Kelpie 2nd Gear April 1, 2012 Share April 1, 2012 Hi all, Ok, I start 1st. I find that you need to turn off the car engine and use the car key to open up the petrol cap in Citroen C5. Troublesome and I wonder whether other cars have this feature as well. Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Eyke Supercharged April 1, 2012 Share April 1, 2012 (edited) I find that you need to turn off the car engine and use the car key to open up the petrol cap in Citroen C5. Ford Focus Mk1 as well, but then it was designed in 1998! Edited April 1, 2012 by Eyke Link to post Share on other sites More sharing options...
Tohto Hypersonic April 1, 2012 Share April 1, 2012 Hi all, Ok, I start 1st. I find that you need to turn off the car engine and use the car key to open up the petrol cap in Citroen C5. Troublesome and I wonder whether other cars have this feature as well. Regards, You already mentioned 'switch off engine '. Maybe this will prevent some driver from toppings up petrol with engine running Link to post Share on other sites More sharing options...
Mecontle 1st Gear April 1, 2012 Share April 1, 2012 my coupe's panoramic roof , too hot under sun but i know so many here will envy the car when it slides back on a foggy night Link to post Share on other sites More sharing options...
Kiadaw 6th Gear April 1, 2012 Share April 1, 2012 You already mentioned 'switch off engine '. Maybe this will prevent some driver from toppings up petrol with engine running You are right. Safety feature. My Fiat punto had this as well. But it can be irritating as I its very troublesome. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear April 1, 2012 Share April 1, 2012 Hi all, Ok, I start 1st. I find that you need to turn off the car engine and use the car key to open up the petrol cap in Citroen C5. Troublesome and I wonder whether other cars have this feature as well. Regards, My Panda uses a different key for petrol cap. So not useful to steal such car. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear April 1, 2012 Share April 1, 2012 The most useless feeature in my car? Its over designed! The speedo shows 180Km/hr....but the max I ever use is 120km/hr. Completely ovverpaid for a feature that I dare and will not use. The airbags is another useless feature, that is never used and therefore useless. If you really strictly want the serve no purpose item in the car? there is non in my most basic jazz. Prhaps there will be many redundant features in the conti upmarket cars, that may not be useful in Singapore at all. Like heated seats, and heater air con, etc. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear April 1, 2012 Share April 1, 2012 my coupe's panoramic roof , too hot under sun but i know so many here will envy the car when it slides back on a foggy night I believe not many can see through the foggy night[laugh] Link to post Share on other sites More sharing options...
Happily1986 5th Gear April 1, 2012 Share April 1, 2012 You are right. Safety feature. My Fiat punto had this as well. But it can be irritating as I its very troublesome. troublesome? do you not switch off the engine before you pump petrol? Link to post Share on other sites More sharing options...
Kiadaw 6th Gear April 1, 2012 Share April 1, 2012 troublesome? do you not switch off the engine before you pump petrol? The use the key to open the cap part. Key cannot be removed while the fuel cap is not close, so you have to be careful that the key is not accidentally dip in fuel when you pump. But yeah, the good thing is that you can be sure the cap is close properly when you drive off your car. You never have the situation (which happen to forgetful me a lot) of "Did I close the fuel cap just now?, or "did I check the pump specialist close the cap properly" 5 mins after driving off the pump station. Link to post Share on other sites More sharing options...
Vega Turbocharged April 1, 2012 Share April 1, 2012 My car come with seat heater. Totally useless. I rather they put aircon like the gs300. Link to post Share on other sites More sharing options...
Kelpie 2nd Gear April 1, 2012 Author Share April 1, 2012 (edited) You are right. Safety feature. My Fiat punto had this as well. But it can be irritating as I its very troublesome. Not so safe, IMHO. Just invite people to steal your car more easily with the key hook to the cap and then drive away. Certainly not a welcoming feature in Bolehland . Regards, Edited April 1, 2012 by Kelpie Link to post Share on other sites More sharing options...
RadX Moderator April 1, 2012 Share April 1, 2012 in Singapore, signal indicators...never used....might as well take it out of car 1 Link to post Share on other sites More sharing options...
Happily1986 5th Gear April 1, 2012 Share April 1, 2012 The use the key to open the cap part. Key cannot be removed while the fuel cap is not close, so you have to be careful that the key is not accidentally dip in fuel when you pump. But yeah, the good thing is that you can be sure the cap is close properly when you drive off your car. You never have the situation (which happen to forgetful me a lot) of "Did I close the fuel cap just now?, or "did I check the pump specialist close the cap properly" 5 mins after driving off the pump station. i feel that you might be appreciative if you stay in an area where fuel theft/siphoning is common. Maybe irrelevant in sg or germany. maybe. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear April 1, 2012 Share April 1, 2012 serve no purpose function? speed cut. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged April 1, 2012 Share April 1, 2012 in Singapore, signal indicators...never used....might as well take it out of car Don't lidat, I at least signal 3 times wen chg lane n keep it on wen turning... Give chan wil u? Link to post Share on other sites More sharing options...
RadX Moderator April 1, 2012 Share April 1, 2012 Don't lidat, I at least signal 3 times wen chg lane n keep it on wen turning... Give chan wil u? meant to be a joke, but seriously, how many like u? Just scout and you see that it is never used for the right reason. Link to post Share on other sites More sharing options...
Vulcann 6th Gear April 1, 2012 Share April 1, 2012 Useless feature? Speedometers..... ....for roadhoggers & chiongsters! ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Feb 2025
Missing Chinese actor Wang Xing found in Myanmar's notorious scam factory KK Park
Two dead bodies found in Kovan
COE Bidding - January 2025
2024 Suzuki Swift
2024 Suzuki Swift
Australia: Car Rental in Melbourne
