Simon29 Neutral Newbie December 17, 2012 Share December 17, 2012 Nitrogen in the atmosphere is already 78%. And the so called pumped in nitrogen is 100% pure?? Did they do a vacuum before introducing nitrogen into tyre?? Bottom line......waste money lah That's my concern as well. Perhaps they pump in the pure nitrogen gas, release the tyre gas, repump nitrogen gas, repeat a few times. This will ensure the tyre contains pure nitrogen gas. Air already 78%nitrogen......good enough. I would only be interested if they sell helium or argon gas filling. That will help to lighten up the tyres. ↡ Advertisement Link to post Share on other sites More sharing options...
Kiario 5th Gear December 18, 2012 Share December 18, 2012 guys , do you all feel any different after pumping the nitrogen gas ? actually none at all... but since it was filled with nitrogen during tyre change for free, i take it. i later refill with normal air at petrol kiosk, no problem whatsoever... Link to post Share on other sites More sharing options...
Xefera 6th Gear December 18, 2012 Share December 18, 2012 Sure you can. but then you will be waiting for disaster to happen. Oxygen is more combustible than air. Just need one tiny spark to ...... Link to post Share on other sites More sharing options...
Vidz 6th Gear December 18, 2012 Share December 18, 2012 with nitrogen, the leak is less, so longer topup/check interval. for temp, unless you power slide or you have 300bhp, its just hype Link to post Share on other sites More sharing options...
Topspin 2nd Gear December 18, 2012 Share December 18, 2012 I would only be interested if they sell helium or argon gas filling. That will help to lighten up the tyres. I was curious about your suggestion therefore I ran the calculations through my computer, the helium in a helium filled tire will be only 14% the weight of the same volume of Nitrogen and at the same pressure. But in absolute terms, assuming the volume of Nitrogen or Helium inside a tire is 50 liters, it means that the Nitrogen gas will weigh 0.18 kg and Helium will weigh 0.03 kg. Not much reduction in absolute weight. The weight of the rims and the rubber in the tire will already weigh about 15 kgs. Conclusion, for weight savings of the wheels, better to buy a lighter rims and forget about Helium Link to post Share on other sites More sharing options...
Sjlim Clutched December 18, 2012 Share December 18, 2012 for temp, unless you power slide or you have 300bhp, its just hype Hi, What's the impact on tyre temp if you have 300 hp? Should be only if you drive at high speed, right? Thanks. Link to post Share on other sites More sharing options...
Dark_flan 2nd Gear May 31, 2013 Share May 31, 2013 Anyone knows where to pump nitrogen gas for tyres? I just changed tyres at AL tyres but they dun have nitrogen gas service. Seems it's economical to run on nitrogen gas than conventional air... Suggestions? Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 31, 2013 Share May 31, 2013 Anyone knows where to pump nitrogen gas for tyres? I just changed tyres at AL tyres but they dun have nitrogen gas service. Seems it's economical to run on nitrogen gas than conventional air... Suggestions? Many tire shops hv nitrogen. Most wil give u free incl top ups if u buy their tires. If not their tires i think u can pay $5/tire with free top ups. U can try places like stamford n autobacs etc. Advantage is u dun need to top up yr air every week. I use fr a few months then go back n ty top up any drop. Air pressure drop much slower than air n it stays cooler n stable fr long high speed drives. Link to post Share on other sites More sharing options...
Rustyz 5th Gear May 31, 2013 Share May 31, 2013 Honda, H tyre has such svr Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 31, 2013 Share May 31, 2013 Why economical? Juz get Airman Tire Repair kit. It comes with an electric pump. Everyday pump tire also can. Link to post Share on other sites More sharing options...
Jamesc Hypersonic May 31, 2013 Share May 31, 2013 (edited) Anyone knows where to pump nitrogen gas for tyres? I just changed tyres at AL tyres but they dun have nitrogen gas service. Seems it's economical to run on nitrogen gas than conventional air... Suggestions? I know a few cheap places if you don't mind 78% nitrogen instead of pure 100%. They will even throw in free some very rare and noble gases. I think also include helium to make your car a little bit lighter. But only a bit so your car won't fly in the air. Edited May 31, 2013 by Jamesc Link to post Share on other sites More sharing options...
Yuan 6th Gear May 31, 2013 Share May 31, 2013 Many tire shops hv nitrogen. Most wil give u free incl top ups if u buy their tires. If not their tires i think u can pay $5/tire with free top ups. U can try places like stamford n autobacs etc. Advantage is u dun need to top up yr air every week. I use fr a few months then go back n ty top up any drop. Air pressure drop much slower than air n it stays cooler n stable fr long high speed drives. You on nitrogen? I used to be on nitrogen but went back to normal air. Easier to pump and maintain at any petrol kiosk. OT a bit: Planning to go Jimmy there to do alignment soon. You still going to him? Link to post Share on other sites More sharing options...
Dark_flan 2nd Gear May 31, 2013 Share May 31, 2013 Why economical? Juz get Airman Tire Repair kit. It comes with an electric pump. Everyday pump tire also can. Heard u can save bit on fuel, comfortable & longer tyre life. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 31, 2013 Share May 31, 2013 Must be joke to offer nitrogen gas for road tyres. This idea original for aeroplanes due to high altitudes and temp. For road tyres, most important is dry compressed air. Link to post Share on other sites More sharing options...
Kangadrool Supersonic May 31, 2013 Share May 31, 2013 If free, no harm lah since so many people rave about it. For me, I don't bother if tyre shop fills up nitrogen or corrupted air. Link to post Share on other sites More sharing options...
Jamesc Hypersonic May 31, 2013 Share May 31, 2013 Must be joke to offer nitrogen gas for road tyres. This idea original for aeroplanes due to high altitudes and temp. For road tyres, most important is dry compressed air. I don't know if its a joke but $20 for 4 tyres, someone must be laughing all the way to the bank. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 31, 2013 Share May 31, 2013 Shops offering nitrogen are cone by equipment suppliers who in turns fool car owners who are naive aka hai gong. Link to post Share on other sites More sharing options...
Monkill May 31, 2013 Share May 31, 2013 Went down to change new set of tyres this morning, the shop provide free nitrogen top up for 2 years. ↡ Advertisement Link to post Share on other sites More sharing options...
Is this tyre good? Made in SG!! Giti tyres!
Getting new tyres soon...
