Maddude Neutral Newbie December 10, 2012 Share December 10, 2012 Hi all I tried "cable installation" and "cable installer" search on the forums but couldn't find an answer. Was wondering if anyone has a workshop to recommend to install just the in car camera power cable? Any idea on the cost of installing 2 (1 at the rearview cam and the other at the rear)? I got the in-car camera but the wire is hanging from my 12V socket to the rearview mirror, kinda looks fugly. Thanks in advance! ↡ Advertisement Link to post Share on other sites More sharing options...
Colnagobob 1st Gear December 10, 2012 Share December 10, 2012 bro,any car audio shop will be able to do for you at low cost..:) Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear December 10, 2012 Share December 10, 2012 I did mine in Malaysia...RM80. They did not cut the wires between the supplied charger to the camera...instead they added another 12V socket and hide behind the dashboard...wire run from there to the top...cos they say some of the supplied charger amperage is higher...if potong already some cam dun work cos not enuff power. So to install a additional 12V socket is safer. Link to post Share on other sites More sharing options...
Fishy 4th Gear December 10, 2012 Share December 10, 2012 Chuan Sing @ Sin Ming blk 29? Link to post Share on other sites More sharing options...
Zniper 2nd Gear December 10, 2012 Share December 10, 2012 soon lee @ geylang is gd... i did mine there... :) Link to post Share on other sites More sharing options...
Gohsj89 1st Gear December 10, 2012 Share December 10, 2012 I did myself. Went to Autobac, $9 but extra pair of Socket (not those plug in kind, but those you need to do your own grounding + connecting the fuse box). One for Front, another one for Rear. Neat and tidy. Perfect. But must say, Vios very easy to do these kind of thing la. Other car idk. Link to post Share on other sites More sharing options...
Kenomi 2nd Gear December 10, 2012 Share December 10, 2012 On 12/10/2012 at 8:15 AM, Maddude said: Hi all I tried "cable installation" and "cable installer" search on the forums but couldn't find an answer. Was wondering if anyone has a workshop to recommend to install just the in car camera power cable? Any idea on the cost of installing 2 (1 at the rearview cam and the other at the rear)? I got the in-car camera but the wire is hanging from my 12V socket to the rearview mirror, kinda looks fugly. Thanks in advance! did mine for $35 with a extra connector in at stamford tire Link to post Share on other sites More sharing options...
Nystalia Neutral Newbie December 10, 2012 Share December 10, 2012 On 12/10/2012 at 10:55 AM, Zniper said: soon lee @ geylang is gd... i did mine there... :) How much bro? Link to post Share on other sites More sharing options...
Johorat 1st Gear December 10, 2012 Share December 10, 2012 On 12/10/2012 at 8:45 AM, Ghostrider said: I did mine in Malaysia...RM80. They did not cut the wires between the supplied charger to the camera...instead they added another 12V socket and hide behind the dashboard...wire run from there to the top...cos they say some of the supplied charger amperage is higher...if potong already some cam dun work cos not enuff power. So to install a additional 12V socket is safer. I think you kena chop carrot. I did mine for only RM20 Link to post Share on other sites More sharing options...
RageX 1st Gear December 10, 2012 Share December 10, 2012 I second Soon Lee @ Geylang. Cheap and good and fast! Link to post Share on other sites More sharing options...
Dafansu Turbocharged December 10, 2012 Share December 10, 2012 diy mine, just need to remove those plastic pillars and slot in Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear December 11, 2012 Share December 11, 2012 On 12/10/2012 at 1:58 PM, Johorat said: I think you kena chop carrot. I did mine for only RM20 With the extra 12V socket ? Wow then that is cheap !!! Link to post Share on other sites More sharing options...
Topgan 1st Gear December 11, 2012 Share December 11, 2012 DIY, it is easy. You just need a plastic card or ruler. Push the DVR wire into the side of the roof, pillar etc. Did mind front and rear DVR this way together with a extra cigarette holder for the additional plugs. Link to post Share on other sites More sharing options...
Newdrive 1st Gear December 11, 2012 Share December 11, 2012 On 12/10/2012 at 1:26 PM, Nystalia said: How much bro? they charge $30. just done my on last sat. very quick... 10 min job done. Link to post Share on other sites More sharing options...
Zogel Clutched December 11, 2012 Share December 11, 2012 On 12/11/2012 at 6:49 AM, Newdrive said: they charge $30. just done my on last sat. very quick... 10 min job done. U got address? thanks! Link to post Share on other sites More sharing options...
Newdrive 1st Gear December 11, 2012 Share December 11, 2012 On 12/11/2012 at 7:21 AM, Zogel said: U got address? thanks! postal code 389638. its just before the taiwan smelly beancurd that stretch down. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear December 11, 2012 Share December 11, 2012 On 12/11/2012 at 6:13 AM, Topgan said: DIY, it is easy. You just need a plastic card or ruler. Push the DVR wire into the side of the roof, pillar etc. Did mind front and rear DVR this way together with a extra cigarette holder for the additional plugs. Dun want the wires dangling here and there lah...temp while I test the cam is ok...but if everyday see wires all over the shop I will be bothered. Installing the rear cam is no issue...easy to do...but dunno how to wire up the power lah...aiyah...just pay to get the problem solved. Link to post Share on other sites More sharing options...
Dafansu Turbocharged December 11, 2012 Share December 11, 2012 On 12/11/2012 at 8:59 AM, Ghostrider said: Dun want the wires dangling here and there lah...temp while I test the cam is ok...but if everyday see wires all over the shop I will be bothered. Installing the rear cam is no issue...easy to do...but dunno how to wire up the power lah...aiyah...just pay to get the problem solved. i got those multi cigarette adapter slot in near the empty space beside the pedal, then slot in the wiring into the roof carpet and side pillar to the adapter. all hidden ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Mar 2025
Xiaomi EV is Coming
Xiaomi EV is Coming
2024 Suzuki Swift
2024 Suzuki Swift
Mileage Tampering
Mileage Tampering
COE Bidding – Feb 2025
Servicing car at Shell station
