Blackvue users - please come in AGAIN 2
RadX
This is the direct link to download the blackvue viewer for mac.
http://www.blackvue.co.kr/en/common/downloadHIT.asp?downfile=BlackVueViewer1.2000.zip&path=board&idx=1164&sort=0
If still cannot then use the one i sent.
Pasting the link here in case others have the same problem downloading: https://www.hightail.com/download/elNMaUNLU1BYSHl4djhUQw
Edited by Wiiuwii
I have bought a BlackVue Car dash cam,about 3 month lifetime.
Will never buy this brand again,
My USD 50 Black VIEW after 2 years still going strong!
Which model of backvue are u using?
My two DR400 installed front and rear has been working fine for almost two years liao. They are installed as driving recorders and not run 24/7.
I was using DR380,after 3 month,can't be turn on, after reset,black screen,contact with seller, need send back for repair.
Then i am though out it.
I just installed DR550 with power magic, very concerned about battery drainage, can anyone advise the power magic pro I should turn to "1" or "0" during driving and parking? Thanks.
U can buy two sets for that price from online shops. [shocked]
bro, if buy from gmarket, is the installation for this dual channel straightforward?
need to tap power directly from battery terminal?
1
Up to u. If need 24/7, then need to connect to battery terminal or fuse box. Otherwise just plug into cig plug for normal drive recorder.
1
so the cable connection to the rear camera , is usually through taping from cigaraette plug to the rear windscreen?
1
1 is during driving or parking or both?
Please refer to the manual, page 17.
Manual : http://files.sotmarket.ru/instr/aksy_dlya_avto/videoregistratory/blackvue/manual-blackvue-dr550gw-2ch.pdf
I do not own the DR550. I refer to the attached manual to answer ur query. I find the manual is pretty clear.
Refer to this manual for ur Power Magic Pro. Look at Multi-booting.
U want 24/7 recording = 1
U want drive recorder only = 0
Hey folks,
recently, I found out that there is only one video clip in the SD card (used to be multiple clips). the same clip will be overwritten to instead of creating multiple video files.
I'm sure i did not change any settings and each video length is of 2 mins. The SD size is 4GB which i pretty sure more than sufficient.
any good advices?
