Deckbuild 6th Gear November 8, 2012 Share November 8, 2012 Was wondering able to run at dash and install it beside the ERP unit. ↡ Advertisement Link to post Share on other sites More sharing options...
Jtb 6th Gear November 8, 2012 Share November 8, 2012 (edited) On 11/8/2012 at 8:28 AM, Deckbuild said: Was wondering able to run at dash and install it beside the ERP unit. get down to Autobacs for 12V wire and estimate your length and hide behind the plastic trunk by peeling it slowly. Using a plastic rule to push in and lay accordingly to your requirement. RAM mount good for temperature. http://www.rammount.com/ Edited November 8, 2012 by Jtb Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 8, 2012 Share November 8, 2012 On 11/8/2012 at 8:28 AM, Deckbuild said: Was wondering able to run at dash and install it beside the ERP unit. 1) Recording angle too low, cannot cover whole front. 2) Windows might be smashed. Top of windscreen gives u better coverage. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear November 8, 2012 Share November 8, 2012 I guess I will go purchase from AD and ask them install, hopefully they provide the installation.. Link to post Share on other sites More sharing options...
Refresher76 Clutched November 8, 2012 Author Share November 8, 2012 Mine is curtain airbag covering from A to C pillar. My AD knows about it. You do not required to take out the pillar to install the cable. At least I did not see my installer, Soon Lee dismantling my pillars. Link to post Share on other sites More sharing options...
Zhutou Clutched November 8, 2012 Share November 8, 2012 On 11/8/2012 at 8:28 AM, Deckbuild said: Was wondering able to run at dash and install it beside the ERP unit. u will need the camera to shoot down best is can see ur bonnet Link to post Share on other sites More sharing options...
Patience Clutched November 9, 2012 Share November 9, 2012 On 10/28/2012 at 1:08 PM, Refresher76 said: At the same time, I requested Soon Lee Auto to transfer my DOD-tec V660II from my front windscreen to the rear. Of course another $30 spent. Bro refresher76, where do they tap the power of ur rear camera from? Link to post Share on other sites More sharing options...
Colourblind Clutched November 9, 2012 Share November 9, 2012 Bro, Any difference if pair up ITB-100HD + Power Magic or ITB-100HD + IVT-80? Link to post Share on other sites More sharing options...
Refresher76 Clutched November 9, 2012 Author Share November 9, 2012 On 11/9/2012 at 4:03 AM, Patience said: Bro refresher76, where do they tap the power of ur rear camera from? I've a rear ciggy socket at my boot. Soon Lee tap the source from there. Link to post Share on other sites More sharing options...
Patience Clutched November 9, 2012 Share November 9, 2012 On 11/9/2012 at 6:19 AM, Refresher76 said: I've a rear ciggy socket at my boot. Soon Lee tap the source from there. I doubt my car has it......may I know wat car ur driving? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 9, 2012 Share November 9, 2012 On 11/9/2012 at 4:55 AM, Colourblind said: Bro, Any difference if pair up ITB-100HD + Power Magic or ITB-100HD + IVT-80? basically both works as uninterupt power. i did my own wiring for front and rear. Front using ITB100HD with IVT-80. Rear using a dual camera with power magic. Conceal the wiring myself go sim lim buy wires and climping tool. Settle all in 45mins job. Link to post Share on other sites More sharing options...
Refresher76 Clutched November 9, 2012 Author Share November 9, 2012 On 11/9/2012 at 7:09 AM, Patience said: I doubt my car has it......may I know wat car ur driving? SUV Link to post Share on other sites More sharing options...
Colourblind Clutched November 9, 2012 Share November 9, 2012 On 11/9/2012 at 8:32 AM, MkMan said: basically both works as uninterupt power. i did my own wiring for front and rear. Front using ITB100HD with IVT-80. Rear using a dual camera with power magic. Conceal the wiring myself go sim lim buy wires and climping tool. Settle all in 45mins job. I tihink i read from some where IVT-80 if detect battery voltage 11.8V will cut off as where power magic is around 12V or 12.2V..... Please correct me if i am wrong as i am not a technical guy....... Link to post Share on other sites More sharing options...
Tayyw76 Neutral Newbie November 9, 2012 Share November 9, 2012 On 11/9/2012 at 12:00 PM, Colourblind said: I tihink i read from some where IVT-80 if detect battery voltage 11.8V will cut off as where power magic is around 12V or 12.2V..... Please correct me if i am wrong as i am not a technical guy....... IVT-80 has 3 settings - 11.8V, 12V and 12.2V whereas power magic pro has 2 settings - 11.8V and 12V... Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 9, 2012 Share November 9, 2012 On 11/9/2012 at 12:00 PM, Colourblind said: I tihink i read from some where IVT-80 if detect battery voltage 11.8V will cut off as where power magic is around 12V or 12.2V..... Please correct me if i am wrong as i am not a technical guy....... Power magic also can set la.. where u get the info that power magic cut off at 12V or 12.2V? Link to post Share on other sites More sharing options...
Patience Clutched November 9, 2012 Share November 9, 2012 On 11/9/2012 at 9:38 AM, Refresher76 said: SUV my car dont have plug at the back....duno how they will tap power for the back camera....hmmm Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 10, 2012 Share November 10, 2012 On 11/9/2012 at 5:52 PM, Patience said: my car dont have plug at the back....duno how they will tap power for the back camera....hmmm Did they link the power magic to you rear? If yes they probably run and conceal wiring tapping the power from the interior car fuse box. Link to post Share on other sites More sharing options...
Patience Clutched November 10, 2012 Share November 10, 2012 On 11/10/2012 at 1:22 AM, MkMan said: Did they link the power magic to you rear? If yes they probably run and conceal wiring tapping the power from the interior car fuse box. i asked soon lee today. ..they will run a cigarette plug to the back for the rear Cam. my front Cam is itronics....thinking of getting a DOD Cam during sitex for the rear. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
How to feedback on hospital service?
Anyone have invested in SSB?
Feedback on hazard
Feedback on hazard
Cannot post an Ad
Cannot post an Ad
Any feedback on castlewoodgroup?
VW Tiguan 2011-2012 feedback
Feedback for Additional Rear Aircon Installed
