Windwaver Turbocharged June 18, 2012 Share June 18, 2012 Just changed to Amaron battery but battery indicator still lights up. Does that mean car alternator is faulty or fuse blown? How to check? ↡ Advertisement Link to post Share on other sites More sharing options...
Batlim 1st Gear June 18, 2012 Share June 18, 2012 Most likely alternator not charging leow ........... Link to post Share on other sites More sharing options...
Boxster 2nd Gear June 18, 2012 Share June 18, 2012 Normally the battery indicator indicates charging issues rather than battery problem such as unable to hold charge Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 18, 2012 Author Share June 18, 2012 On 6/18/2012 at 1:09 PM, Boxster said: Normally the battery indicator indicates charging issues rather than battery problem such as unable to hold charge I see. In that case, is the alternator faulty or fuse blown? How much roughly to repair or change alternator? Link to post Share on other sites More sharing options...
Kb27 Supersonic June 18, 2012 Share June 18, 2012 Battery indicator is a charging problem, not battery problem. In most cases, it's usually due to a bad alternator. Price range from $300~$500 including parts and labour, depending on which workshop you go to. Link to post Share on other sites More sharing options...
Trafficwatch Clutched June 18, 2012 Share June 18, 2012 Yes, alternator not charging your battery already. To confirm simple steps: - start engine - dis-connect negative terminal of battery when engine is running / idling - if car stall immediately after disconnect the battery terminals, then it's confirmed alternator defective Cost to replace alternator depends on car models. - Re-codition between S$ 250 to S$ 600 - brand new between S$ 800 to S$ 1,400 or more Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 18, 2012 Share June 18, 2012 I sincerely hope you are not a trained auto electrician Link to post Share on other sites More sharing options...
Trafficwatch Clutched June 18, 2012 Share June 18, 2012 Haha, i'm trained ! Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 18, 2012 Share June 18, 2012 (edited) Good night, I hope I will not have a bad dream on alternator DC and Amp output status testing Edited June 18, 2012 by Yeobh Link to post Share on other sites More sharing options...
Mcf777 Turbocharged June 18, 2012 Share June 18, 2012 I just changed my alternator for s$2k. Blardy kui! Link to post Share on other sites More sharing options...
Windwaver Turbocharged June 18, 2012 Author Share June 18, 2012 On 6/18/2012 at 2:28 PM, Trafficwatch said: Yes, alternator not charging your battery already. To confirm simple steps: - start engine - dis-connect negative terminal of battery when engine is running / idling - if car stall immediately after disconnect the battery terminals, then it's confirmed alternator defective Cost to replace alternator depends on car models. - Re-codition between S$ 250 to S$ 600 - brand new between S$ 800 to S$ 1,400 or more I see. My mileage is not even 20K, does a alternator fail that easily? Link to post Share on other sites More sharing options...
Jerrimie Clutched June 18, 2012 Share June 18, 2012 just go workshop and let them test lo. Even driven a Rav 4 with dying alternator and all of sudden power steering died on me. Chua sai sia. Link to post Share on other sites More sharing options...
Kb27 Supersonic June 18, 2012 Share June 18, 2012 On 6/18/2012 at 3:09 PM, Mcf777 said: I just changed my alternator for s$2k. Blardy kui! Alternator cost may be $250 onwards. Labour shouldn't cost more than $100, depending on how difficult it is to access and remove. + + all that the workshop want to make extra, yeah it can add up. Link to post Share on other sites More sharing options...
Boxster 2nd Gear June 18, 2012 Share June 18, 2012 On 6/18/2012 at 3:11 PM, Windwaver said: I see. My mileage is not even 20K, does a alternator fail that easily? If yr car is <20K and still covered under warranty you should got back to the AD workshop and let them diagnose Link to post Share on other sites More sharing options...
QQDreamer 4th Gear June 18, 2012 Share June 18, 2012 On 6/18/2012 at 10:57 PM, Boxster said: If yr car is <20K and still covered under warranty you should got back to the AD workshop and let them diagnose Probably TS car is a opc or a 2nd car in the family. Not sure abt the age of TS car. Not surprised that after couple of yrs the mileage is still below 20k. Mine 4yrs plus. Mileage less than 20k opc. Link to post Share on other sites More sharing options...
ER-3682 Twincharged June 18, 2012 Share June 18, 2012 On 6/18/2012 at 3:09 PM, Mcf777 said: I just changed my alternator for s$2k. Blardy kui! Must be a BMW or Mercedes Benz,done in Agent. Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 19, 2012 Share June 19, 2012 On 6/18/2012 at 2:28 PM, Trafficwatch said: Yes, alternator not charging your battery already. To confirm simple steps: - start engine - dis-connect negative terminal of battery when engine is running / idling - if car stall immediately after disconnect the battery terminals, then it's confirmed alternator defective Cost to replace alternator depends on car models. - Re-codition between S$ 250 to S$ 600 - brand new between S$ 800 to S$ 1,400 or more The easiest way is to use a multimeter or voltmeter to check the voltage at the battery if it is 13+ to 14V. If it is, means alternator is working. If only 12+ to 11V, means alternator not working. No need to remove batt terminal. Link to post Share on other sites More sharing options...
Mcf777 Turbocharged June 19, 2012 Share June 19, 2012 my car power totally cut-off when im still driving at 2pm along yio chu kang road. Lucky, behind no car. if not, sure chain accident. Heng ah!!!!! Brake and steering wheel is still working well. 1st time SOS for a flat towing car to tow back to agent ↡ Advertisement Link to post Share on other sites More sharing options...
Battery for Honda Vezel
My EV journey to the i4
Battery Voltage up & down
Amaron Battery
Amaron Battery
