Aimnfire 4th Gear April 25, 2012 Share April 25, 2012 can a damage rim such as slight warp or bend will cause a slow leak of air? my tire is leaking air slow about 3-5 psi per day the thing is, it is on a slight dent rim only during high speed balancing you can see the rim wobble previously same problem but after i change a new tyre and after about 4000km the problem resurface so back to the top sentence... ↡ Advertisement Link to post Share on other sites More sharing options...
Mindbox33 1st Gear April 25, 2012 Share April 25, 2012 y not get a tyre shop n check if the rims is damaging ur tyres.. maybe 'loan' a spare rim fr ur tyre shop n install back ur tyre...for tat particular side. monitor..if tyre air remains good for 1 week..then easy to conclude the rim got prob..then change whole set lo. Link to post Share on other sites More sharing options...
Aimnfire 4th Gear April 25, 2012 Author Share April 25, 2012 thanks for the suggestion might be going to jb tomorrow for servicing and let the mech check if confirm...haiyah...burn money again Link to post Share on other sites More sharing options...
Mazdaowner Moderator April 25, 2012 Share April 25, 2012 thanks for the suggestion might be going to jb tomorrow for servicing and let the mech check if confirm...haiyah...burn money again Better then having an accident ok? Money isn't everything, safety for your life is priceless. Link to post Share on other sites More sharing options...
Aimnfire 4th Gear April 25, 2012 Author Share April 25, 2012 Better then having an accident ok? Money isn't everything, safety for your life is priceless. yalah i know its just...wrong timing Link to post Share on other sites More sharing options...
Mazdaowner Moderator April 25, 2012 Share April 25, 2012 yalah i know its just...wrong timing When I got my new car also wrong timing, 2 weeks niah, kana two nails, side wall, LPPL. Cannot repair, did temp repair, plugging, but got swollen, so best change new tire. Not worth the bloody scare every time you go at high speed, donno if tyre is going to explode or not. Worth to look into used rims, or have you checked your tyres, might have a puncture you didn't see. If you're in Jurong, Pioneer had two tyre shops, have them check for puncture etc. Link to post Share on other sites More sharing options...
Premroy Neutral Newbie April 25, 2012 Share April 25, 2012 You may try to repair your rims in jb to, quite cheap.. They's also respray and loan you a set to use. Link to post Share on other sites More sharing options...
Rainbowbiatch 6th Gear April 25, 2012 Share April 25, 2012 can a damage rim such as slight warp or bend will cause a slow leak of air? my tire is leaking air slow about 3-5 psi per day the thing is, it is on a slight dent rim only during high speed balancing you can see the rim wobble previously same problem but after i change a new tyre and after about 4000km the problem resurface so back to the top sentence... if u can see wobbling while they do speed balancing, means ur rims are warp already.. although there r options to repair warp rims, please try not to. the integrity of ur rims are compromise already.. quite dangerous imh.. just my 5cents. Link to post Share on other sites More sharing options...
5936 1st Gear April 25, 2012 Share April 25, 2012 I found that strange too. mine current and previous cars also experienced punctured just weeks after taken over new cars. Link to post Share on other sites More sharing options...
Mazdaowner Moderator April 25, 2012 Share April 25, 2012 I found that strange too. mine current and previous cars also experienced punctured just weeks after taken over new cars. ALMAK! Don't conspiracy theory leh?! [laugh] MIne was same tyre some more. Link to post Share on other sites More sharing options...
5936 1st Gear April 25, 2012 Share April 25, 2012 Twice can be forgiven. 3 times should be confirmed. But very unlikely to happen within these few years if I want to put hard earn $ to buy new car. Link to post Share on other sites More sharing options...
5936 1st Gear April 25, 2012 Share April 25, 2012 Minor problems can be repaired. Link to post Share on other sites More sharing options...
Aimnfire 4th Gear April 25, 2012 Author Share April 25, 2012 hey thanks sista long time no see btw Link to post Share on other sites More sharing options...
Aimnfire 4th Gear April 25, 2012 Author Share April 25, 2012 i try to check with my mech if it leak due to the rims anyway...car already 7 years still using stock rim to change rim now will be such a waste rather go for some cheap 2nd hand if i can find Link to post Share on other sites More sharing options...
Rainbowbiatch 6th Gear April 25, 2012 Share April 25, 2012 hey thanks sista long time no see btw but.. i never see u b4 leh.. or just get a 2nd hand rim to replace.. Link to post Share on other sites More sharing options...
Aimnfire 4th Gear April 25, 2012 Author Share April 25, 2012 your place got or not for 2nd hand rims Link to post Share on other sites More sharing options...
Mazdaowner Moderator April 25, 2012 Share April 25, 2012 your place got or not for 2nd hand rims You called that place I pm you yet for used rims and repairs? Link to post Share on other sites More sharing options...
Rainbowbiatch 6th Gear April 26, 2012 Share April 26, 2012 your place got or not for 2nd hand rims i dun have laa.. LOL!! u might wanna try calling AL-Tyres.. http://www.sgcarmart.com/directory/merchant.php?MID=11541 ↡ Advertisement Link to post Share on other sites More sharing options...
Does rims change shape/warp over time?
Replacing a 2yrs old tyre?
Math Question
Math Question
Shipping USA Rims
Shipping USA Rims
Singapore Brand Rims VS China Brand Rims
