Mllcg 3rd Gear May 20, 2012 Share May 20, 2012 Are car horns waterproof?i think mine got damaged at the car wash ytd..suddenly no sound. ↡ Advertisement Link to post Share on other sites More sharing options...
AlanZ Neutral Newbie May 20, 2012 Share May 20, 2012 Dun fit ur car horns with the trumpet hole facing upwards. Else sure collect water n spoils Link to post Share on other sites More sharing options...
Mcf777 Turbocharged May 20, 2012 Share May 20, 2012 change a new set. less than S$50 including installation at most audio shop. I forgoten the brand. it is a pair of RED colour horn. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear May 20, 2012 Author Share May 20, 2012 so how to tell them install? the "holes" facing upwards? Link to post Share on other sites More sharing options...
Nzy Twincharged May 20, 2012 Share May 20, 2012 The holes should be facing down. The horns spoil probably cuz water got in and got trapped inside the horn Link to post Share on other sites More sharing options...
Gee 1st Gear May 20, 2012 Share May 20, 2012 Make sure that it is the horn that's faulty. No sound could be due to bad connection or fuse blown or something else. Link to post Share on other sites More sharing options...
Tommimakinen Clutched May 20, 2012 Share May 20, 2012 hijack abit... :) noob question... is aftermatket horns like hella/ bosch approved? Link to post Share on other sites More sharing options...
Othello Supersonic May 20, 2012 Share May 20, 2012 generally, yes they are weatherproof. Means can tahan rain but not submerged under water. Horns are always situated behind the front grille, sure will kenna water one, and usually the flare part faces down (the correct mounting position) horns are cheap. go and get them changed. Get those two tone type, loud and shiok !! Eg. Stebel Magnum II Link to post Share on other sites More sharing options...
Othello Supersonic May 20, 2012 Share May 20, 2012 hijack abit... :) noob question... is aftermatket horns like hella/ bosch approved? No approved or not approved. Only air horns are NOT ALLOWED. Link to post Share on other sites More sharing options...
Jflcorp Neutral Newbie May 21, 2012 Share May 21, 2012 generally, yes they are weatherproof. Means can tahan rain but not submerged under water. Horns are always situated behind the front grille, sure will kenna water one, and usually the flare part faces down (the correct mounting position) horns are cheap. go and get them changed. Get those two tone type, loud and shiok !! Eg. Stebel Magnum II I am using Stebels for my car and bike! Super shiok sound! Last time use Hella, but Stebel more kick! Link to post Share on other sites More sharing options...
SimonTan 2nd Gear May 21, 2012 Share May 21, 2012 Drill draining holes in those spriral horns. I did that for my motorcycle horn. To get maximum sound forward you need to 'aim' the opening forward. But that will cause water to go into the horn during rain and washing. Link to post Share on other sites More sharing options...
Count-Bracula Twincharged May 21, 2012 Share May 21, 2012 The holes should be facing down. The horns spoil probably cuz water got in and got trapped inside the horn Bro, isn't front facing more effective? Louder por por? Will installing new horns mess up the car's electric circuit? Heard something about resistor to go with the installation. Link to post Share on other sites More sharing options...
Count-Bracula Twincharged May 21, 2012 Share May 21, 2012 No approved or not approved. Only air horns are NOT ALLOWED. Air horns don't install, just put it within reach on the dashboard. Lower window and blast! ooops! Link to post Share on other sites More sharing options...
Mllcg 3rd Gear May 21, 2012 Author Share May 21, 2012 Air horns don't install, just put it within reach on the dashboard. Lower window and blast! ooops! isnt there electric air horns? those connected to that little button? Link to post Share on other sites More sharing options...
Count-Bracula Twincharged May 21, 2012 Share May 21, 2012 isnt there electric air horns? those connected to that little button? Football air horns lah . . . . Link to post Share on other sites More sharing options...
Mllcg 3rd Gear May 21, 2012 Author Share May 21, 2012 Football air horns lah . . . . lol. but are the electronic air horns allowed? the high pitched ones Link to post Share on other sites More sharing options...
RadX Moderator May 21, 2012 Share May 21, 2012 Football air horns lah . . . . might as well blow the african horn vuvuzela Link to post Share on other sites More sharing options...
Count-Bracula Twincharged May 21, 2012 Share May 21, 2012 might as well blow the african horn vuvuzela Mr Radx, I don't mind if they are louder then the Steibels but seriously I'm having second thoughts about replacing the stock horns. ↡ Advertisement Link to post Share on other sites More sharing options...
6 people were arrested for car thefts from Jurong and Boon Lay carparks, including 16-year-old teen
Online purchase for car parts
i Wake Up Naked Today Morning
ODO Mileage Tampering
