Batlim 1st Gear June 8, 2012 Share June 8, 2012 ID FUSEs are also known as LED BLOW-OUT FUSE ↡ Advertisement Link to post Share on other sites More sharing options...
Gee 1st Gear June 8, 2012 Share June 8, 2012 Aside the LED, any side effects to car ECU? What's the cost roughly if change entire fuse box? Thanks. Link to post Share on other sites More sharing options...
Batlim 1st Gear June 8, 2012 Author Share June 8, 2012 (edited) These have been around for a while - so far there has been on side effect on any vehicle. pls see pricing on this thread page 47 here in MCF - http://www.mycarforum.com/index.php?showto...2970&st=940 They are plug & play item, best for the DIYers...... Edited June 8, 2012 by Batlim Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 9, 2012 Share June 9, 2012 (edited) Are you referring to lit-up blown fuse Edited June 9, 2012 by Yeobh Link to post Share on other sites More sharing options...
Kb27 Supersonic June 9, 2012 Share June 9, 2012 Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 9, 2012 Share June 9, 2012 Yes this the one I have in mind Link to post Share on other sites More sharing options...
Batlim 1st Gear June 9, 2012 Author Share June 9, 2012 (edited) Is that the diode sticking out ? This is what I have in mind - The diodes is built into the fuse....... Edited June 9, 2012 by Batlim Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 10, 2012 Share June 10, 2012 Link to post Share on other sites More sharing options...
Batlim 1st Gear June 10, 2012 Author Share June 10, 2012 Morning..... Here is a clearer picture of the internal LED setup, unfortunately only when it is blown then we seen the leds lite-up - Link to post Share on other sites More sharing options...
Gee 1st Gear June 10, 2012 Share June 10, 2012 Any info about how long will it stay light up after blown? Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 10, 2012 Share June 10, 2012 It will remain lite up until the day it's remove. Link to post Share on other sites More sharing options...
Batlim 1st Gear June 10, 2012 Author Share June 10, 2012 I will run the test now & keep u updated...... Link to post Share on other sites More sharing options...
Batlim 1st Gear July 3, 2012 Author Share July 3, 2012 (edited) The Mirco unit which was given to me by the factory - diode dead within 48hours. 2nd test on our own Mini 10amp started on Sat Morning - still burning bright untill now so more than 72 hours leow..... Am trying to get the specifications from the maker but I think if any think is wrong 1 should go check the Fuse Box 1st. Picture of 2nd test will be posted soon bec a newbie nearly short-circuit the wires & Battery today. His name is ME...... Edited July 3, 2012 by Batlim Link to post Share on other sites More sharing options...
Batlim 1st Gear July 7, 2012 Author Share July 7, 2012 Testing stop - after 7 days the Mini LED ID fuse still lighted up. Link to post Share on other sites More sharing options...
Batlim 1st Gear July 14, 2012 Author Share July 14, 2012 Our maker has came back to us about the specs - their leds fuses are good for 500 man hours (20days). ↡ Advertisement Link to post Share on other sites More sharing options...
Using blower to dry car
CPU chip - What are you using? Intel or AMD?
56 Delightful Victorian Slang Terms You Should Be Using
Who Still using STP Oil Treatment?
Anyone using Blaupunkt BP-9.0A?
How are you using the SkillsFuture?
Using hose in mscp
Using hose in mscp
New VW still using key ignition
