Adrianli Hypersonic September 4, 2014 Share September 4, 2014 thanks. but if space between the rearview mirror and windscreen has a housing for sensors, then it has to be placed below which might affect driver's view Then u can place the camera on either side of the sensor housing, top of windscreen. No need die die in the center one. Car camera have wide angle lens. If u scroll back, u can see I am using two car camera. One in the center and one on top of driver side. Both capture the same thing. ↡ Advertisement Link to post Share on other sites More sharing options...
Enye Hypersonic September 4, 2014 Share September 4, 2014 Then u can place the camera on either side of the sensor housing, top of windscreen. No need die die in the center one. Car camera have wide angle lens. If u scroll back, u can see I am using two car camera. One in the center and one on top of driver side. Both capture the same thing. great. thanks for your advice! Link to post Share on other sites More sharing options...
Adrianli Hypersonic September 4, 2014 Share September 4, 2014 Link to post Share on other sites More sharing options...
TVT Supercharged September 4, 2014 Share September 4, 2014 Will a dash cam partially block the driver's front view? Some of these cameras look pretty big You are asking about a cam that is mounted on the dashboard right ? Not on the windscreen...if I read correctly. Link to post Share on other sites More sharing options...
Enye Hypersonic September 4, 2014 Share September 4, 2014 You are asking about a cam that is mounted on the dashboard right ? Not on the windscreen...if I read correctly. used it as a general term is cam mounted on windscreen commonly called "windscreen cam"? Link to post Share on other sites More sharing options...
TVT Supercharged September 4, 2014 Share September 4, 2014 used it as a general term is cam mounted on windscreen commonly called "windscreen cam"? Not sure also..... but when you mention "dash", it gives an impression that it refers to the dashboard, like this: Anyway.... Link to post Share on other sites More sharing options...
Adrianli Hypersonic September 5, 2014 Share September 5, 2014 Not sure also..... but when you mention "dash", it gives an impression that it refers to the dashboard, like this: Anyway.... This is a potential window smashing, snatch and grab situation in JB!!! I would not encourage to mount it this way. I maintain a clean dashboard when driving to JB. 1 Link to post Share on other sites More sharing options...
Enye Hypersonic September 5, 2014 Share September 5, 2014 This is a potential window smashing, snatch and grab situation in JB!!! I would not encourage to mount it this way. I maintain a clean dashboard when driving to JB. mounted on windscreen less prone to theft in JB? less visible? Link to post Share on other sites More sharing options...
Adrianli Hypersonic September 5, 2014 Share September 5, 2014 mounted on windscreen less prone to theft in JB? less visible? Top part of the windscreen. Link to post Share on other sites More sharing options...
TVT Supercharged September 5, 2014 Share September 5, 2014 This is a potential window smashing, snatch and grab situation in JB!!! I would not encourage to mount it this way. I maintain a clean dashboard when driving to JB. If mount cam/GPS on dashboard must remove it when park car in all Malaysia, not just JB. Link to post Share on other sites More sharing options...
Tireburner 3rd Gear September 5, 2014 Share September 5, 2014 Need some advice here. I'm using Smart, a Taiwanese made cam that sticks on the windscreen. The holder drops off after a while like around once a month. Recently, when it dropped off, it did so suddenly that the plug from the power cable was pulled out of place leaving only bare wires. With that, my cam is without the power source. Anyone knows where I can buy a cigarette charger power cable with the specs of Input 12Vdc/24Vdc, Output 5Vdc 1A. Length 3.4m. Went to Challenger and Best Denki but couldn't find it. Thanks in advance. Link to post Share on other sites More sharing options...
Adrianli Hypersonic September 5, 2014 Share September 5, 2014 Need some advice here. I'm using Smart, a Taiwanese made cam that sticks on the windscreen. The holder drops off after a while like around once a month. Recently, when it dropped off, it did so suddenly that the plug from the power cable was pulled out of place leaving only bare wires. With that, my cam is without the power source. Anyone knows where I can buy a cigarette charger power cable with the specs of Input 12Vdc/24Vdc, Output 5Vdc 1A. Length 3.4m. Went to Challenger and Best Denki but couldn't find it. Thanks in advance. Go Sim Lim Tower, lots of shop sell this. Cheaper way is to solder back the wire and cig plug. No need to buy new one. Link to post Share on other sites More sharing options...
TVT Supercharged September 5, 2014 Share September 5, 2014 This is a potential window smashing, snatch and grab situation in JB!!! Btw, these car cams are now selling commonly in JB. In many major shopping malls I see shops selling them, especially those selling handphones. Soon it'll be common on Malaysian cars as well. Link to post Share on other sites More sharing options...
Crashburner 3rd Gear September 9, 2014 Share September 9, 2014 (edited) any folks using or heard about Cowon? Went to AutoBacs and wanted to install ThinkWare but don't have the model that I wanted. Was recommended Cowon instead. Edited September 9, 2014 by Crashburner Link to post Share on other sites More sharing options...
GongJiaoWei 3rd Gear September 9, 2014 Share September 9, 2014 any folks using or heard about Cowon? Went to AutoBacs and wanted to install ThinkWare but don't have the model that I wanted. Was recommended Cowon instead. Which model they introducing? I think the brand comes from Korea.. For your reference: http://www.cowonglobal.com/ But I think not all their blackbox models is in sg. Manage to find 2 models listed in sgcarmart only http://www.sgcarmart.com/products/listing.php?RPG=15&PTB=cowon&CAT=0&SCAT= Link to post Share on other sites More sharing options...
Crashburner 3rd Gear September 9, 2014 Share September 9, 2014 Which model they introducing? I think the brand comes from Korea.. For your reference: http://www.cowonglobal.com/ But I think not all their blackbox models is in sg. Manage to find 2 models listed in sgcarmart only http://www.sgcarmart.com/products/listing.php?RPG=15&PTB=cowon&CAT=0&SCAT= they quoted the AW1. But not sure about it because hardly see any review on it or limited videos to evaluate the quality Link to post Share on other sites More sharing options...
xherion 2nd Gear September 26, 2014 Share September 26, 2014 any folks using or heard about Cowon? Went to AutoBacs and wanted to install ThinkWare but don't have the model that I wanted. Was recommended Cowon instead. Bro, may i know which Thinkware models were in Autobacs? Price already includes free installation? For Thinkware i believe the cheapest is around 200+ Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged September 26, 2014 Share September 26, 2014 I am using this kind of camera.. Sgd 70+ from taobao. All is good, only thing is the angle not too good but it's neat looking for the car ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Feb 2025
Car camera recommendation
COE Bidding - January 2025
2024 Suzuki Swift
2024 Suzuki Swift
Australia: Car Rental in Melbourne
