Enqury: timing belt's car vs timing chain
Skyiet27
Hi all, quite curious about this issue.
Those cars on belts, need to change belts, bearings, pump etc
Those cars on chains, no need to change bearings and pumps meh???
Btw any bros driving Getz 1.3, my fil driving, like to know whether chain or belt?
Many thanks
Hypersonic
Getz is timing belt, needs to change. For hyundai car, i think only from avante onwards is using timing chain.
Getz on belt. I used to drive it changed during 80k mileage. whole set with pump etc. 300plus with labor.
On chain u still need to change the pump n check on belt for aircon etc.
Thanks for all bros who replied.
Curious cos my bil jus brought his gd1 fit to ws then they say timing chain, jus do std serivicng
and last year my fren jdm accord actually went another ws do timing belt, ws said chain then only do std servicing
Funny why they never guide change pump etc
hahahahaaa
I never drive a car on chain so learnt something today.
thanks cheers
i never ask him cos not on very good terms recently
hahhahahaa
maybe around 10?
but years back when i borrow once just from sengkang to pasir ris back to sengkang
WOW!!!!!!!!!!!!!!!!!!!!!! >1/8 tank gone cos i test the car
hahahaha
then i told my wife, sb jiak luk fc
i heard the getz 1.6 better fc
chain usually need not change unless it gets really really noisy then you prob need to take a look.
timing chain tensioners need changing
chain might requires changing too.
Mine was stretched at 40k km, and it was changed under warranty. That will include tensioners too.
agent says jus change timing belt with other 3 belts onli, no need to change water pump.... but other workshops say must change water pump when change timing belt..... so wat is recommended? jus change onli timing belt n 3 other belts or include also water pump? pls advise..... thks n drive safe
For peace of mind and savings on labour charge, change all at one go.
Hypersonic
If you never change anything before, better change everything, the belt, water pump etc. Unless you are changing second time, then maybe listen to what advise your mechanic says.
