't have much overhead we will try to give our best price for our customers. cheers http://www.mycarforum.com/topic/2698808-24-hr-car-battery-service-car-battery-replacement/ Edited May 13, 2015 by 24hrsbatteryservices Link to post Share on other sites More sharing options...
JudeL 1st Gear October 25, 2018 Share October 25, 2018 (edited) Best way is to take a preventive stance and measure your battery's EMF using a multimeter. If the EMF hovers and start to dip below 12V, then it is time to shop for a new one. The best check for a battery is to do a CCA check with a meter that can perform that check. I've seen batts with high volt but low CCA and shows "Bad & Replace" on meter checks I always drive till need to change, and I find that you pay for what you get, sometimes higher price is worth it as it lasts longer. I use this doorstep service so even drive till flat also they can come change for you. https://fastfix.com.sg/ No point changing some unknown brand or bad brands that sometimes lasts only 6-8 months like Globatt or Drive. Stick with good brands like Amaron Bosch or Hoppecke (very good German batt!) I do some van rentals so i hate to get calls saying "eh your van cannot start!" Edited October 25, 2018 by JudeL Link to post Share on other sites More sharing options...
Lala81 Hypersonic December 1, 2018 Share December 1, 2018 My Battery just went flat today in my home carpark. promptly changed by one of our forummers. Punctual. came on agreed time. Plugged in a secondary battery so that I won't lose my audio settings. One option if u just need a battery change service. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
My EV journey to the i4
Change Disc Rotors
Change Disc Rotors
Tool to change Spark Plug
X for twitter change request
