Gilahonda Clutched July 26, 2012 Share July 26, 2012 Anyone know whats wrong? My car's aircon is now blowing hot air. Had an inkling that this happened when I went over a pot hole or I fiddled with the thermostat. Car is a Civic 1.8. Also, can recommend a good aircon workshop? Thanks in advance! ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Trafficwatch Clutched July 26, 2012 Share July 26, 2012 Possible issues:- - air compressor coil spoilt (Change around S$ 200/- pc; no need to change compressor) - discharge pipe leak @ S$ 80/- - condenser leakage or choked @ S$ 60 to S$ 250/- - cooling coil coil choked @ S$ 280 to S$ 350/- - cooling coil expansion valve spoilt @ S$ 40- - thermostat defective @ S$ 30/- Unlikely radiator cooling fan motor spoilt unless not working (Turning) 1 Link to post Share on other sites More sharing options...
Trafficwatch Clutched July 26, 2012 Share July 26, 2012 MY WS: Sunrise Auto Services Blk 15 Defu Lan 10 #01-432 (pls call before arrival - 6283 5166) Link to post Share on other sites More sharing options...
Gilahonda Clutched July 26, 2012 Author Share July 26, 2012 you own the WS or this WS you always patronise? Link to post Share on other sites More sharing options...
Gilahonda Clutched July 26, 2012 Author Share July 26, 2012 thanks bro........wonder how you know the prices.hehe Link to post Share on other sites More sharing options...
Iamtheone 1st Gear July 26, 2012 Share July 26, 2012 Blowing hot air while car stopped? Check if ur radiator fan is running or can cut in when temperature rises.. 1 Link to post Share on other sites More sharing options...
Gilahonda Clutched July 26, 2012 Author Share July 26, 2012 while on the move or stationary. aircon still blowing air w/o the coldness.catch my drift? temperature never go up so far Link to post Share on other sites More sharing options...
Iamtheone 1st Gear July 26, 2012 Share July 26, 2012 the last time when it happen to my car, it was due to my radiator fan motor kaput. Another time when happen on my colleague's car, the aircon coil choked. Link to post Share on other sites More sharing options...
5936 1st Gear July 26, 2012 Share July 26, 2012 (edited) I hope selector is not at heater. Most likely compressor failed to cut-in. Please be around and follow when mechanic check for problems. It may be a loose connector at thermostat in you case. or maybe other genuine problem. But if you leave car alone with workshop, and wait for their call, it will definately be paying for at lease a compressor. Edited July 26, 2012 by 5936 1 Link to post Share on other sites More sharing options...
Trafficwatch Clutched July 26, 2012 Share July 26, 2012 It's my regular WS since 1993 and now my company van & truck also service by Paul too. (The owner and he's always hands-on with his 2 staffs) Quite trustful and he serviced fleet of vehicles for:- - Nera Communications - Lee Wee Nasi Lemak - All Link 21 - Clean Solutions etc Link to post Share on other sites More sharing options...
Trafficwatch Clutched July 26, 2012 Share July 26, 2012 As mentioned, i with Paul since 1993 and he's price quite reasonable and around the mentioned range unless conti-cars then maybe higher and Paul will use Original parts not counter-fit unless owner preference. Link to post Share on other sites More sharing options...
Skyiet27 Clutched July 26, 2012 Share July 26, 2012 Correct! That's y I'm always with my car even for servicing for past 10 yrs Hahaha Oso can learn alot of things about my car ba 1 Link to post Share on other sites More sharing options...
Alf08 Neutral Newbie July 26, 2012 Share July 26, 2012 Anyone know whats wrong? My car's aircon is now blowing hot air. Had an inkling that this happened when I went over a pot hole or I fiddled with the thermostat. Car is a Civic 1.8. Also, can recommend a good aircon workshop? Thanks in advance! it is likely to be the magnetic clutch of the compressor kaput, it happen to me before(my previous ride is a 08 civicfd), if you can find a good aircon WS, they will probably repair for you, cost not more than $250, but more likely most WS will ask you to change the whole compressor...cost not more than $650. 1 Link to post Share on other sites More sharing options...
Dezouk Clutched July 26, 2012 Share July 26, 2012 U can try first auto at circuit link . Look for Mr yap. I done my aircon in my colt plus there. Time taken app. 3-4hours. Experienced guy . U can call before going to check price. 1 Link to post Share on other sites More sharing options...
Gilahonda Clutched July 28, 2012 Author Share July 28, 2012 last 2 days the problem got worse.it went from aircon blowing just hot air to engine became noisy to smoke coming out from bonnet so managed to go in JB and had it fixed.....total damage RM900 - parked overnite at my JB home to let car rest first before heading to WS this morning. yup, true enough, the compressor gave way.Singapore workshops quoted me SGD800 plus for compressor alone and labour. changed the aircon compressor and fan - seriously didnt know compressor kaput can cause my bonnet to spew smoke. scared shitless thought car gonna catch fire. lucky I didn't do it here in SGP...... thanks all for the leads and info!!! car is definitely ok now......cheers! Link to post Share on other sites More sharing options...
5936 1st Gear July 28, 2012 Share July 28, 2012 Gotten a seized compressor? Glad to hear that your problem is resolved. For BB cars, aircon job is definitely cheaper Was it a locally made compressor,, by Denso,sanden, or ACM? Link to post Share on other sites More sharing options...
Renegade777 5th Gear July 29, 2012 Share July 29, 2012 last 2 days the problem got worse.it went from aircon blowing just hot air to engine became noisy to smoke coming out from bonnet so managed to go in JB and had it fixed.....total damage RM900 - parked overnite at my JB home to let car rest first before heading to WS this morning. yup, true enough, the compressor gave way.Singapore workshops quoted me SGD800 plus for compressor alone and labour. changed the aircon compressor and fan - seriously didnt know compressor kaput can cause my bonnet to spew smoke. scared shitless thought car gonna catch fire. lucky I didn't do it here in SGP...... thanks all for the leads and info!!! car is definitely ok now......cheers! Is it brand new and where is it ? 1 Link to post Share on other sites More sharing options...
Eighteenjack Neutral Newbie July 29, 2012 Share July 29, 2012 last 2 days the problem got worse.it went from aircon blowing just hot air to engine became noisy to smoke coming out from bonnet so managed to go in JB and had it fixed.....total damage RM900 - parked overnite at my JB home to let car rest first before heading to WS this morning. yup, true enough, the compressor gave way.Singapore workshops quoted me SGD800 plus for compressor alone and labour. changed the aircon compressor and fan - seriously didnt know compressor kaput can cause my bonnet to spew smoke. scared shitless thought car gonna catch fire. lucky I didn't do it here in SGP...... thanks all for the leads and info!!! car is definitely ok now......cheers! Hi Gilahonda, can you share with us the JB workshop name and location you fixed your compressor and fan? I've also driving a civic 06 and need to visit them asap. Thanks in advance. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Dehumidifier recommendations
Car air-con
Car air-con
