WML888 2nd Gear April 26, 2012 Share April 26, 2012 Need help here. Is this normally caused by faulty Supercharger ? If not, what need to be fixed ? Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
KVR666 Neutral Newbie April 26, 2012 Share April 26, 2012 I don't own a Benz, but from the photo, that area you highlighted appears to be where the camshafts are. They should be attached to the sprockets where the timing chain/belt drives the cams. Could be a leak on the cover that encloses the timing chain/belt. Or could simply be a rocker cover gasket that's leaking. Your supercharger should be the unit attached on the right of the picture, where your air intake piping leads to. Link to post Share on other sites More sharing options...
Toledo 1st Gear April 26, 2012 Share April 26, 2012 i had a slow oil leak at the camshaft area. turned out to be the oil seals. just changed the seals yesterday. now monitoring if there's still leakage. btw my leakage is very slow one. 5000km lose abt 500ml (check from dipstick). Link to post Share on other sites More sharing options...
W210k 1st Gear April 26, 2012 Share April 26, 2012 That section highlighted has got nothing to do with the external supercharger module (where the CAI hose is directly connected to). That section is where the DOHCs are located. Valve/seal leakage likely. Get workshop to open up the cylinder head to check. Link to post Share on other sites More sharing options...
WML888 2nd Gear May 2, 2012 Author Share May 2, 2012 Update (May 12) : Changed the oil seal of cam sensor, and monitoring now... Should be ok. Thanks all ! Link to post Share on other sites More sharing options...
Imac 5th Gear February 19, 2016 Share February 19, 2016 Update (May 12) : Changed the oil seal of cam sensor, and monitoring now... Should be ok. Thanks all ! Hi, How much it cost to change the oil seal ? Mine is slightly oily. Link to post Share on other sites More sharing options...
Gnahp Turbocharged February 20, 2016 Share February 20, 2016 That's the infamous camshaft position sensors leak of the older M271 engine. the oil will mitigates along the wires, to the main harness and sometimes ECU and O2 sensors, throwing all kinds of error codes. Link to post Share on other sites More sharing options...
Imac 5th Gear February 22, 2016 Share February 22, 2016 That's the infamous camshaft position sensors leak of the older M271 engine. the oil will mitigates along the wires, to the main harness and sometimes ECU and O2 sensors, throwing all kinds of error codes. Yes...any sight of oily engine...should straight away go workshop to change the rubber seal/gasket....should not delay. Those who have changed, pls share your lobang and advise on the cost $..???? Thank you. ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
SCHNELL Engine Oil 5W40
Would you buy a high mileage E200K (W211) ?
