Dumb 4th Gear July 27, 2012 Share July 27, 2012 Maybe in the near future car makers may include this as a feature. Auto disengage of transmission when going down a slope. LOL... Since now a lot of cars have this function call start/stop to help on FC why not this one? Somw in post #5 already said, no a single drop of petrol is burned if you lift off the pedal. I find that hard to understand. How could an engine be alive with a single drop of petrol. ↡ Advertisement Link to post Share on other sites More sharing options...
Watwheels Supersonic July 27, 2012 Share July 27, 2012 Somw in post #5 already said, no a single drop of petrol is burned if you lift off the pedal. I find that hard to understand. How could an engine be alive with a single drop of petrol. I forgot to put "sacarstic mode" lah. Engine still have to maintain idle rpm, fuel will still be burning. To me it makes no difference. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear July 27, 2012 Share July 27, 2012 Auto car engine brake is minimal, dosen't make much of a difference. My concern now is whether will it damage the gear transmission in the long run.. Auto car engine brake is minimal because you let it be auto, try releasing the OD button or shift it to 2 at high speed and you will feel the engine pull. Not sure about the CVT though Link to post Share on other sites More sharing options...
Felipe 3rd Gear July 27, 2012 Share July 27, 2012 Auto car engine brake is minimal, dosen't make much of a difference. My concern now is whether will it damage the gear transmission in the long run.. if u dun shift back into gear when moving, should be ok. Link to post Share on other sites More sharing options...
Happily1986 5th Gear July 27, 2012 Share July 27, 2012 A mechanic from TCM said it is not recommended to push the gear to neutral while going down slope because when you shift back to drive mode, the gears wont have enough power to shift back properly? why would you even think of slotting your gear selector into N before the vehicle descends a slope? for fuel savings? there is a good reason why N is in between R and D shift selection. N is intended to disengage the torque convertor and the gearbox if you decide to switch between R and D. especially those tims when you think it's okay to switch from R to D or vice versa when the vehicle is in motion. This is what N is meant for on the auto slushbox, not for you to freewheel your vehicle! Link to post Share on other sites More sharing options...
ER-3682 Twincharged July 27, 2012 Share July 27, 2012 Maybe in the near future car makers may include this as a feature. Auto disengage of transmission when going down a slope. LOL... Since now a lot of cars have this function call start/stop to help on FC why not this one? The lastest Porsche 911's P.D.K. already got this 'coast' function,take your leg off the throttle it auto drop to idling speed. Link to post Share on other sites More sharing options...
Terratoss 1st Gear July 27, 2012 Author Share July 27, 2012 I have been driving that way for more than 4 yrs and my mileage was 130k. No damage!!! And I had let my car roll on free gear for 7km at above 80to 130 kph a few times. hm.. ok.. what car are you driving? Link to post Share on other sites More sharing options...
Terratoss 1st Gear July 27, 2012 Author Share July 27, 2012 why would you even think of slotting your gear selector into N before the vehicle descends a slope? for fuel savings? there is a good reason why N is in between R and D shift selection. N is intended to disengage the torque convertor and the gearbox if you decide to switch between R and D. especially those tims when you think it's okay to switch from R to D or vice versa when the vehicle is in motion. This is what N is meant for on the auto slushbox, not for you to freewheel your vehicle! Yes, I agree with you but now the issue is I am not sure if it is safe to do so or will it cause any damage to the transmission. I did experiment on it before and it give me an extra 70-100km yield on my per tank mileage. So If it is proven that it does damage the transmission, I wouldnt want to do that just to strech the mileage. Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 27, 2012 Share July 27, 2012 if u dun shift back into gear when moving, should be ok. dont anyhow advice if you dont know....... putting to N while car is cruising will fry the autotrans Link to post Share on other sites More sharing options...
Deckbuild 6th Gear July 27, 2012 Share July 27, 2012 This topic have been discuss before, auto transimssion might over heated when moving in neutral. Link to post Share on other sites More sharing options...
Seanboi 1st Gear July 27, 2012 Share July 27, 2012 Yes, I agree with you but now the issue is I am not sure if it is safe to do so or will it cause any damage to the transmission. I did experiment on it before and it give me an extra 70-100km yield on my per tank mileage. So If it is proven that it does damage the transmission, I wouldnt want to do that just to strech the mileage. Shifting to N can yield you extra 70-100km of mileage?! I would not do so for safety reasons (traction) unless it is a long straight road with little traffic. Link to post Share on other sites More sharing options...
W124 Clutched September 16, 2012 Share September 16, 2012 I did try that once - shifting to Neutral when the car was in motion...but stopped when I was advised that the transmission was going to take a lot of wear and tear when I shifted back into gear with the car moving Actually if I was going down slope, I would step a little on the accelerator pedal just a bit above idling and let the car cruise. While the fuel savings may not be as great as leaving the gear in Neutral, I'm mindful that a gearbox overhaul costs thousands depending on the car model. And if the torques converter is damaged, that's a brand new unit being indented with separate freight charges. Torque converters are frequently sealed units and unlikely it can be overhauled (not in Singapore!) although I've heard some shops do cut it open and replace the bearings and gears before welding it back. How good the workmanship is is anybody's guess Link to post Share on other sites More sharing options...
Xanavi 4th Gear September 16, 2012 Share September 16, 2012 I did try that once - shifting to Neutral when the car was in motion...but stopped when I was advised that the transmission was going to take a lot of wear and tear when I shifted back into gear with the car moving Actually if I was going down slope, I would step a little on the accelerator pedal just a bit above idling and let the car cruise. While the fuel savings may not be as great as leaving the gear in Neutral, I'm mindful that a gearbox overhaul costs thousands depending on the car model. And if the torques converter is damaged, that's a brand new unit being indented with separate freight charges. Torque converters are frequently sealed units and unlikely it can be overhauled (not in Singapore!) although I've heard some shops do cut it open and replace the bearings and gears before welding it back. How good the workmanship is is anybody's guess Hope it will help enlighten those who are penny wise, pound foolish.. ↡ Advertisement Link to post Share on other sites More sharing options...
Used Car, what STA Inspection grade then can buy?
COE Bidding - December 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Our car community ❤️🚗
Join us on a curated driving adventure for car enthusiasts! 🚗 Sgcarmart Adventures: Car Factories from Past to Present - 24 November 2024
