ITB100HD feedback
Refresher76
All Korean wordings leh....
each model will have 3 files available for download, 1 of them will have English words "PC Player" in the name, that's pretty self-explanatory. Of the other 2, 1 will be in PDF format, so that's the manual (it's in Korean, so not much use, but you don't really need it anyway), which leaves that last file the firmware (which will be in zip format).
Not too hard to decipher. Either that, or you open in Chrome, and click on the "Translate" pop-up.
put the folder in the sd card or open the folder and copy the 4 files in?
Mine is ver 1.3 so no need update?
Edited by Axela525
if you are referring to updating of firmware, if I remember correctly, copy the .bin file to the root directory of the SD card, and put it back into the camera and power it up to update. you will have to re-do the settings after a firmware update if I'm not wrong, so don't be alarm if the camera switches back to Korean language.
if you are using the ITB-100HDSP model, then v1.3 is already the latest.
Edited by Wacko
Ok...its latest...will let the GPS lock in 1st ...now setting in Korea..time also different...thks! I lost the voice...so was trying to get back but I think cannot...sian!
Are you using PC Player v1.4.0? I think you have to use that with firmware v1.3
[sunny]
did it work? I think you will need to have the SD card access by the computer with PC Player 1.4.0 installed, and the settings saved by adjusting within PC Player will captured onto the SD card, and enabled within the camera when it loads the same SD card.
still cannot...always korean time zone. Tonite i chk my PC version. Thks. Now
is 1hr ahead.
Hi thks fr advise.i changed two cards already n ir seems tt it damaging my cards.
Now my both SD Cards got problem already.
One card cannot be reformat no matter what method I use. Even I go to my drive management n do slow format it can't be reformat
The other card (F:/ example) jus appear on my computer fr split second n disappear. Drive doesnt appear on computer after that.
Are you using a SD or a micro SD? I have experienced this problem twice. Both times it was due to faulty memory card. Do note that the adapter for microSD can also be faulty. Hence, remember to change the adapter too! Hope it helps.
As long as nt camera die ok la..jus nw I try installing the card again.."record" for 15min let me hear techno sound again ( beep beep beep beep)..zzz
Will go buy an adaptor n try. Thks all. Anyway my sd card got so call lifetime wrty.. Bought frm simlim..
I agreed with u.
when I used those microSD card with adapter, it also gave me problem.
