Mitsubishi super long life coolant
Keen
I bought my coolant from Ming ghee. Initially wanna buy the red color 4 liter Toyota coolant abt 25 plus but Ming ghee recommend to buy honda 4L version. He mention better performance than Toyota at ard 35bucks.
Ming ghee is a good place to get stuff. They gave you great advice to get the better product
and also save money.
:D
TOP up with coolant and not water
Y not? i being using tap water for 7 years liao.. car ok lay.. but of cos i got remain coolant not juz only water [cool]
Edited by Proton
i dont think its wrong to change coolant regularly.
another factor is PH value. over time cooling water changed to acidic, and that's bad for engine
I wil change my coolant every 3yrs or 60-70k km when i change my timing belt n waterpump.
So far no problem. I dun do top-up cos e moment i find my coolant drop it means there is a leak in e system n i get it fixed.
I recently started using OWS coolant to try. So far so good fr last couple if months.
If its good i prob use it again next year when i change my timing belt n waterpump.
is the concentrate version still available or now all is pre-mixed ??
Both have. Best get the premix one. Mustafa have.
Frankly speaking RED or Green is the same is ONLY the color different....Best to change every 20-30K.
If you want value for money can check out Capro Anti Freeze Coolant 2200ml ever brought from Fairprice Xtra AMK Hub below $10 / bottle available in Red or Green color :D
Typical long life coolant can last up to 100k or 5 years, changing every 20-30k is overkill.
this is very true.
I regretted changing my coolant after 2 years and 30,000 km
as the coolant looked brand new like out of the bottle.
:D
I just got hold 2 x 2L Mitsubishi Super Long Life coolant Premium from my supplier. Blue in color. Been using the Mitsubishi Super long life coolant (green) in the past. They are not that expensive.
luckily mine uses timing chain, so I get coolant replaced every 40+K km.You are right that closed cooling system should not need regular top ups frequently. Missing cooling water may be signs of leak.
