Roberttan 5th Gear February 7, 2014 Share February 7, 2014 I use Nitrogen. Only need to check abt 3-4 months. Friend , filling with nitrogen gas doesn't meant you can run away the regular checking of tyre pressure. main reason for checking tyre pressure once every fortnight is to monitoring the pressures and should discovered any pressure lost on any tyre and you should it check see got any leak caused by nail or something else . So please continue the regular pressure checking for Safety reason running on too low pressure could lead to tyre failure especially on high speed long distance drving ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 7, 2014 Share February 7, 2014 Friend , filling with nitrogen gas doesn't meant you can run away the regular checking of tyre pressure. main reason for checking tyre pressure once every fortnight is to monitoring the pressures and should discovered any pressure lost on any tyre and you should it check see got any leak caused by nail or something else . So please continue the regular pressure checking for Safety reason running on too low pressure could lead to tyre failure especially on high speed long distance drving Ya but usually no puncture wil last long time. ↡ Advertisement Link to post Share on other sites More sharing options...
Michelin Primacy 5 Energy
Pirelli P Zero PZ5
Pirelli P Zero PZ5
Petlas Or Giti?
Petlas Or Giti?
