Hosaybo 6th Gear December 7, 2024 Share December 7, 2024 Old topic but something we dealt we in this high humidity country..... Anyone bought those blower or install toilet ventilator for your toilet to get rid of the humidity? Any feedback on the brand or type of blower you use. Thanks in advance. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
13177 Hypersonic December 7, 2024 Share December 7, 2024 Open the window in the toilet doesn’t help? Link to post Share on other sites More sharing options...
serenade 6th Gear December 7, 2024 Share December 7, 2024 KDK or Mistral, with preference for KDK. 1 Link to post Share on other sites More sharing options...
BanCoe Hypersonic December 7, 2024 Share December 7, 2024 Some of the new condos …… some of the bathroom got no window even ….. just a ventilator fan which God knows only blows out nowhere Link to post Share on other sites More sharing options...
Volvobrick Hypersonic December 7, 2024 Share December 7, 2024 On 12/7/2024 at 2:22 PM, Hosaybo said: Old topic but something we dealt we in this high humidity country..... Anyone bought those blower or install toilet ventilator for your toilet to get rid of the humidity? Any feedback on the brand or type of blower you use. Thanks in advance. Forced ventilation is very important. Just go for KDK wall mounted. 25cm or 30cm for bigger rooms. Very effective to cool down even whole house. 6 Link to post Share on other sites More sharing options...
Kb27 Supersonic December 7, 2024 Share December 7, 2024 On 12/7/2024 at 2:22 PM, Hosaybo said: Old topic but something we dealt we in this high humidity country..... Anyone bought those blower or install toilet ventilator for your toilet to get rid of the humidity? Any feedback on the brand or type of blower you use. Thanks in advance. I have a KDK ventilation fan in my toilet, used for many years already. But the frame is rusting due to all the moisture. Need some maintenance to oil, lubricate the hinge, but I sort of lazy. 😀 To install the fan, I remove some of the glass panels of the window and added a panel to fix the fan. Now, I have a moisture detector powered switch. I set the limit on when the switch is on and off, which regulates the fan on/off. 5 Link to post Share on other sites More sharing options...
Hosaybo 6th Gear December 7, 2024 Share December 7, 2024 On 12/7/2024 at 7:16 PM, Kb27 said: I have a KDK ventilation fan in my toilet, used for many years already. But the frame is rusting due to all the moisture. Need some maintenance to oil, lubricate the hinge, but I sort of lazy. 😀 To install the fan, I remove some of the glass panels of the window and added a panel to fix the fan. Now, I have a moisture detector powered switch. I set the limit on when the switch is on and off, which regulates the fan on/off. You diy? Was rec the kdk to be mounted on an acrylic sheet to seal up the window with the power linked to the light switch. Link to post Share on other sites More sharing options...
Kb27 Supersonic December 7, 2024 Share December 7, 2024 On 12/7/2024 at 10:27 PM, Hosaybo said: You diy? Was rec the kdk to be mounted on an acrylic sheet to seal up the window with the power linked to the light switch. Yes, I diy. Acrylic sheet would be nice. You'll need to measure and cut. Power can be link to light switch, but it also means they don't work independently, unless you put another switch. As mine is hdb, with louver glass panel, I remove a few pcs of glass and the alum panel, then reverse it to mount the fan. Later found some acrylic pieces, (from fridge) someone threw away, and stick them on. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
JEM/Westgate ceiling collapse!
Toilet ceiling leaking
Ceiling fan
Ceiling fan
Buying Ceiling fan and lighting from JB
Ceiling Fan in Car
Ceiling Fan in Car
Small little tiny bug on walls & ceiling
Help: ceiling n wall cracks are leaking water
