Kelpie 2nd Gear April 18, 2012 Share April 18, 2012 Hi all, Anyone know how to remove dried paint away from the dashboard (be it rubber or plastic) safely? Thank you very much. Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Nismo22 Neutral Newbie April 18, 2012 Share April 18, 2012 WD40 or equilivilant spray on then rub with cloth Link to post Share on other sites More sharing options...
Adrianli Hypersonic April 19, 2012 Share April 19, 2012 Nothing works like a bottle of thinner. Apply thinner on cloth and rub it on the paint. Link to post Share on other sites More sharing options...
KARTer 2nd Gear April 19, 2012 Share April 19, 2012 Nothing works like a bottle of thinner. Apply thinner on cloth and rub it on the paint. Won't the plastic dashboard react to thinner and turn dull-looking? Link to post Share on other sites More sharing options...
Adrianli Hypersonic April 19, 2012 Share April 19, 2012 Won't the plastic dashboard react to thinner and turn dull-looking? Dont think so if u do it quickly. And dont pour the thinner directly on the dashboard. Link to post Share on other sites More sharing options...
KARTer 2nd Gear April 19, 2012 Share April 19, 2012 Dont think so if u do it quickly. And dont pour the thinner directly on the dashboard. OIC. Thanks Link to post Share on other sites More sharing options...
Saabest 2nd Gear April 19, 2012 Share April 19, 2012 Question is: why did you manage to get paint onto the dashboard? Link to post Share on other sites More sharing options...
Skyiet27 Clutched April 19, 2012 Share April 19, 2012 Should be kerosene Thinner should be too strong May leave a Matt surface if lacquer comes off Key point is always put a bit on a clean cloth n test on small surface 1st Link to post Share on other sites More sharing options...
Adrianli Hypersonic April 19, 2012 Share April 19, 2012 Should be kerosene Thinner should be too strong May leave a Matt surface if lacquer comes off Key point is always put a bit on a clean cloth n test on small surface 1st Kerosene??? Have not tried that. Its either turpentine or thinner. Turpentine is milder but needs lots of rubbing before paint come off. Thinner, much faster. Thatz my experience. Link to post Share on other sites More sharing options...
Mazdaowner Moderator April 19, 2012 Share April 19, 2012 Yes there really is a way to do so. Hi all, Anyone know how to remove dried paint away from the dashboard (be it rubber or plastic) safely? Thank you very much. Regards, Link to post Share on other sites More sharing options...
Karebu 1st Gear April 19, 2012 Share April 19, 2012 u test the thinner first on a small area that's not too prominent la. if it fogs up then forget it. might be better off trying to scrape the paint off GENTLY. maybe rub with eraser Link to post Share on other sites More sharing options...
Skyiet27 Clutched April 19, 2012 Share April 19, 2012 Oh maybe it's turpertine hahaha Sorry sorry my bad These 3 always i mixed up Sorry sorry Link to post Share on other sites More sharing options...
Shawn123 Neutral Newbie April 20, 2012 Share April 20, 2012 I will help for this.I had a good experience with the Service Plus Auto Repair.They can help you in this case i am sure.they are providing very good new modern technologies in painting also.For more details please refer http://www.serviceplus416.com/ Link to post Share on other sites More sharing options...
Vertigoer Neutral Newbie April 21, 2012 Share April 21, 2012 Actually, those dish washing scrub (3m green color scrub) is pretty good at scrubbing off dry paint. Might want to try with some water. At least better than solvents. Link to post Share on other sites More sharing options...
Bigbadguy 1st Gear April 21, 2012 Share April 21, 2012 turpentine can be use to remove the paint on ur dashboard. but there is still a high chance u may matt ur dash board as u need a few good wipe before u can soften the paint and remove it. ↡ Advertisement Link to post Share on other sites More sharing options...
Colour Drive touch up paint
House painting
House painting
How to remove stubborn stain on windscreen?
