Mazdaowner Moderator April 26, 2012 Share April 26, 2012 On 4/26/2012 at 12:02 AM, Rainbowbiatch said: i dun have laa.. LOL!! u might wanna try calling AL-Tyres.. http://www.sgcarmart.com/directory/merchant.php?MID=11541 I PM him Euro girl. ↡ Advertisement Link to post Share on other sites More sharing options...
Rainbowbiatch 6th Gear April 26, 2012 Share April 26, 2012 On 4/26/2012 at 1:23 AM, Mazdaowner said: I PM him Euro girl. his rims got prob. and u PM a EURO GIRL???? [laugh] Link to post Share on other sites More sharing options...
Mazdaowner Moderator April 26, 2012 Share April 26, 2012 On 4/26/2012 at 1:26 AM, Rainbowbiatch said: his rims got prob. and u PM a EURO GIRL???? [laugh] My gym sessions are affecting me. Euro, girl, girl re: you. 5hrs sleep last night. Work. I PM him Euro RIms at Toh Guan. Link to post Share on other sites More sharing options...
5936 1st Gear April 26, 2012 Share April 26, 2012 Agree with you. 3 years left will be a waste on new rims. Can try Woodlands inidustrial park for second hand rims. or some bigger tyre retailers may also offer. Link to post Share on other sites More sharing options...
Thinthin Neutral Newbie April 27, 2012 Share April 27, 2012 (edited) On 4/25/2012 at 5:07 AM, Aimnfire said: can a damage rim such as slight warp or bend will cause a slow leak of air? my tire is leaking air slow about 3-5 psi per day the thing is, it is on a slight dent rim only during high speed balancing you can see the rim wobble previously same problem but after i change a new tyre and after about 4000km the problem resurface so back to the top sentence... Rims that are warped / dented often occurred when the wheel ran over humps / pot holes .This usually occur in the front . If the dents are minor , they could be sand down , build up weld and polish to restore . Ps look out for hairline cracks that could be disastrous if overlooked . Used rims often have "out of round" issues , the initial balancing will keep yr ride comfortable for awhile , however , after a while as the rims moved over more humps and uneven roads , the deterioration of material increased fatigue and ageing of the rims , the warpage increases , and that is the reason why the ride became "choppy" as it wear out . That is why it is very important to buy a good set of rims , and if there is no alternative but a used one , try to get one with a reputed brand . ( OEM and PRC rims uses low quality aluminium alloy which may not be robust and easily damage ) If a rim is warped ( usually out of round / concentricity ) , no matter what tyres u fit , leakage will occur . The rim needs to be re-machined on a lathe to correct its roundness and concentricity . If the Concentricity is too bad , the amount of material removal will be insufficient , the rim will have to be disgarded . Edited April 27, 2012 by Thinthin Link to post Share on other sites More sharing options...
13177 Hypersonic April 27, 2012 Share April 27, 2012 Am wondering for tyres, we need to change a brand new set according to usage. But how come we do not need to change rims? What is the lifespan for rims? If you are using the same rims on your car for 10 years or more, will the rims suddenly give way? Link to post Share on other sites More sharing options...
Aimnfire 4th Gear April 27, 2012 Author Share April 27, 2012 hey guys...and a gal included found the culprit that cause the leak it was a 2" screw stuck right in the middle of the tyre my mech plug the hole, after pulling the screw, let me drive for about 2 hours and then he took off my wheel and submerge it in basin full of water and observe any air bubble there is no air bubble but he then told me to monitor the situation for the warp rims he told me mine is not that bad Link to post Share on other sites More sharing options...
Aimnfire 4th Gear April 27, 2012 Author Share April 27, 2012 anyway thank you all for the suggestion i will keep the contacts for future use...thank you Link to post Share on other sites More sharing options...
Mazdaowner Moderator April 27, 2012 Share April 27, 2012 Like that ok lah, $5 bucks niah, compared to changing all rims. On 4/27/2012 at 12:44 PM, Aimnfire said: hey guys...and a gal included found the culprit that cause the leak it was a 2" screw stuck right in the middle of the tyre my mech plug the hole, after pulling the screw, let me drive for about 2 hours and then he took off my wheel and submerge it in basin full of water and observe any air bubble there is no air bubble but he then told me to monitor the situation for the warp rims he told me mine is not that bad Link to post Share on other sites More sharing options...
Aimnfire 4th Gear April 27, 2012 Author Share April 27, 2012 yalah....heng now hopefully 3 more years to go without any more major problem thks bro Link to post Share on other sites More sharing options...
Mazdaowner Moderator April 28, 2012 Share April 28, 2012 On 4/27/2012 at 6:20 PM, Aimnfire said: yalah....heng now hopefully 3 more years to go without any more major problem thks bro No worries, but you still have to change ties when the time comes. If selling or scrapping by then, get the used ones from that place I PM you. My friends did just that as well. Link to post Share on other sites More sharing options...
Slyver Neutral Newbie April 28, 2012 Share April 28, 2012 it may happen bro.. Link to post Share on other sites More sharing options...
Aimnfire 4th Gear April 28, 2012 Author Share April 28, 2012 thks MO Link to post Share on other sites More sharing options...
Edwinteo Clutched May 3, 2012 Share May 3, 2012 Hi all, Anyone here knows where can i weight my car rim? Link to post Share on other sites More sharing options...
0wnage 2nd Gear May 3, 2012 Share May 3, 2012 On 5/3/2012 at 11:45 AM, Edwinteo said: Hi all, Anyone here knows where can i weight my car rim? Remove the whole tyre & rim assembly and put on a weighing scale should do the job Weight of your tyre can be found on the spec sheet. Do some maths and you'll get the weight of your rim Link to post Share on other sites More sharing options...
Edwinteo Clutched May 3, 2012 Share May 3, 2012 haha..yap..but any shop does this service? If yes, how much? Link to post Share on other sites More sharing options...
Rainbowbiatch 6th Gear May 4, 2012 Share May 4, 2012 On 4/27/2012 at 12:44 PM, Aimnfire said: hey guys...and a gal included found the culprit that cause the leak it was a 2" screw stuck right in the middle of the tyre my mech plug the hole, after pulling the screw, let me drive for about 2 hours and then he took off my wheel and submerge it in basin full of water and observe any air bubble there is no air bubble but he then told me to monitor the situation for the warp rims he told me mine is not that bad hallelujah! ↡ Advertisement Link to post Share on other sites More sharing options...
Does rims change shape/warp over time?
Replacing a 2yrs old tyre?
Math Question
Math Question
Shipping USA Rims
Shipping USA Rims
Singapore Brand Rims VS China Brand Rims
