Adrianli Hypersonic April 23, 2012 Share April 23, 2012 My battery ran out of juice today morning. Took urgent leave for the day and decided to charge it up by myself with my computerised charger. It took my charger 3hrs to fully charge the car battery. Put back 10,000mA of juice. Background is the power supply, converting AC to DC. Middle with lighted LCD screen is my computerised charger. Foreground is the car battery. After charging, its as good as new again!!! ↡ Advertisement Link to post Share on other sites More sharing options...
Happily1986 5th Gear April 23, 2012 Share April 23, 2012 My battery ran out of juice today morning. Took urgent leave for the day and decided to charge it up by myself with my computerised charger. It took my charger 3hrs to fully charge the car battery. Put back 10,000mA of juice. Background is the power supply, converting AC to DC. Middle with lighted LCD screen is my computerised charger. Foreground is the car battery. After charging, its as good as new again!!! Better monitor said battery for a few charging cycles to see whether it is able to retain charge normally and whether the discharging cycle is normal i.e. gradual and proportional to load. Link to post Share on other sites More sharing options...
Ngck 3rd Gear April 23, 2012 Share April 23, 2012 batter still quite new... no reason for it to die so soon Link to post Share on other sites More sharing options...
Longg8 Clutched April 23, 2012 Share April 23, 2012 probably need to check your alternator as well.... Link to post Share on other sites More sharing options...
LoverofCar 6th Gear April 23, 2012 Share April 23, 2012 Battery don't charge for no reason...better check your electrical system Link to post Share on other sites More sharing options...
Cephas 3rd Gear April 23, 2012 Share April 23, 2012 is the computerised charger expensive? it looked quite expensive in the background... Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged April 23, 2012 Share April 23, 2012 Bro adrianli... U have too any car cams running... Lol.. Link to post Share on other sites More sharing options...
Adrianli Hypersonic April 24, 2012 Author Share April 24, 2012 Better monitor said battery for a few charging cycles to see whether it is able to retain charge normally and whether the discharging cycle is normal i.e. gradual and proportional to load. The battery is still good. Just that my car cameras drained the battery. Did not drive the car since Fri, only tried to drive it on Monday morning. I would need to drive the car every alternate day to keep the battery charged. Link to post Share on other sites More sharing options...
Adrianli Hypersonic April 24, 2012 Author Share April 24, 2012 is the computerised charger expensive? it looked quite expensive in the background... To me, its mid-range price. Not sure to others. It cost ard S$350 for the charger and S$128 for the AC-DC power supply. Link to post Share on other sites More sharing options...
Fishy 4th Gear April 24, 2012 Share April 24, 2012 The battery is still good. Just that my car cameras drained the battery. Did not drive the car since Fri, only tried to drive it on Monday morning. I would need to drive the car every alternate day to keep the battery charged. do u use power magic? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic April 24, 2012 Share April 24, 2012 I think you standby a jumpstart kit in your car more convenient and cheaper. Link to post Share on other sites More sharing options...
Adrianli Hypersonic April 24, 2012 Author Share April 24, 2012 do u use power magic? Yes. I reviewed the recordings. On Saturday nite, the power magic cut in and recording stopped. So battery was at its lowest already. Further drain on battery due to other various car electronics over early sunday morning till monday morning. Therefore it ran out of juice when I wanted to start it. The measured voltage was 11.6v, not sufficient juice to crank the engine. Fully charged by my charger, it reads 12.6v, started on the very first crank. Alternator output voltage reading was 13.98v. Link to post Share on other sites More sharing options...
Adrianli Hypersonic April 24, 2012 Author Share April 24, 2012 I think you standby a jumpstart kit in your car more convenient and cheaper. I just need to make sure the car is driven every alternate day. If not driving for more than that, just pull out the cameras. Link to post Share on other sites More sharing options...
Ender Hypersonic April 24, 2012 Share April 24, 2012 Just another reason to play with your gadget (computerise charger).. Link to post Share on other sites More sharing options...
Mingsect 5th Gear April 25, 2012 Share April 25, 2012 Yes. I reviewed the recordings. On Saturday nite, the power magic cut in and recording stopped. So battery was at its lowest already. Further drain on battery due to other various car electronics over early sunday morning till monday morning. Therefore it ran out of juice when I wanted to start it. The measured voltage was 11.6v, not sufficient juice to crank the engine. Fully charged by my charger, it reads 12.6v, started on the very first crank. Alternator output voltage reading was 13.98v. hmmm, u set it to 12.6 or 12.8 ? Link to post Share on other sites More sharing options...
Adrianli Hypersonic April 25, 2012 Author Share April 25, 2012 hmmm, u set it to 12.6 or 12.8 ? Set what??? If u referring to my charger, I set to Pb(Sealed Lead Acid) and 6S(12v) charging. It reads the voltage from the battery and adjust the charging automatically. First hour, I noticed it was giving constant current(CC) of 13A and then after that gave constant voltage(CV) and peak voltage was 13.8v charging. After completed, I measured the voltage on the battery was 12.6v. Link to post Share on other sites More sharing options...
Happily1986 5th Gear April 25, 2012 Share April 25, 2012 The battery is still good. Just that my car cameras drained the battery. Did not drive the car since Fri, only tried to drive it on Monday morning. I would need to drive the car every alternate day to keep the battery charged. i see. that explains why. You are already using a battery which has higher rated capacity for a battery meant for Axio? Link to post Share on other sites More sharing options...
Happily1986 5th Gear April 25, 2012 Share April 25, 2012 Set what??? If u referring to my charger, I set to Pb(Sealed Lead Acid) and 6S(12v) charging. It reads the voltage from the battery and adjust the charging automatically. First hour, I noticed it was giving constant current(CC) of 13A and then after that gave constant voltage(CV) and peak voltage was 13.8v charging. After completed, I measured the voltage on the battery was 12.6v. Actually you are quite heng that it happened on a new battery or your battery was robust. Some car batteries i used, it seemed like once the remaining charge has dwindled beyond a certain threshold, the battery is as good as gone, unable to retain charge anymore. ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
Battery Voltage up & down
Amaron Battery
Amaron Battery
More MRT Lines Announced
Request for dark mode
