Uplinkhack 1st Gear August 5, 2012 Share August 5, 2012 Anyone knows of any in-car camera/blackbox/DVR with LCD that allows input of reverse camera (auto switch to reverse video when reverse is engaged)??? Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Uplinkhack 1st Gear August 6, 2012 Author Share August 6, 2012 nothing in the market??? Link to post Share on other sites More sharing options...
Adrianli Hypersonic August 6, 2012 Share August 6, 2012 Search for "rearview mirror DVR" in Aliexpress. U can find it there. Link to post Share on other sites More sharing options...
Adrianli Hypersonic August 6, 2012 Share August 6, 2012 Found one : http://www.aliexpress.com/product-fm/56676...holesalers.html Link to post Share on other sites More sharing options...
Uplinkhack 1st Gear August 6, 2012 Author Share August 6, 2012 On 8/6/2012 at 1:19 AM, Adrianli said: Found one : http://www.aliexpress.com/product-fm/56676...holesalers.html thanks for the reply, but not very keen on rearview mirror clip on type (use visor frequently). would prefer an external screen kind. Link to post Share on other sites More sharing options...
Adrianli Hypersonic August 6, 2012 Share August 6, 2012 On 8/6/2012 at 5:07 AM, Uplinkhack said: thanks for the reply, but not very keen on rearview mirror clip on type (use visor frequently). would prefer an external screen kind. Hur??? Normal in-car dvr screen are usually only 2.5", not good candidate for use as rearview parking camera leh. Cannot see clearly. Another one would be look for those GPS navigator that come with DVR and AV-in. Search in Aliexpress. Link to post Share on other sites More sharing options...
Uplinkhack 1st Gear August 6, 2012 Author Share August 6, 2012 On 8/6/2012 at 6:27 AM, Adrianli said: Hur??? Normal in-car dvr screen are usually only 2.5", not good candidate for use as rearview parking camera leh. Cannot see clearly. Another one would be look for those GPS navigator that come with DVR and AV-in. Search in Aliexpress. found that Marbella 610XT and garmin 2565r has what i need. don't need the GPS function though. oh well Link to post Share on other sites More sharing options...
Cybertech 4th Gear August 8, 2012 Share August 8, 2012 On 8/8/2012 at 2:30 AM, Uidyn said: Have u found one? Is this you need? http://www.beltal.com/on-sale/free-express...td-47601-266987 which or what type of dvr can be go with this one? Link to post Share on other sites More sharing options...
BoneStock 5th Gear February 21, 2017 Share February 21, 2017 hi guys, Anyone knows where the red/black cable should be connected to? The bunch of cable has 3 ends. - one jack connected to rear camera - one jack connected to the front camera - but there is a red/black cable (circled in blue) that i don't know where it should go to. It comes with a manual which is not helpful at all. much appreciate any help in advance. 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic February 21, 2017 Share February 21, 2017 On 2/21/2017 at 11:04 AM, BoneStock said: hi guys, Anyone knows where the red/black cable should be connected to? The bunch of cable has 3 ends. - one jack connected to rear camera - one jack connected to the front camera - but there is a red/black cable (circled in blue) that i don't know where it should go to. It comes with a manual which is not helpful at all. much appreciate any help in advance. Goes to a cig plug or battery or power magic pro device. Link to post Share on other sites More sharing options...
BoneStock 5th Gear February 21, 2017 Share February 21, 2017 On 2/21/2017 at 11:46 AM, Adrianli said: Goes to a cig plug or battery or power magic pro device.Thanks bro. The red/black cable is only about 1m long...meaning I have find a permanent power source near the rear windscreen where the rear cam is mounted. Any power source suitable for tapping here? The normal tail light, reverse light and signal are all not on all the time. Also the box says 5V dc but the power cables in the car are all 12V right ? 2 Link to post Share on other sites More sharing options...
Adrianli Hypersonic February 21, 2017 Share February 21, 2017 On 2/21/2017 at 12:15 PM, BoneStock said: Thanks bro. The red/black cable is only about 1m long...meaning I have find a permanent power source near the rear windscreen where the rear cam is mounted. Any power source suitable for tapping here? The normal tail light, reverse light and signal are all not on all the time. Also the box says 5V dc but the power cables in the car are all 12V right ? If its 5V, get a 5V cig plug like this : https://www.aliexpress.com/item/plastic-Material-5V-Devices-Car-Charger-with-2-5mm-Plug-high-quality-charges-your-Tablet-PC/32790204525.html?spm=2114.01010208.3.185.7mCOBe&ws_ab_test=searchweb0_0,searchweb201602_3_10000073_10000077_10000074_10000167_10000175_10000069_10000068_10000062_10000063_10099_10000156_10000158_10096_10000056_10000059_10000097_10000094_10000090_10000091_10000147_10000144_10084_10000150_10083_10080_10000153_10082_10081_10110_10111_10112_10113_10114_10000089_10000086_10000083_10000135_10000080_10078_10079_10073_10070_10000140_10122_10123_10121_10126_10124_10065_10068_10501_10000132_10000033_10503_119_10000030_10000126_10000026_10000129_10000023_10000123_431_10060_10062_10056_10055_10054_10059_10000120_10000020_10000117_10000013_10103_10102_10000114_10000016_10000111_10052_10053_10050_10107_10051_10106_10000101_10000100_10000104_10000045_10000108_10000191_10000197_10000179_10000042_10000039_100003_100001_10000036_10000187-10503_10501_100001_100003,searchweb201603_3,afswitch_1,ppcSwitch_4,single_sort_1_default&btsid=1f0b3cb5-ddd9-4833-9853-71f8783acd42&algo_expid=c849900c-8730-41ad-b23b-cd9a01ab266d-23&algo_pvid=c849900c-8730-41ad-b23b-cd9a01ab266d Cut off the round pin end and connect red to red and black to black. 1 Link to post Share on other sites More sharing options...
BoneStock 5th Gear February 21, 2017 Share February 21, 2017 On 2/21/2017 at 12:25 PM, Adrianli said: If its 5V, get a 5V cig plug like this : https://www.aliexpress.com/item/plastic-Material-5V-Devices-Car-Charger-with-2-5mm-Plug-high-quality-charges-your-Tablet-PC/32790204525.html?spm=2114.01010208.3.185.7mCOBe&ws_ab_test=searchweb0_0,searchweb201602_3_10000073_10000077_10000074_10000167_10000175_10000069_10000068_10000062_10000063_10099_10000156_10000158_10096_10000056_10000059_10000097_10000094_10000090_10000091_10000147_10000144_10084_10000150_10083_10080_10000153_10082_10081_10110_10111_10112_10113_10114_10000089_10000086_10000083_10000135_10000080_10078_10079_10073_10070_10000140_10122_10123_10121_10126_10124_10065_10068_10501_10000132_10000033_10503_119_10000030_10000126_10000026_10000129_10000023_10000123_431_10060_10062_10056_10055_10054_10059_10000120_10000020_10000117_10000013_10103_10102_10000114_10000016_10000111_10052_10053_10050_10107_10051_10106_10000101_10000100_10000104_10000045_10000108_10000191_10000197_10000179_10000042_10000039_100003_100001_10000036_10000187-10503_10501_100001_100003,searchweb201603_3,afswitch_1,ppcSwitch_4,single_sort_1_default&btsid=1f0b3cb5-ddd9-4833-9853-71f8783acd42&algo_expid=c849900c-8730-41ad-b23b-cd9a01ab266d-23&algo_pvid=c849900c-8730-41ad-b23b-cd9a01ab266d Cut off the round pin end and connect red to red and black to black. thanks bro. I just charged the cam using USB to my computer. It was totally flat just now. Realised that the rear cam works even the red/black cable is left unconnected. Guess the rear cam must be drawing power from the front cam. The red/black cable is redundant then 3 Link to post Share on other sites More sharing options...
Beng2 5th Gear February 22, 2017 Share February 22, 2017 On 2/21/2017 at 1:07 PM, BoneStock said: thanks bro. I just charged the cam using USB to my computer. It was totally flat just now. Realised that the rear cam works even the red/black cable is left unconnected. Guess the rear cam must be drawing power from the front cam. The red/black cable is redundant then The red/black should be power cables (red = positive, black = ground). They are not redundant, unless you intend to keep using the built-in battery in the camera. Since you charge the cam using USB from your computer, it should be requiring 5V for normal operations. Your options: 1. Getting a 5V ciggy lighter plug and join the wires. You then plug the ciggy lighter plug into your car ciggy lighter socket 2. Hardwire it to your fuse box. As you pointed out, you need to use a 12V to 5V converter with built in fuse tap (google this). You connect the red cable to the fuse tap, and black cable to ground. No wire splicing is required to be performed on your car if you use a fuse tap. Disclaimer: information is provided solely based on writer's limited knowledge, and you do at your own risk 1 Link to post Share on other sites More sharing options...
WoRmHao 3rd Gear February 22, 2017 Share February 22, 2017 On 2/21/2017 at 11:04 AM, BoneStock said: hi guys, Anyone knows where the red/black cable should be connected to? The bunch of cable has 3 ends. - one jack connected to rear camera - one jack connected to the front camera - but there is a red/black cable (circled in blue) that i don't know where it should go to. It comes with a manual which is not helpful at all. much appreciate any help in advance. Not sure whether is it the same. Few months ago, I removed my reverse cam from my old car and place it into my new car. There's this red/black cable that is connected to my reverse light. So when reverse, the rear cam will turn on. Link to post Share on other sites More sharing options...
BoneStock 5th Gear February 23, 2017 Share February 23, 2017 On 2/22/2017 at 2:56 PM, Beng2 said: The red/black should be power cables (red = positive, black = ground). They are not redundant, unless you intend to keep using the built-in battery in the camera. Since you charge the cam using USB from your computer, it should be requiring 5V for normal operations. Your options: 1. Getting a 5V ciggy lighter plug and join the wires. You then plug the ciggy lighter plug into your car ciggy lighter socket 2. Hardwire it to your fuse box. As you pointed out, you need to use a 12V to 5V converter with built in fuse tap (google this). You connect the red cable to the fuse tap, and black cable to ground. No wire splicing is required to be performed on your car if you use a fuse tap. Disclaimer: information is provided solely based on writer's limited knowledge, and you do at your own risk good info. thanks bro On 2/22/2017 at 3:58 PM, WoRmHao said: Not sure whether is it the same. Few months ago, I removed my reverse cam from my old car and place it into my new car. There's this red/black cable that is connected to my reverse light. So when reverse, the rear cam will turn on. it's different, cos mine is a blackbox cam, so it needs power all the time whenever I am driving. for reverse cam, it only needs power when the car is reversing. ↡ Advertisement 4 Link to post Share on other sites More sharing options...
COE Bidding – Mar 2025
Car of Politician
Car of Politician
Anyone missing a car plate?
