Ungtiong 2nd Gear February 24, 2013 Share February 24, 2013 (edited) just checking you measure your 0-100 performance on the road. Was watching youtube and notice many used the speedometer (either video timed or hand timed), i recently realize that our speedometer can be faster by quite a bit as they factory always set it a bit higher (meaning it shows faster than it is)..so you time may look better. My car is almost 10km/hr difference at 100!!!!!! (verified with ODB sensor and GPS). For faster cars it maybe a fraction of a second difference, but for slower cars can make a 2 second difference (like mine slow Altis) I have tried GPS timing but its not very accurate as it can 'miss' the start. Now using ODBII sensor (android) and the times are very high..so maybe its the most accurate (ODB speed readings are different from what is shown on the speedometer. Now looking for program that can give acceleration curve. My car gear ratio means more zippy at low speed by really drag closer to 100. Anyone go another way of testing? Edited February 24, 2013 by Ungtiong ↡ Advertisement Link to post Share on other sites More sharing options...
Watwheels Supersonic February 24, 2013 Share February 24, 2013 (edited) I feel that the 0-100km/hr timing just gives you a rough idea how fast the car can go. There are other timings and info too like 0-100km/hr-0, braking distance. I'm not so paranoid and into these numbers, FC included. Coz all these are done under manufacturers condition. You do not get a prize nor money reward so stop being so boh liao like those ppl in YouTube and get a life. Spend your time doing smth more meaningful. Edited February 24, 2013 by Watwheels Link to post Share on other sites More sharing options...
Blue850r Clutched February 24, 2013 Share February 24, 2013 just checking you measure your 0-100 performance on the road. Was watching youtube and notice many used the speedometer (either video timed or hand timed), i recently realize that our speedometer can be faster by quite a bit as they factory always set it a bit higher (meaning it shows faster than it is)..so you time may look better. My car is almost 10km/hr difference at 100!!!!!! (verified with ODB sensor and GPS). For faster cars it maybe a fraction of a second difference, but for slower cars can make a 2 second difference (like mine slow Altis) I have tried GPS timing but its not very accurate as it can 'miss' the start. Now using ODBII sensor (android) and the times are very high..so maybe its the most accurate (ODB speed readings are different from what is shown on the speedometer. Now looking for program that can give acceleration curve. My car gear ratio means more zippy at low speed by really drag closer to 100. Anyone go another way of testing? Use Gtech Pro. Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic February 24, 2013 Share February 24, 2013 you should trust the the spec on paper ma if u dun believe bring to workshop Link to post Share on other sites More sharing options...
Blue850r Clutched February 24, 2013 Share February 24, 2013 I feel that the 0-100km/hr timing just gives you a rough idea how fast the car can go. There are other timings and info too like 0-100km/hr-0, braking distance. I'm not so paranoid and into these numbers, FC included. Coz all these are done under manufacturers condition. You do not get a prize nor money reward so stop being so boh liao like those ppl in YouTube and get a life. Spend your time doing smth more meaningful. Yes your comments are correct. However, the timings of 0-100km/h and 1/4 mile will indicate the power of the car. For stock car you will know if the manufactuer had over-rate or under-rate the power. If mod car, then you will know if the tuner did a good job or not. Or for used cars, the 1/4 mile timing will tell if the engine is still having same power as new car or not. Link to post Share on other sites More sharing options...
Watwheels Supersonic February 24, 2013 Share February 24, 2013 Yes your comments are correct. However, the timings of 0-100km/h and 1/4 mile will indicate the power of the car. For stock car you will know if the manufactuer had over-rate or under-rate the power. If mod car, then you will know if the tuner did a good job or not. Or for used cars, the 1/4 mile timing will tell if the engine is still having same power as new car or not. The timings are good to know for you but dan if you are not competing in a race it's only good to you. If you upload into YouTube more ppl will know but it serves little purpose. Probably justify your money well spent for getting faster from 0-100. Link to post Share on other sites More sharing options...
Happily1986 5th Gear February 24, 2013 Share February 24, 2013 Which road, what road? Tell me I cc TP. The question I throw back to you is WHY do you measure your 0-100 timing on the (so conveniently omitted term, public) road? Link to post Share on other sites More sharing options...
Wormvirus 1st Gear February 24, 2013 Share February 24, 2013 0-100 no use except when stopping taxi want to cut u at traffic go, in gear acc is better as u can cut taxi off Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear February 24, 2013 Share February 24, 2013 Theres a device specially for this The old thing used for tuning the af ratio is call safc They Hv one to time the pick up But I forgot the name Too long ago Liao It's the same thing to cut off the speed or rev limiter I think it's call RSM Rev speed meter? By apexi Link to post Share on other sites More sharing options...
1fast1 Supersonic February 25, 2013 Share February 25, 2013 Theres a device specially for this The old thing used for tuning the af ratio is call safc They Hv one to time the pick up But I forgot the name Too long ago Liao It's the same thing to cut off the speed or rev limiter I think it's call RSM Rev speed meter? By apexi Yes Apexi RSM can do this, along with 1/4 mile (or 400m) timing, and other measurements. It uses the signal from the ECU to do the measurement. GTECH Pro is another device that can do it - this is an accelerometer that you plug into the ciggie lighter socket. Does not depend on the ECU signal, so it's unaffected by changes in rolling diameter (upsized rims) - but on the whole, may be less accurate than RSM. Link to post Share on other sites More sharing options...
Icebrush79 4th Gear February 25, 2013 Share February 25, 2013 Theres a device specially for this The old thing used for tuning the af ratio is call safc They Hv one to time the pick up But I forgot the name Too long ago Liao It's the same thing to cut off the speed or rev limiter I think it's call RSM Rev speed meter? By apexi I measure mine using Defi Advance ZD. Ooh... not on public roads... Link to post Share on other sites More sharing options...
Maseratigood 5th Gear February 25, 2013 Share February 25, 2013 you should trust the the spec on paper ma if u dun believe bring to workshop Wow, which dealer workshop do 0-100 checks for the cars they sell? Just joking If the car feels or sounds fast when i drive it, I am happy, don't want the stop watch or actual professional test to shutter my "dream", or illusion Link to post Share on other sites More sharing options...
Pms 3rd Gear February 25, 2013 Share February 25, 2013 Changing rims or tyre size from the stock spec with make the speedo run off. Link to post Share on other sites More sharing options...
Maseratigood 5th Gear February 25, 2013 Share February 25, 2013 0-100 no use except when stopping taxi want to cut u at traffic go, in gear acc is better as u can cut taxi off Agreed But, I saw taxis doing 0-100 sprints with other cars when red light turned green, so ts needs to find out and prepare his car. Link to post Share on other sites More sharing options...
Maseratigood 5th Gear February 25, 2013 Share February 25, 2013 Another thing:- the car makers must have clocked their official 0-100 timings using factory driver trained to do it day in day out, on perfect tarmac surface and wind condition, proper tyres with proper pressure, under most ideal atmospheric conditions, and take the best of maybe 50 trials? not many owners can repeat the official 0-100 although there must also be a few who actually better them Link to post Share on other sites More sharing options...
Blue850r Clutched February 25, 2013 Share February 25, 2013 Which road, what road? Tell me I cc TP. The question I throw back to you is WHY do you measure your 0-100 timing on the (so conveniently omitted term, public) road? Are you implying that 0-100km/h on public road is dangerous? Link to post Share on other sites More sharing options...
Blue850r Clutched February 25, 2013 Share February 25, 2013 Another thing:- the car makers must have clocked their official 0-100 timings using factory driver trained to do it day in day out, on perfect tarmac surface and wind condition, proper tyres with proper pressure, under most ideal atmospheric conditions, and take the best of maybe 50 trials? not many owners can repeat the official 0-100 although there must also be a few who actually better them There is surely some minor variance in timing but if car is modded or using different grade of petrol, the timing will tell if there is a gain in power or loss power. We use the before and after delta (the difference) to determine the effects. It is more for benchmarking. Not just for racing or some stunts that some Bros have in their mind. Link to post Share on other sites More sharing options...
Maseratigood 5th Gear February 25, 2013 Share February 25, 2013 Are you implying that 0-100km/h on public road is dangerous? OT a bit:- If A does 0-100 in say 5 sec on public road, B does it in say 14 sec, yes 14 sec! Between the two, if they do it on public roads, who is more dangerous to other road users? ↡ Advertisement Link to post Share on other sites More sharing options...
Reckless Cyclist
Reckless Cyclist
Anybody into quantum physics, relativity or just a science freak?
What is this road at buangkok?
Where to get those plastics that allow your to stick the road tax/decal on screen
