Rogersk8ter 1st Gear October 31, 2012 Share October 31, 2012 Was driving somewhere in Jurong and all of a sudden inside the car sells of chemical. the smell lingers inside for quite sometime. I believe my car is not air tight and air with funny smell leaks in. Anyway to improve the seal? or it only happens to older cars? if i make love inside car will i die of poisoning? ↡ Advertisement Link to post Share on other sites More sharing options...
WTF 4th Gear October 31, 2012 Share October 31, 2012 If car is so air-tight, we'll be able to use it as a boat liao......... Link to post Share on other sites More sharing options...
ER-3682 Twincharged October 31, 2012 Share October 31, 2012 Some European cars will run with 20% fresh air,even A/C is in Rec mode. Link to post Share on other sites More sharing options...
Jordanplus 1st Gear October 31, 2012 Share October 31, 2012 If credit is air tight, ants & cockroaches won't make home in inside e car liao Link to post Share on other sites More sharing options...
Darthx123 Neutral Newbie November 1, 2012 Share November 1, 2012 If car is so air-tight, we'll be able to use it as a boat liao......... [laugh]...... unless u put tube and pump the exhaust into ur car dont think u will die so easily Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 1, 2012 Share November 1, 2012 If car is air tight, will u even be able to breathe!!! Link to post Share on other sites More sharing options...
Aventador 6th Gear November 1, 2012 Share November 1, 2012 If car is air tight, will u even be able to breathe!!! Adrainli is correct if your car is airtight, the air inside will start with about 21% oxygen level and this will slowly diminish and be replaced by carbon dioxide then either you get light headed from insufficient oxygen and crash the car or suffocate and die from lack of oxygen Link to post Share on other sites More sharing options...
Deckbuild 6th Gear November 1, 2012 Share November 1, 2012 Was driving somewhere in Jurong and all of a sudden inside the car sells of chemical. the smell lingers inside for quite sometime. I believe my car is not air tight and air with funny smell leaks in. Anyway to improve the seal? or it only happens to older cars? if i make love inside car will i die of poisoning? What you can do is shut off the air con completely when u smell something funny or u can see smog infront of you. Link to post Share on other sites More sharing options...
Simon29 Neutral Newbie November 1, 2012 Share November 1, 2012 I guess some cars are really air tight. Because I know some high end cars have designed one way valves to allow air to escape, to allow the door to shut properly. Some cars even lowered the windows slightly, to alow the door to shut properly too. If one sleep in such cars without the aircon on or windows open, I think the CO level will rise easily and kill the driver. Especcially in winter/autumn times, where no air is required, the long distance driver could be deadly. But I believe, the breath moisture will fog up the windshield, and the driver is naturally 'forced' to lower the windows occasionally to equalize the inside air to reduce fogging. Thereby reducing the risk of high level CO in such air tight cars! Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 1, 2012 Share November 1, 2012 I guess some cars are really air tight. Because I know some high end cars have designed one way valves to allow air to escape, to allow the door to shut properly. Some cars even lowered the windows slightly, to alow the door to shut properly too. If one sleep in such cars without the aircon on or windows open, I think the CO level will rise easily and kill the driver. Especcially in winter/autumn times, where no air is required, the long distance driver could be deadly. But I believe, the breath moisture will fog up the windshield, and the driver is naturally 'forced' to lower the windows occasionally to equalize the inside air to reduce fogging. Thereby reducing the risk of high level CO in such air tight cars! The only car in the world I know is air tight is this : Link to post Share on other sites More sharing options...
Jman888 Moderator November 1, 2012 Share November 1, 2012 must dive into water see whether it leak or not?? :huh: Link to post Share on other sites More sharing options...
R_aquarii 1st Gear November 4, 2012 Share November 4, 2012 The only car in the world I know is air tight is this : this car also need to pay toll? Link to post Share on other sites More sharing options...
Celina29 Neutral Newbie November 6, 2012 Share November 6, 2012 There are several ways to know if you have an airtight car and none of them are pleasant. That's because the passenger compartment of your car is not designed to be airtight. So its difficult both the ways. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear November 6, 2012 Share November 6, 2012 The only car in the world I know is air tight is this : max speed 60mph only? Link to post Share on other sites More sharing options...
Btwl Clutched November 6, 2012 Share November 6, 2012 Another car which is probably air tight -- James Bond's Lotus Esprit submarine car Link to post Share on other sites More sharing options...
Donut Supercharged November 6, 2012 Share November 6, 2012 Was driving somewhere in Jurong and all of a sudden inside the car sells of chemical. the smell lingers inside for quite sometime. I believe my car is not air tight and air with funny smell leaks in. Anyway to improve the seal? or it only happens to older cars? if i make love inside car will i die of poisoning? U think your car is a space shuttle cabin? Air tight? First, your back seat and car boot area is not air tight. Secondly, all your doors are not air tight. Thirdly, your air con system is not air tight. How to get fresh air if the car is totally 100% vacuum air tight?? Link to post Share on other sites More sharing options...
Masjojon Neutral Newbie November 6, 2012 Share November 6, 2012 I agree with Jordanplus Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 7, 2012 Share November 7, 2012 max speed 60mph only? I dont know, have yet to driven one or be driven in one. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - December 2024
Used Car, what STA Inspection grade then can buy?
Xiaomi EV is Coming
Xiaomi EV is Coming
Our car community ❤️🚗
Join us on a curated driving adventure for car enthusiasts! 🚗 Sgcarmart Adventures: Car Factories from Past to Present - 24 November 2024
