Blackvue users - please come in AGAIN 2
RadX
I just gotten the DR400G season 2 and it seems like the season 2 is also plagued with the heating problem. May I ask if anyone installed heatsink to their Blackvue DR400? Mind sharing some photos of it?
Heatsink without a fan in an environment where the surrounding will be hotter than the subject to be cooled is totally useless, as it will only transfer more heat from the surrounding to the subject instead of dissipating the heat.
There:
http://forums.redflagdeals.com/merged-offi...6/#post16037605
NB: It may nullify your warranty if you take it apart.
Thanks for the link. This person stuck a heat sink at the NAND flash part while the speaker is where the TI processor is located. I guess still some work has to be done to add addition heatsink to the components in that area.
Yeah, an active component like a fan is better. However, I suppose the component should still be hotter than the surroundings (the car ambient temperature). Even with a fan, if it is in a thermal equilibrium state, the fan does not remove the heat effectively because of the lack of temperature gradient?
Hi guys, anyone here did not link the cam to car batt instead link to ownself bought outside power bank like those used to charge phone. Not talking abt the tpower c. More like those powerbank u can buy frm sim lim.
Thanks bro I'll try to find him. Ya I want parking surveillance but dun want tap car batt. Looking for alternatives to the tpower c.
Aiyo, then you shouldnt get DR400. Confirm will overheat one. You can get the power magic.
Edited by Dscheng
u used for surveillance too? test it for a couple of months first. i tried 400 & 380 for few months with few RMA, ended up with 350 instead.
lately, found that even disconnected and exposed to noon sun, front windscreen dvr body still hot to the touch. lucky rear 350 has spoiler to shield it from noon sun that's y i think can "survive" til now.
use both until koyak first before deciding wc to install, mayb by then chg car liao..
Edited by Fuelsaver
Me. But I using 3cell lithium polymer battery.
Hi adrian, can advise more like how many volt out frm your batt 8v or 12v? And how much mah is yours? 10000mah or 6000mah? And lastly how is the connection frm the batt to the blackvue, izzit batt straight to cam or in between there is a ciggy socket connector for the cam ciggy plug to go in? Hehe sorry to trouble u.
12.6v out when fully charged.
8000mah.
Direct battery out to car cam.
Great info bro! Thanks for sharing. Reason y I ask batt is becos the t-power seems quite expensive. Wanted to have 2 batteries. Might be costly if get 2 tpower.
