Jamessoh Neutral Newbie October 21, 2012 Share October 21, 2012 hi, i noticed internal misting in one of my headlights after a heavy downpour. I checked the headlights. no sign of crack or damage. I am afraid to disassemble the headlights to check in internal seals for fear that i may cause more damage as i am not a technical person. is there any place anyone can recommend to fix this problem? many thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
RageX 1st Gear October 21, 2012 Share October 21, 2012 Did you check the cap inside the hood? Link to post Share on other sites More sharing options...
Mockngbrd Supersonic October 21, 2012 Share October 21, 2012 Drill a hole Link to post Share on other sites More sharing options...
Rustyz 5th Gear October 21, 2012 Share October 21, 2012 Can sun it or use hair dryer to remove Moisture? Link to post Share on other sites More sharing options...
Watwheels Supersonic October 21, 2012 Share October 21, 2012 (edited) Did you change the bulbs to aftermarket ones? Try switching back to stock or original ones. Aftermarket bulbs might not have the same seal as the original ones. To remove the condensation just unplug the bulbs thus leaving a big hole, on the engine and let the heat dry up the moisture. Edited October 21, 2012 by Watwheels Link to post Share on other sites More sharing options...
Gdspd08 2nd Gear October 21, 2012 Share October 21, 2012 (edited) Change headlight. It will come back no matter wat. I have this issue on my previous Lancer. I even ask technician to put silicon to seal up every possible area. Still no use. Change headlight resolve all issue. Edited October 21, 2012 by Gdspd08 Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 21, 2012 Share October 21, 2012 hi, i noticed internal misting in one of my headlights after a heavy downpour. I checked the headlights. no sign of crack or damage. I am afraid to disassemble the headlights to check in internal seals for fear that i may cause more damage as i am not a technical person. is there any place anyone can recommend to fix this problem? many thanks. What car u drive? BMW its a common problem. Chk e venting hole not blocked or e rubber tube pointing down. Just use as normal n e heat of main bulb wil dry it off. Or cud b when it cools it draw cool air in n moisture condense inside. As long as cn use just use. Its not a serious problem. Link to post Share on other sites More sharing options...
Tarquin 1st Gear October 21, 2012 Share October 21, 2012 hi, i noticed internal misting in one of my headlights after a heavy downpour. I checked the headlights. no sign of crack or damage. I am afraid to disassemble the headlights to check in internal seals for fear that i may cause more damage as i am not a technical person. is there any place anyone can recommend to fix this problem? many thanks. Quick fix...pop the bonnet...remove the rubber backing and unplug the socket from the affected headlight...leave it overnight to let the headlight "breath"...the following day mist should be out...but not a permanent solution...either micro cracks or gaps in the headlight assy.. Link to post Share on other sites More sharing options...
Cba6p 1st Gear October 21, 2012 Share October 21, 2012 hi, i noticed internal misting in one of my headlights after a heavy downpour. I checked the headlights. no sign of crack or damage. I am afraid to disassemble the headlights to check in internal seals for fear that i may cause more damage as i am not a technical person. is there any place anyone can recommend to fix this problem? many thanks. izzit a Ford? If yes, then it's chronic issue...no cure. Link to post Share on other sites More sharing options...
Jtb 6th Gear October 29, 2012 Share October 29, 2012 hi, i noticed internal misting in one of my headlights after a heavy downpour. I checked the headlights. no sign of crack or damage. I am afraid to disassemble the headlights to check in internal seals for fear that i may cause more damage as i am not a technical person. is there any place anyone can recommend to fix this problem? many thanks. if you have changed bulb, old ring dont sit properly and during dowpour left over water under shelter not dry, condensation take place. ↡ Advertisement Link to post Share on other sites More sharing options...
Are LED lights subject to brightness checks?
2009 hyundai avante HD
Car travelling without headlight on
Brighter headlights needed
H7 LED Headlight bulbs
Condensation in headlight(s)
Headlights turn yellowish
