Yeobh 4th Gear May 31, 2013 Share May 31, 2013 (edited) This got nothing to do with tech aspect but purely marketing actions to retain existing customers and hopefully convert them in repeat customers. Many garages are offering very cheap labour to replace engine oil, the sole objective is to hope over time to land in big ticket service repair jobs Edited May 31, 2013 by Yeobh ↡ Advertisement Link to post Share on other sites More sharing options...
Monkill May 31, 2013 Share May 31, 2013 This got nothing to do with tech aspect but purely marketing actions to retain existing customers and hopefully convert them in repeat customers. Many garages are offering very cheap labour to replace engine oil, the sole objective is to hope over time to land in big ticket service repair jobs Good for us as consumer Link to post Share on other sites More sharing options...
Timex1441 1st Gear May 31, 2013 Share May 31, 2013 no N2 for me....cos I like to check n pump tyres once a week....it's already built into my routine, juz like drinking kopi at my neighbourhood coffee shop on saturday morning Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 31, 2013 Share May 31, 2013 It's works only for some shops with loyal customers but for many marginal customers who have no appreciations for good works and services usually stray across the causeway. Link to post Share on other sites More sharing options...
Remylee Clutched May 31, 2013 Share May 31, 2013 Pump nitro into your tyres? You wanna fly isit? Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 31, 2013 Share May 31, 2013 If you have the time and enjoy pumping tyres, why not Link to post Share on other sites More sharing options...
Monkill May 31, 2013 Share May 31, 2013 Here is the googled result from http://www.popularmechanics.com/cars/how-t...estions/4302788 A: Sort of. From the top: Air is 78 percent nitrogen, just under 21 percent oxygen, and the rest is water vapor, CO2 and small concentrations of noble gases such as neon and argon. We can ignore the other gases. There are several compelling reasons to use pure nitrogen in tires. First is that nitrogen is less likely to migrate through tire rubber than is oxygen, which means that your tire pressures will remain more stable over the long term. Racers figured out pretty quickly that tires filled with nitrogen rather than air also exhibit less pressure change with temperature swings. That means more consistent inflation pressures during a race as the tires heat up. And when you're tweaking a race car's handling with half-psi changes, that's important. Passenger cars can also benefit from the more stable pressures. But there's more: Humidity (water) is a Bad Thing to have inside a tire. Water, present as a vapor or even as a liquid in a tire, causes more of a pressure change with temperature swings than dry air does. It also promotes corrosion of the steel or aluminum rim. If I ever need to top off a tire when I'm out on the road, I'll always briefly depress the tire chuck's valve with my thumbnail and vent some air. If my thumb gets wet, there's water in the line. Some gas stations don't do a very good job of keeping the humidity out of their air system. I don't even like to use a water-based tire-mounting lubricant unless I can let the tire bake in the sun for a couple of hours before I air it up and seat the bead. I've dismounted tires (not mine) that had several quarts of water inside Link to post Share on other sites More sharing options...
Monkill May 31, 2013 Share May 31, 2013 Since I have free nitrogen top up and it's near my house, I dont mind going for it. hahahaa Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 31, 2013 Share May 31, 2013 You on nitrogen? I used to be on nitrogen but went back to normal air. Easier to pump and maintain at any petrol kiosk. OT a bit: Planning to go Jimmy there to do alignment soon. You still going to him? Nitrogen saves me e trouble of going top up every week. Been on it abt 2 yrs. I stopped going jimmy long long ago. Found better places to get my tire stuff done. Link to post Share on other sites More sharing options...
Yuan 6th Gear May 31, 2013 Share May 31, 2013 Must be joke to offer nitrogen gas for road tyres. This idea original for aeroplanes due to high altitudes and temp. For road tyres, most important is dry compressed air. It is a selling point for some tyre shops these days. Link to post Share on other sites More sharing options...
Yuan 6th Gear May 31, 2013 Share May 31, 2013 Nitrogen saves me e trouble of going top up every week. Been on it abt 2 yrs. I stopped going jimmy long long ago. Found better places to get my tire stuff done. I seldom use nitrogen these days as I checked tyres regularly. For Jimmy, I go to him only when my regular alignment shop is packed or full. Link to post Share on other sites More sharing options...
Yuan 6th Gear May 31, 2013 Share May 31, 2013 I don't know if its a joke but $20 for 4 tyres, someone must be laughing all the way to the bank. That is expensive. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 31, 2013 Share May 31, 2013 I seldom use nitrogen these days as I checked tyres regularly. For Jimmy, I go to him only when my regular alignment shop is packed or full. I like nitro mainly fr e convenience. I dun need to go petrol station to pump cos sometimes got pple there n u hv to wait forever fr them to finish or sometimes u reach e air pump spoil. I can only go pump air after car parked a few hours then tire wil b cold. Quite inconvenient. Nitro i only pump after a few months n e pressure drop not as much as air. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 31, 2013 Share May 31, 2013 That is expensive. I paid abt that but i get free unlimited top ups so spread over several years.....its not ex to me. Something like maint free battery. Cost a bit more but saves me time n trouble. Link to post Share on other sites More sharing options...
Monkill May 31, 2013 Share May 31, 2013 I paid abt that but i get free unlimited top ups so spread over several years.....its not ex to me. Something like maint free battery. Cost a bit more but saves me time n trouble. I got unlimited top up too! Why are you guys paying? Link to post Share on other sites More sharing options...
Monkill May 31, 2013 Share May 31, 2013 (edited) edited* Edited May 31, 2013 by Monkill Link to post Share on other sites More sharing options...
Yuyububu Neutral Newbie May 31, 2013 Share May 31, 2013 Is there any diff between nitro filled tyres and regular air? Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 31, 2013 Share May 31, 2013 I got unlimited top up too! Why are you guys paying? U get free nitro fr yr tires? ↡ Advertisement Link to post Share on other sites More sharing options...
Is this tyre good? Made in SG!! Giti tyres!
Getting new tyres soon...
