Typhoonz 4th Gear August 15, 2012 Author Share August 15, 2012 cheap leh.........and since all W30 and same brand.............mix lah.......... Have to... If not gotta go back to Amsoil to buy again... ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 15, 2012 Share August 15, 2012 W50+W30= W40.............. i always top up with diff oil. Makes no diff as all will smoke out anyway....... Link to post Share on other sites More sharing options...
Tohto Hypersonic August 15, 2012 Share August 15, 2012 How's the FC and performance? Normal? Just that my ride is more than 100K already. That's why I mix with 0w30 & 0w40. FC I don't seems much different. Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 15, 2012 Author Share August 15, 2012 W50+W30= W40.............. i always top up with diff oil. Makes no diff as all will smoke out anyway....... Now have 5W50 mineral oil in my engine to "clean" it... Will do the change tomorrow... Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 15, 2012 Author Share August 15, 2012 Just that my ride is more than 100K already. That's why I mix with 0w30 & 0w40. FC I don't seems much different. Mine's just past 100K too... Half tank usually is about 300km... Link to post Share on other sites More sharing options...
Duskyoa Neutral Newbie August 22, 2012 Share August 22, 2012 basically the front number is the starting temperature. Will not have effect. The behind is the density of the engine oil. Mixing the same number should be okay Link to post Share on other sites More sharing options...
Showtime Neutral Newbie August 22, 2012 Share August 22, 2012 (edited) basically the front number is the starting temperature. Will not have effect. The behind is the density of the engine oil. Mixing the same number should be okay the front number is not starting temperature. its winter viscosity. Hence 'W'. dont bother with that number here in sunny singapore. if you want to be picky, choose the highest W number as it will have less thinning additives, which are not required anyway. also, its viscosity. not density. viscosity is the reluctance of a fluid to flow. while density is its weight per unit volume. 2 very different things. Edited August 22, 2012 by Showtime Link to post Share on other sites More sharing options...
Duskyoa Neutral Newbie August 22, 2012 Share August 22, 2012 the front number is not starting temperature. its winter viscosity. Hence 'W'. dont bother with that number here in sunny singapore. if you want to be picky, choose the highest W number as it will have less thinning additives, which are not required anyway. also, its viscosity. not density. viscosity is the reluctance of a fluid to flow. while density is its weight per unit volume. 2 very different things. I was trying to be as layman as possible so that it will be easier to digest. Link to post Share on other sites More sharing options...
Ckchong8 1st Gear August 22, 2012 Share August 22, 2012 The main bulk will be 0W30 and top up is 5W30... Went to Amsoil last week as they have their offer for 1GL SSO 0W30 going for $56... No offer for 5W30 as I think most would take this grade... Bro. where to get Amsoil EO ? Thks Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 23, 2012 Author Share August 23, 2012 Bro. where to get Amsoil EO ? Thks http://amsoil-sg.blogspot.sg/ Link to post Share on other sites More sharing options...
Ckchong8 1st Gear January 22, 2013 Share January 22, 2013 http://amsoil-sg.blogspot.sg/ Thanks! Bro ↡ Advertisement Link to post Share on other sites More sharing options...
Mileage 110k, Should use 5W30 or 5W40
5W30 or 5W40 Engine Oil Is Better For Your Car?
5w30 vs 5w40
5w30 vs 5w40
Pennzoil Ultra 5w30 Euro
10w30 or 5w30?
10w30 or 5w30?
Mobil 1 EP 5w30
Mobil 1 EP 5w30
Mobil 1 5w30 fully synthetic $15 per quart worth buying ?
Idemitsu Extreme Eco 5W30 SM/CF
