Honk sometimes work sometimes not
Shor
Bro what talking you?
seems like your car recently got quite a few issues. Is it possible there is a background issue causing all these problems? My guess is that you are not longer servicing at Tan Chong. How about going back to do a diagnostics?
Bro, Nissan right?
Could be the module in the steering wheel which houses the terminals for horn, signal, cruise control etc.
That's what happen to my friend's cefiro.
Youre right bro, you seems know me quite well leh [cool]
Bro, Nissan right?
Yes Bro burger, Nissan.....
No see you in futsal nowadays?
CONCLUSION
All the above not correct
Theres a spiral coil in the Airbag causing the problem.
CONCLUSION
thats the thing. That piece of spiral coil has all the terminals that connects all fixtures on the steering wheels.
Proly has to replace the whole unit which cost less than 200
Exactly it's solved DIY.
It's the "Spiral Coil" in the steering worn out.
wiring or horn spoilt...cheap...
It's the spiral coil which connect all the wiring for the Audio, Signal and horn. Buy the whole thing from retail and DIY.
Costing not more than $200.
So not water go in horn, not relay problem .IMO :D
I don't encourage DIY as there is a sequence in installation and the attachment can only be taken out when installation is in placed. Failing to do so will render the new part useless.
I saw how it was done on the cefiro and .. :wacko:
But this issue very clear cut, open, install, closed.
The spiral thingy is secured with an attachment that can only be taken out after installation. DO NOT unsecure it when taken out from the box when new.
