Vulcann 6th Gear October 31, 2012 Share October 31, 2012 $50 cam, reasonable. 一分钱, 一分货. ↡ Advertisement Link to post Share on other sites More sharing options...
Afiyy Neutral Newbie October 31, 2012 Share October 31, 2012 Fiited this cam on my rear: Though can roughly make out the VRN of vehicles behind, it is not very clear as the rear windscreen is forever dirty. Hi, http://list.qoo10.sg/gmkt.inc/Goods/Goods....scode=407391553 Is that how the rear cam look like for the particular model as above? Thanks hope u can reply asap Link to post Share on other sites More sharing options...
Vulcann 6th Gear October 31, 2012 Share October 31, 2012 Hi, http://list.qoo10.sg/gmkt.inc/Goods/Goods....scode=407391553 Is that how the rear cam look like for the particular model as above? Thanks hope u can reply asap No mine was a single cam mouted at the rear while what you have here is a 2 channel. But the chasis seems to be the same. Link to post Share on other sites More sharing options...
Afiyy Neutral Newbie October 31, 2012 Share October 31, 2012 Oh i see thanks. Because I'm looking for DVR which have 2 lens that can record behind too. Apparently Rodis is one of the choice but theres no sample video of the rear cam . HAHAH ! Link to post Share on other sites More sharing options...
Zniper 2nd Gear October 31, 2012 Share October 31, 2012 alamak... thanks bro... :) wonder how to self install and pull the cables to the rear... Link to post Share on other sites More sharing options...
Boo_saa Neutral Newbie October 31, 2012 Author Share October 31, 2012 alamak... thanks bro... :) wonder how to self install and pull the cables to the rear... Wiring should be quite simple. I did my front ,nicely concealed. Rear I guess just run via the top panel all the way to the rear. Btw the charger provided not very lasting. And also can feel that the power supply not very stable. some time can auto off some time cAnt,Less then a week up lorry leow, think the fuse can't take it. Now I running via my head unit USB feel much more stable. Link to post Share on other sites More sharing options...
Vulcann 6th Gear October 31, 2012 Share October 31, 2012 alamak... thanks bro... :) wonder how to self install and pull the cables to the rear... This part tough... Mine everything I DIY after consulting with bro Adrianli who is the undisputed guru of car cams Link to post Share on other sites More sharing options...
Vulcann 6th Gear October 31, 2012 Share October 31, 2012 Wiring should be quite simple. I did my front ,nicely concealed. Rear I guess just run via the top panel all the way to the rear. Btw the charger provided not very lasting. And also can feel that the power supply not very stable. some time can auto off some time cAnt,Less then a week up lorry leow, think the fuse can't take it. Now I running via my head unit USB feel much more stable. Top panel via A-frame? Not long enough for me and mine is a Axio not lux car. Ended up I ran it from the ciggy splitter through in between the front seats (underneath), along floor mat, then under the rear seats and upturn through in-between the rear seat back rest and tisse box/umbrella panel support, via the hind A-frame and then finally on the top of the rear windscreen. Cable was just enough [sweatdrop] Link to post Share on other sites More sharing options...
Vulcann 6th Gear November 2, 2012 Share November 2, 2012 Oh i see thanks. Because I'm looking for DVR which have 2 lens that can record behind too. Apparently Rodis is one of the choice but theres no sample video of the rear cam . HAHAH ! OK here is sample of this cam as a rear facing device in my ride around evening time: Like mentioned earlier maybe because my rear windscreen dirty so the effect not that impressive. In addition it was evening time when the lighting condition was less than ideal even with street lights. Cannot really make out the VRNs.. Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 2, 2012 Share November 2, 2012 OK here is sample of this cam as a rear facing device in my ride around evening time: Like mentioned earlier maybe because my rear windscreen dirty so the effect not that impressive. In addition it was evening time when the lighting condition was less than ideal even with street lights. Cannot really make out the VRNs.. Its normal, cos we cannot install rear headlights. Link to post Share on other sites More sharing options...
Vulcann 6th Gear November 2, 2012 Share November 2, 2012 OK here is sample of this cam as a rear facing device in my ride around evening time: Like mentioned earlier maybe because my rear windscreen dirty so the effect not that impressive. In addition it was evening time when the lighting condition was less than ideal even with street lights. Cannot really make out the VRNs.. Again compare this to my front BV around the same time: Difference very obvious because one is HD and the other a full HD. Link to post Share on other sites More sharing options...
Auto_emocion 2nd Gear November 2, 2012 Share November 2, 2012 OK here is sample of this cam as a rear facing device in my ride around evening time: Like mentioned earlier maybe because my rear windscreen dirty so the effect not that impressive. In addition it was evening time when the lighting condition was less than ideal even with street lights. Cannot really make out the VRNs.. Bro, cars behind u are turning on their headlights shining into your camera, I believe u will be blinded by the headlamp beams if you look back, similarly the camera will not be able to make up the VRN unless u have rear lamps fitted. What is most important, capturing the footage of the vehicles surrounding u. Link to post Share on other sites More sharing options...
Vulcann 6th Gear November 2, 2012 Share November 2, 2012 (edited) Bro, cars behind u are turning on their headlights shining into your camera, I believe u will be blinded by the headlamp beams if you look back, similarly the camera will not be able to make up the VRN unless u have rear lamps fitted. What is most important, capturing the footage of the vehicles surrounding u. Agree. The rear cam is really for daytime operations. Under poor lighting conditions or during nightime it just serves as a general device to capture footages (even if it is fuzzy) and not VRNs. Edited November 2, 2012 by Vulcann Link to post Share on other sites More sharing options...
Berncsp76 6th Gear November 2, 2012 Share November 2, 2012 haha now 2CH group buy revert back to $90 from $72.90. The other seller going at $45 group buy...maybe can buy 2 same units and put front and back... Am rather interested in the PIP feature though...now headache is the wiring portion... Link to post Share on other sites More sharing options...
Boo_saa Neutral Newbie November 2, 2012 Author Share November 2, 2012 just to share http://www.mycarforum.com/index.php?showto...t&p=4659788 Link to post Share on other sites More sharing options...
Afiyy Neutral Newbie November 2, 2012 Share November 2, 2012 Rodis Dvr using TF CARD. what is TF card? is it SD Card or micro Sd ? Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear November 2, 2012 Share November 2, 2012 Rodis Dvr using TF CARD. what is TF card? is it SD Card or micro Sd ? they are the same thing Link to post Share on other sites More sharing options...
Boo_saa Neutral Newbie November 2, 2012 Author Share November 2, 2012 Rodis Dvr using TF CARD. what is TF card? is it SD Card or micro Sd ? It's micro sd.. I also lost when it mention TF,, ↡ Advertisement Link to post Share on other sites More sharing options...
W212 owners, please check-in
Toyota Corolla AE86 Revival! Initial D Fans COME IN!
Attention all Duragloss #951 Aquawax user.
Migrating down under? Come share your experiences
Peugeot Owner please come in..
Mazda Rx8 owners..pls come in
