Pureness Clutched February 11, 2013 Share February 11, 2013 any idea who or how should i go about repairing it? when it rains water will accumulate into my rear brake light this far it doesn't seem to spoil the lights though ↡ Advertisement Link to post Share on other sites More sharing options...
Keavze 1st Gear February 11, 2013 Share February 11, 2013 Take out reseal with silicon, else drill a tiny hole at the most bottom part where it's not obvious. Link to post Share on other sites More sharing options...
VenomMX 4th Gear February 11, 2013 Share February 11, 2013 My car had the same problem.. Easy to solve.. Just involves drilling a small hole at e base of the light.. Did mine at SKM for a minimal fee Link to post Share on other sites More sharing options...
Pureness Clutched February 11, 2013 Author Share February 11, 2013 Take out reseal with silicon, else drill a tiny hole at the most bottom part where it's not obvious. problem is i don't know where the leak is coming from would a small hole remove vapour too? Link to post Share on other sites More sharing options...
Passion 5th Gear February 11, 2013 Share February 11, 2013 problem is i don't know where the leak is coming from would a small hole remove vapour too? 3 option here. 1. change a new tail lamp. 2. Reseal the tail lamp. 3. Drill hole to release water. But this wouldn't work if it is water vapour. Water vapour is normal. Even my headlight, during damn cooling days will have vapour after switching on for long hours. Link to post Share on other sites More sharing options...
Colourblind Clutched February 12, 2013 Share February 12, 2013 My rear tail light also water entered...I have resealed with silicon all around. But after 2 weeks, water appeared again in my tail light. Got pissed off and went stockist and got it replaced. Last month my front headlight also encountered same problem...I got it replaced too...so far so gd....Total damaged $200+ for front X1 n rear X1 .... Link to post Share on other sites More sharing options...
Pureness Clutched February 12, 2013 Author Share February 12, 2013 My rear tail light also water entered...I have resealed with silicon all around. But after 2 weeks, water appeared again in my tail light. Got pissed off and went stockist and got it replaced. Last month my front headlight also encountered same problem...I got it replaced too...so far so gd....Total damaged $200+ for front X1 n rear X1 .... noted. however my tail lights will cost over $250 if bought 2nd hand from ebay if bought from local distributor i suspect will be over $300 easily Link to post Share on other sites More sharing options...
Acerchan2002 Clutched February 12, 2013 Share February 12, 2013 Mazda 3 before SP model got this problem... I DIY and solve it for my fren and my ride Link to post Share on other sites More sharing options...
Colourblind Clutched February 12, 2013 Share February 12, 2013 What car you driving? You got try stockist? Link to post Share on other sites More sharing options...
Porsche916 Neutral Newbie March 12, 2013 Share March 12, 2013 You could try this on a Sunday afternoon. Remove tail lamp assembly and clean it well. Inspect for any damages, leaks and the rubber washers which secure the lens to the base of the assembly. Ensure it Link to post Share on other sites More sharing options...
Alan39 Neutral Newbie March 12, 2013 Share March 12, 2013 My tail light also encounter the same issue...Seal with silicon but after 1 week...Vapour appear inside again... Link to post Share on other sites More sharing options...
Bobucw 2nd Gear March 12, 2013 Share March 12, 2013 3 option here. 1. change a new tail lamp. 2. Reseal the tail lamp. 3. Drill hole to release water. But this wouldn't work if it is water vapour. Water vapour is normal. Even my headlight, during damn cooling days will have vapour after switching on for long hours. Errmm,..... how about 4th option??... -- Buy goldfiss put inside... Free fiss tank. Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 12, 2013 Share March 12, 2013 which car make and model? Link to post Share on other sites More sharing options...
Bensonawyong Neutral Newbie April 24, 2013 Share April 24, 2013 My tail light also encounter the same issue...Seal with silicon but after 1 week...Vapour appear inside again... I believed that all water has not been cleared before you silicon. ↡ Advertisement Link to post Share on other sites More sharing options...
Aquatic Plants - Anyone into it as well?
