Car camera recommendation
Pelican
56 minutes ago, BengGaBoy said:
No prob.
I have also tested Sandisk Ultra 128GB microSDXC UHS-I x2 as well. But of course, testing period is not as long as Samsung EVO.
Not too sure whether is it true, get the biggest memory size your device can support (in this case 128GB for Thinkware) so that the same spot is over-written fewer times and hopefully, the card can last much longer. No harm trying.
Ok, noted with thanks.
I saw this from Thinkware website:
How long is the lifespan of a SD card?
Please note that SD cards are consumable items. Due to the stress and build-up of bad blocks (spaces on the memory card that files can no longer be stored) due to constant overwriting cycles, SD cards typically have lifetime of 6 months to 1 year with regular formatting.
When corrupt memory cards are inserted to Thinkware Dash Cams, our dash cam continually restarts in attempt to allocate space on the card to save its files.
The dash cam may also state "Format SD card regularly for data integrity" upon each startup. Another indication that the SD card has gone corrupt is hearing the device say "Memory card error."
If you believe that the SD card is beginning to become corrupt, insert the card into your PC. If the SD card is unable to be properly formatted it is time to replace this SD card.
On 9/30/2020 at 1:17 AM, awhtc said:
70mai A800 4K Dual Dash Camera Review - GPS & WiFi
Hi. Brought a used car that pre installed with blackvue 590. But find it very troublesome as cannot view what I am taking unless plug the SD card into the computer. May I know this camera 70 Mai come with warranty? Easy to install? Come with motion detection mode when car engine off?
this was nice.
57 minutes ago, s4dreamer said:
Which workshops did you go to get your dash cam fixed? Any recommendations?
Can try Autotrend at Toa Payoh. Look for the boss Darren.
Been going there for my horns, alarm, car cam, etc.
any recommendations for 2ch full hd with wifi?
blackvue 590W good enough? anything better at that price point?
buy from where can get free installation?
Edited by wlalala
It doesn't come with motion detect for parking mode. Only records upon impact. That's a concern for me.
Tested the DDP Mini 3 and Mini 5.
Mini 3 comes with a Bluetooth wireless push switch to snap a photo and 10-30s video, not the Mini 5. But both can be voice activated to do the same. "I want to take a photo". And other functions.
In Chinese! 😅
Ingerish educated buyers beware!
Plus Mini 5 has GPS and speed indication. Which of course I will switch off.
Edited by Volvobrick
33 minutes ago, Eugenenana said:
Hi. Anyone know where to replace this reverse camera?
What car is it?
Go to Autotrend at Toa Payoh and look for boss Darren. He will find something similar.
29 minutes ago, darkwish said:
need to shift my thinkware f770 to another car cause coe expiring. any recommendations that does this without ripping you off? thanks
13 minutes ago, Innocuous said:
I have bought my own car camera , need a reliable workshop to help install, any recommendation
Thank you in advance
Autotrend at Toa Payoh. Look for boss Darren.
Have used them for horns, cameras, stereo stuff, etc. More than capable to do the stuff you need.
So far I always install myself.... Quite easy. Just need to know where your fuse boxes are and which is ACC and which is VCC.
Thanks.  What is considered easy for you, U cannot assumed the same for others.
  • Haha! 1
26 minutes ago, awhtc said:
I paid $50 to install front and rear cameras.  The installer took 1 hour+ to remove my old set up and install the new set up.  It did not look easy to me because he used some tools to pull the signal and electrical cables around and hardwire the electrical cables to the correct wires (I hope so).
That's a fair price for their labour and knowledge.
