Eko6 2nd Gear June 20, 2012 Share June 20, 2012 How much and how long will it take? ↡ Advertisement Link to post Share on other sites More sharing options...
Mcf777 Turbocharged June 20, 2012 Share June 20, 2012 sometime, it is cheaper to change the rotor than skim. my NEW rotor per pair cost S$160. Installation S$40. Total S$200. Skim cost at least S$50 and above for per pair. And how long can it last? Link to post Share on other sites More sharing options...
Briansoh 1st Gear June 23, 2012 Share June 23, 2012 (edited) Its more economical in the long run to get a new rotor. Skimmed rotors dont last long and before you know it, you have to change it again. Besides, Singapore mechs workmanship sucks and the skimmed rotor probably wont be flat still. Buy the rotors yourself from the parts suppliers to save some money. Edited June 23, 2012 by Briansoh Link to post Share on other sites More sharing options...
Tohdj Neutral Newbie June 23, 2012 Share June 23, 2012 On 6/20/2012 at 9:11 AM, Eko6 said: How much and how long will it take? go to the workshop at esso petrol station near thomson plaza. i did mine front rotors for S$51. 2 year+...my rotors are still working well. Link to post Share on other sites More sharing options...
KaKiLang 4th Gear June 23, 2012 Share June 23, 2012 Don't believe in skimming the rotor, get a new set and remember to change the pads together. Link to post Share on other sites More sharing options...
Eko6 2nd Gear June 24, 2012 Author Share June 24, 2012 On 6/23/2012 at 3:25 AM, Tohdj said: go to the workshop at esso petrol station near thomson plaza. i did mine front rotors for S$51. 2 year+...my rotors are still working well. how long did you waited for them to skim? Buy new ones ~ $200 Skim old ones ~ $50 I think it is better to recycle old ones to save the earth's resources. Link to post Share on other sites More sharing options...
Donut Supercharged June 24, 2012 Share June 24, 2012 On 6/20/2012 at 9:11 AM, Eko6 said: How much and how long will it take? Best is NOT to skim..... It's not good. But if u plan to get rid of the car soon, then skim it. But if u want to keep the car long term, change new rotor Link to post Share on other sites More sharing options...
Meanmachine Supercharged June 24, 2012 Share June 24, 2012 MY 0.02cts, If its jap / korean car, intend to drive ard next 8-16 mths, juz skim it and drive, but have to take notice of dust built-up. If its Conti car, best to have two consultation advise from reliable sources, i.e: Ad and workshops specialises in Alf, Bmw.Merc & VW, Audis. Best to change rotor blade once and for all, an average of 4 to 4half yrs usage is a good gauge, of course driving style / handling prevails . . . Link to post Share on other sites More sharing options...
Meanmachine Supercharged June 24, 2012 Share June 24, 2012 On 6/23/2012 at 4:26 AM, KaKiLang said: Don't believe in skimming the rotor, get a new set and remember to change the pads together. U may be rite, many workshops mechanic chose the easier way out by asking you to change this/ tt, towards the end of d day, you are the owner, best to decides wad is best for your own needs. I chose to ignore it after much consideration on the expanded cost / mechanic reliability, instead I changed nly the brake pad, no major problem so far, I still monitoring the rotor, no squelling sounds and noise generated so far, pretty good results for my E200 AG, bt we nvr know . . do we ? Link to post Share on other sites More sharing options...
Edca 1st Gear July 5, 2012 Share July 5, 2012 On 6/20/2012 at 10:35 AM, Mcf777 said: sometime, it is cheaper to change the rotor than skim. my NEW rotor per pair cost S$160. Installation S$40. Total S$200. Skim cost at least S$50 and above for per pair. And how long can it last? Bro what brand u bought the new rotor? Can advise your car model... Link to post Share on other sites More sharing options...
Hurryup Clutched July 5, 2012 Share July 5, 2012 hi guys where else can we skim rotors? and if posible advise the price including taking off and install back. Link to post Share on other sites More sharing options...
Tohdj Neutral Newbie July 5, 2012 Share July 5, 2012 On 6/24/2012 at 3:08 AM, Eko6 said: how long did you waited for them to skim? Buy new ones ~ $200 Skim old ones ~ $50 I think it is better to recycle old ones to save the earth's resources. it should be S$200 per new rotor? i paid S$51 for skimming of 2 rotors. a guy came in a van, picked up the rotors, and when i came back 2 hours later, they were installed on my car. Link to post Share on other sites More sharing options...
Tohdj Neutral Newbie July 5, 2012 Share July 5, 2012 closeup it is grinding a thin layer of the rotors off. when you pressed the brakes...the brake pads contacts the rotors, and in the process of slowing down the car, a thin layer of the rotor is grind off. So do you change your rotors every time you pressed your brakes? Link to post Share on other sites More sharing options...
Aaron_soh80 1st Gear July 5, 2012 Share July 5, 2012 On 6/20/2012 at 9:11 AM, Eko6 said: How much and how long will it take? Y u wan to Skim rotor .. Link to post Share on other sites More sharing options...
Gkteng 1st Gear July 15, 2012 Share July 15, 2012 On 7/5/2012 at 3:28 AM, Tohdj said: it should be S$200 per new rotor? i paid S$51 for skimming of 2 rotors. a guy came in a van, picked up the rotors, and when i came back 2 hours later, they were installed on my car. Tohdj, can you provide the contact? Link to post Share on other sites More sharing options...
Camrysfa Turbocharged July 15, 2012 Share July 15, 2012 where to skim rotor? most workshop can settle this. those workshop men have eagle eye. i sent my car for svcing and without removing anything, they said my rotors need work. what they do is take it out and send somewhere to do. within 3 hrs, job done. Link to post Share on other sites More sharing options...
Tohdj Neutral Newbie July 15, 2012 Share July 15, 2012 On 7/15/2012 at 12:23 PM, Gkteng said: Tohdj, can you provide the contact? my mechanic will call a man...and this guy will come to pick up the rotors and then return within 2 or 3 hours with skimmed rotors. my mech is at the esso petrol station at thomson plaza area. Link to post Share on other sites More sharing options...
13177 Hypersonic July 15, 2012 Share July 15, 2012 If dont change rotor, what will happened? ↡ Advertisement Link to post Share on other sites More sharing options...
AP racing rotor
AP racing rotor
Skim rotor and new brake pads reasonable ?
EXZESS brake rotor needs replacement. where to go?
Best place to buy Big Brake Kit parts online
Where to get brembo rotor?
Brake disc skimming
Brake disc skimming
This brake rotor will sell MUCH better with a caliper!
