supersen 1st Gear January 21, 2018 Share January 21, 2018 just change to amaron 85D23L at Rotor Auto Electrical for $95 at promo price hope it will last for 2.5 years min ↡ Advertisement Link to post Share on other sites More sharing options...
Alessiahayden February 1, 2018 Share February 1, 2018 Amaron battery is good for your car. You can go with this battery. 1 Link to post Share on other sites More sharing options...
Mcmilan Neutral Newbie March 2, 2018 Share March 2, 2018 There are 2 types. 85D23L - L = left 85D23R - R = right The difference is the position of the positive and negative post. Most cars are using L. A few use R. Kb27, can u pm yr number to me. Tks Link to post Share on other sites More sharing options...
Terratoss 1st Gear March 6, 2018 Share March 6, 2018 No more amaron for me. All died within 1.5-1.8 yrs. When died, didnt even give warning, just happily up lorry when it felt like it. Link to post Share on other sites More sharing options...
Sotong1977 4th Gear March 14, 2018 Share March 14, 2018 My Amaron died on me after 6mths. Car connected to carcam setup with parking mode. Still poor considering the stock battery lasted 1yr with same setting. Link to post Share on other sites More sharing options...
kdash Supersonic March 14, 2018 Share March 14, 2018 No more amaron for me. All died within 1.5-1.8 yrs. When died, didnt even give warning, just happily up lorry when it felt like it. did the voltage drop along the way? Link to post Share on other sites More sharing options...
Fitvip Supersonic March 14, 2018 Share March 14, 2018 (edited) My Amaron died on me after 6mths. Car connected to carcam setup with parking mode. Still poor considering the stock battery lasted 1yr with same setting. I thought Amaron provides 12 months' warranty? Btw, first time using Amaron. It has been 51 months. When it was about 4 years old, I left the car parked for 9 days. On my return, it was still OK! Edited March 14, 2018 by Fitvip Link to post Share on other sites More sharing options...
Earthboy 4th Gear March 14, 2018 Share March 14, 2018 4 years!! power lar I thought Amaron provides 12 months' warranty? Btw, first time using Amaron. It has been 51 months. When it was about 4 years old, I left the car parked for 9 days. On my return, it was still OK! Link to post Share on other sites More sharing options...
Sotong1977 4th Gear March 14, 2018 Share March 14, 2018 I thought Amaron provides 12 months' warranty? Btw, first time using Amaron. It has been 51 months. When it was about 4 years old, I left the car parked for 9 days. On my return, it was still OK! Forgot about the warranty. Is your car connected to carcam? Maybe there are good n bad batches of amaron batteries. If tats the case then its a matter of poor quality control i.e. wider quality threshold for lower retail price Link to post Share on other sites More sharing options...
Optramagnum 6th Gear March 14, 2018 Share March 14, 2018 (edited) When install cam to use parking mode function and tapped to car battery, ensure it can auto shut down when battery drop to certain voltage. I set mine for 12.2V and sensitivity to impact to low, otherwise it will keep recording during heavy rain. I also realised the parking mode is getting shorter and shorter. Battery can't hold the charge as long as before, after 18mths of usage. Edited March 14, 2018 by Optramagnum Link to post Share on other sites More sharing options...
Terratoss 1st Gear March 14, 2018 Share March 14, 2018 did the voltage drop along the way? I dont have a volt meter in car but u do see the difference during cranking. But after a day or 2, up lorry. I thought Amaron provides 12 months' warranty? Btw, first time using Amaron. It has been 51 months. When it was about 4 years old, I left the car parked for 9 days. On my return, it was still OK! wow. thats should go into their Guinness book of records. Link to post Share on other sites More sharing options...
Sotong1977 4th Gear March 14, 2018 Share March 14, 2018 When install cam to use parking mode function and tapped to car battery, ensure it can auto shut down when battery drop to certain voltage. I set mine for 12.2V and sensitivity to impact to low, otherwise it will keep recording during heavy rain. I also realised the parking mode is getting shorter and shorter. Battery can't hold the charge as long as before, after 18mths of usage.Mine has auto shutdown setup as what you mentioned. No warning and battery just died Link to post Share on other sites More sharing options...
kdash Supersonic March 14, 2018 Share March 14, 2018 I dont have a volt meter in car but u do see the difference during cranking. But after a day or 2, up lorry. wow. thats should go into their Guinness book of records. waa a day or 2 only. dont even allow you to reach the weekend to check the car... Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear March 14, 2018 Share March 14, 2018 just changed to bosch S4 battery for my civic. last amaron bat lasted 1.5 years. Link to post Share on other sites More sharing options...
DACH Supersonic March 19, 2018 Share March 19, 2018 just changed to bosch S4 battery for my civic. last amaron bat lasted 1.5 years. I've just changed to a Bosch battery too. Hope that it will last. Link to post Share on other sites More sharing options...
Kb27 Supersonic March 19, 2018 Share March 19, 2018 My Amaron died on me after 6mths. Car connected to carcam setup with parking mode. Still poor considering the stock battery lasted 1yr with same setting. Your carcam sucked battery power in parking mode. When enough juice is taken from the battery, it goes flat. When it's flat it cannot start the engine until it's charged full again. It's not right to compare a flat battery, no matter what is the brand. A flat battery is always a problem with those using their carcam in parked mode. But they insist on using it, as it is their rights. I say, if you insist, get ready for a flat battery. 3 Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear March 27, 2018 Share March 27, 2018 I've just changed to a Bosch battery too. Hope that it will last. you running 24/7 cam recording? Link to post Share on other sites More sharing options...
DACH Supersonic March 27, 2018 Share March 27, 2018 you running 24/7 cam recording?No, but with motion sensor. ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
Battery Voltage up & down
Request for dark mode
