BengGaBoy 2nd Gear May 7, 2019 Share May 7, 2019 (edited) https://www.kickstarter.com/projects/arvizon/vezo-360-the-first-4k-360-smart-dash-cam Looks like quite exciting product for a 360 degrees dashcam that can capture side view! Dual lens 4k resolution parking mode Motion sensor GPS Wi-Fi microSD up to 256GB 4G-LTE (micro SIM) Normal price: 299 and early bird @ 169 I guess it should be USD currency But not much video footage to show it's quality and also the ability to survive Singapore hot weather is another doubt. Edited May 7, 2019 by BengGaBoy ↡ Advertisement Link to post Share on other sites More sharing options...
jcchia 3rd Gear May 8, 2019 Share May 8, 2019 My BM ride Blackvue750 2 channel was replaced twice with 8 months. (Intitial thinkware upgrade) Free only under warranty. Need to source for a better 1 after warranty. My previous korean brand with 24/7 monitoring last me 8 yrs n are still working on my other car. Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear May 10, 2019 Share May 10, 2019 https://www.kickstarter.com/projects/arvizon/vezo-360-the-first-4k-360-smart-dash-cam Looks like quite exciting product for a 360 degrees dashcam that can capture side view! Dual lens 4k resolution parking mode Motion sensor GPS Wi-Fi microSD up to 256GB 4G-LTE (micro SIM) Normal price: 299 and early bird @ 169 I guess it should be USD currency But not much video footage to show it's quality and also the ability to survive Singapore hot weather is another doubt. Thanks for the tip... But not true 4k. shld be Korea mfr. But not ex. But their spec sheet not detailed enough Link to post Share on other sites More sharing options...
Lovemyride 4th Gear May 10, 2019 Share May 10, 2019 I'm using android.. hope it work as well as ios... how long can a 64gb card record? can the device support 128gb cards? Hi, sorry for the late reply. I've pulled the SD cards out to check on my computer. 70 mai pro 64GB: I had about 352 files in the folder, 1 min each file, except for those where I've parked and turned the engine off. Give and take, say it can hold about 350 mins. 70 mai 64GB (rear): 384 files. Give and take, about 390 mins. I had some files in my "Events" folder, probably due to the G-force when I open and close the boot. I hope this helps. Link to post Share on other sites More sharing options...
BengGaBoy 2nd Gear May 10, 2019 Share May 10, 2019 Thanks for the tip... But not true 4k. shld be Korea mfr. But not ex. But their spec sheet not detailed enough Ya. I'm clarifying with them on several specification (LTE-4G band, input voltage for hard wire, frame rate & etc). Not sure whether will they reply but just trying. Link to post Share on other sites More sharing options...
Shorty Turbocharged May 10, 2019 Share May 10, 2019 Hi, sorry for the late reply. I've pulled the SD cards out to check on my computer. 70 mai pro 64GB: I had about 352 files in the folder, 1 min each file, except for those where I've parked and turned the engine off. Give and take, say it can hold about 350 mins. 70 mai 64GB (rear): 384 files. Give and take, about 390 mins. I had some files in my "Events" folder, probably due to the G-force when I open and close the boot. I hope this helps. Hi. For the 70mai,is the power only thru the socket? Or do u connnect straight to ur battery? Link to post Share on other sites More sharing options...
Lovemyride 4th Gear May 10, 2019 Share May 10, 2019 Hi. For the 70mai,is the power only thru the socket? Or do u connnect straight to ur battery? Mine is to fuse box. Got the shop to do it for me. $60 for both cams. Link to post Share on other sites More sharing options...
AlvinToh Neutral Newbie May 10, 2019 Share May 10, 2019 Mine is to fuse box. Got the shop to do it for me. $60 for both cams. Link to post Share on other sites More sharing options...
Shorty Turbocharged May 11, 2019 Share May 11, 2019 Mine is to fuse box. Got the shop to do it for me. $60 for both cams.Ok gd to know. Cos fixing to ciggy socket is not so nice la. Considering to buy this cam. Link to post Share on other sites More sharing options...
Reo 4th Gear May 13, 2019 Share May 13, 2019 I've many 70mai (non-Pro) installed and they deliver superb usability and value for money. I had a quick look at the Pro version, besides extra resolution, how's the parking mode feature, if it's indeed true parking mode as in record only when there's motion. Xiaomi 70mai Pro is still the best car camera I have used so far. Even the i-Drive i11 given by my PI shuts down occasionally and restarts, which I suspect is due to overheating. Link to post Share on other sites More sharing options...
XD1293 Neutral Newbie June 10, 2019 Share June 10, 2019 Hi, I need help for my in-car camera. I have purchase a second hand car with Dabonda Gallery camera. As I purchased it from a used car dealer, I got problems checking if the camera is working fine as I don't have the software. The camera seems to be in good working condition and seems to be recording. Any kind bros here can advise me if there is any software or manual which I could download to view the recording? Thank you very much. https://www.sgcarmart.com/products/overview.php?ID=9823 Link to post Share on other sites More sharing options...
Harthen 2nd Gear June 15, 2019 Share June 15, 2019 Xiaomi 70mai Pro is still the best car camera I have used so far. Even the i-Drive i11 given by my PI shuts down occasionally and restarts, which I suspect is due to overheating. Is xiaomi 70mai Pro only front camera and no rear? Is it good enough? Link to post Share on other sites More sharing options...
Dafansu Turbocharged June 15, 2019 Share June 15, 2019 Is xiaomi 70mai Pro only front camera and no rear? Is it good enough?Just add one more for the rear. Can get the non-pro model at about $50 good enough and clarity beats a lot of cam in the market 1 Link to post Share on other sites More sharing options...
Harthen 2nd Gear June 15, 2019 Share June 15, 2019 Just add one more for the rear. Can get the non-pro model at about $50 good enough and clarity beats a lot of cam in the marketOh.. and is it wifi? Or how to view the camera.. smv newbie here. Was looking ard iroad v9 or x9 earlier. Lol.. Link to post Share on other sites More sharing options...
Jusnel 6th Gear July 27, 2019 Share July 27, 2019 Mine is to fuse box. Got the shop to do it for me. $60 for both cams.So the pro is at front, and non pro is at the back? Both are connected to fuse box? Which installation shop u go? Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie August 14, 2019 Share August 14, 2019 Anyone using Cellink Neo battery? Does this means the battery is gone? Link to post Share on other sites More sharing options...
Adrianli Hypersonic August 14, 2019 Share August 14, 2019 Anyone using Cellink Neo battery? Does this means the battery is gone? I was using Cellink Neo. Never had this message before. Does it still charge??? 1 Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie August 14, 2019 Share August 14, 2019 I was using Cellink Neo. Never had this message before. Does it still charge??? Doesn't seem to be charging. With voltage but no amp. ↡ Advertisement Link to post Share on other sites More sharing options...
Explore High-Performance FineVu Dashcams by Auto Interior Pte Ltd
Dashcam with GPS
Dashcam with GPS
Blackvue users - please come in AGAIN 2
IRoad X9 drains battery until it is flat
WIN attractive prizes worth $4,440! Submit reviews on any car tyres, lubricant or accessories now.
