Topspin 2nd Gear July 25, 2012 Share July 25, 2012 On 7/25/2012 at 1:06 AM, TJX said: Help Help!! Formatted my SD card last nite. When i insert the SD card in blackvue cam today, there is an error message, pls check the SD card. Can anyone tell me what is wrong and what i can do to ratify this? Thanks thanks!!! After formatting, you still need to copy over the various folders (I presume you have saved the folders but you can delete away the old saved videos). If you do not have the folders, you can re-instate them by using the Blackvue firmware update software. It will then create the folders for you. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Mysportwish 1st Gear July 25, 2012 Share July 25, 2012 usually after format, i insert it into the BV and it will auto-download to the SD card automatically. 1 Link to post Share on other sites More sharing options...
I_RIDE_DEEP 2nd Gear July 25, 2012 Share July 25, 2012 (edited) On 7/24/2012 at 3:15 AM, Vvman said: That's great! So it seems the critical overheating issue has been resolved! Thanks for the feedback Crystal n Fuelsaver. DR400: It is not resolved for DR400 yet. Please avoid this. DR380 I am not sure if I would say this has no overheating problems. From what i have seen in the forum, nobody has so far tested this with long term parking under the hot sun. Edited July 25, 2012 by I_RIDE_DEEP Link to post Share on other sites More sharing options...
Picanto 3rd Gear July 25, 2012 Share July 25, 2012 On 7/25/2012 at 4:20 AM, I_RIDE_DEEP said: DR400: It is not resolved for DR400 yet. Please avoid this. DR380 I am not sure if I would say this has no overheating problems. From what i have seen in the forum, nobody has so far tested this with long term parking under the hot sun. DR 380 is still quite new. so not much review on it Link to post Share on other sites More sharing options...
TJX Turbocharged July 25, 2012 Share July 25, 2012 On 7/25/2012 at 1:13 AM, Salmon said: Did you use the sd formatter provided by Pittasoft? Use option: full overwrite, size adjustment ON. Yes Sir. That's what i did... Link to post Share on other sites More sharing options...
TJX Turbocharged July 25, 2012 Share July 25, 2012 On 7/25/2012 at 2:53 AM, Topspin said: After formatting, you still need to copy over the various folders (I presume you have saved the folders but you can delete away the old saved videos). If you do not have the folders, you can re-instate them by using the Blackvue firmware update software. It will then create the folders for you. Ok Bro, Will go back and try. Hope it is not too complicated. Thanks. Link to post Share on other sites More sharing options...
TJX Turbocharged July 25, 2012 Share July 25, 2012 On 7/25/2012 at 3:16 AM, Mysportwish said: usually after format, i insert it into the BV and it will auto-download to the SD card automatically. Doesnt work for me... Thanks.. Link to post Share on other sites More sharing options...
Crystal_tiong 1st Gear July 25, 2012 Share July 25, 2012 On 7/25/2012 at 4:20 AM, I_RIDE_DEEP said: DR400: It is not resolved for DR400 yet. Please avoid this. DR380 I am not sure if I would say this has no overheating problems. From what i have seen in the forum, nobody has so far tested this with long term parking under the hot sun. my car is parked 24hrs open car park , so no overheating at the moment Link to post Share on other sites More sharing options...
Locknload 5th Gear July 25, 2012 Share July 25, 2012 On 7/25/2012 at 6:09 AM, Crystal_tiong said: my car is parked 24hrs open car park , so no overheating at the moment Wow, so far so good then. Mine from 9-6pm at Seah Im open carpark for almost 3 weeks, still good. Link to post Share on other sites More sharing options...
Jeff13 Neutral Newbie July 25, 2012 Share July 25, 2012 (edited) I use to leave it running without switching off, than after 3 weeks the lens gets foggy send it back and get a RMA set (recently)....now I install a switch and switches off parking mode at home carpark (MSCP) and work place (park inside warehouse). I uses parking mode only on some places like shopping mall etc.....so far so good...touch wood...lol... But some how it makes me think this in-car camera is under utilize for what this BlackVue DR400 has design to be use... I also tried searching for other brand which I found most of the video quality are incomparable to DR400....If there is no issue with heating, this BV would be perfect....still waiting to find a perfect one :) Edited July 25, 2012 by Jeff13 Link to post Share on other sites More sharing options...
Summithike Neutral Newbie July 27, 2012 Share July 27, 2012 Hi all, Plan on getting 2 of the Blackvues, when they finally sort all this out. Anyway, just got an email from a Blackvue exec from the UK. I requested info on the Mark 11 . He states that all the 400G's are essentially 400G-HD 11's, because they have replaced the old PCB with a new one addressing the heat problem...We shall see? Link to post Share on other sites More sharing options...
Mysportwish 1st Gear July 28, 2012 Share July 28, 2012 (edited) BW exec from UK? I thou this is a korean product. Most exec shld be from the South Korea. Edited July 28, 2012 by Mysportwish Link to post Share on other sites More sharing options...
Bird5011 3rd Gear July 28, 2012 Share July 28, 2012 On 7/27/2012 at 8:20 PM, Summithike said: Hi all, Plan on getting 2 of the Blackvues, when they finally sort all this out. Anyway, just got an email from a Blackvue exec from the UK. I requested info on the Mark 11 . He states that all the 400G's are essentially 400G-HD 11's, because they have replaced the old PCB with a new one addressing the heat problem...We shall see? Got bluff bluff or not! BV exec from the UK? BV is from SKorea leh. Link to post Share on other sites More sharing options...
I_RIDE_DEEP 2nd Gear July 28, 2012 Share July 28, 2012 On 7/28/2012 at 1:06 AM, Bird5011 said: Got bluff bluff or not! BV exec from the UK? BV is from SKorea leh. His first post. Maybe he is a troll Link to post Share on other sites More sharing options...
Bird5011 3rd Gear July 28, 2012 Share July 28, 2012 On 7/25/2012 at 6:09 AM, Crystal_tiong said: my car is parked 24hrs open car park , so no overheating at the moment Yeah..I also parked "open air " at home and office. So far no "floggy" len as mentioned by few users. The only issue i have is that when I unplug power to take out SD Card for viewing and re-insert again some times the date/time is not sync with the current date/time! Some times sync with date/time if not it will continues recording with the "old time/date"! Any ideas how to reset date/time? Link to post Share on other sites More sharing options...
Summithike Neutral Newbie July 28, 2012 Share July 28, 2012 Well that's what I thought but sent an email to this site http://www.blackvue.co.uk/ I assume this is United Kingdom? Am I wrong?? Link to post Share on other sites More sharing options...
Summithike Neutral Newbie July 28, 2012 Share July 28, 2012 Found this, however my Korean is a bit rusty.. Notice diff in lens cover on body http://www.blackvue.com/contents/sub1.asp?idx=17 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged July 28, 2012 Share July 28, 2012 On 7/24/2012 at 3:15 AM, Vvman said: That's great! So it seems the critical overheating issue has been resolved! Thanks for the feedback Crystal n Fuelsaver. let's just say the heat range is somewat between dr350 and dr400; slightly lower than dr400. again, it's been about a couple weeks i'm on it 24/7 and still working. ↡ Advertisement Link to post Share on other sites More sharing options...
Car camera recommendation
Anyone using Blaupunkt BP-9.0A?
Video edit from dark to bright res?
Dashcam comparion: BlackVue iRoad and Thinkware
Using power bank with Car Cam
In-Car Camera Installation
