Deckbuild 6th Gear March 26, 2012 Share March 26, 2012 Anyone have any problem pumping RON 97 for their SSS? ↡ Advertisement Link to post Share on other sites More sharing options...
C-K 2nd Gear March 26, 2012 Share March 26, 2012 IF the car isn't heavily modded, there shouldn't be any problems. There's knock sensor to retard the ignition timing when lower-octane fuel starts to cause the knocking/pinging. My friend even pumps in 95 in his stock SSS sometimes to save $$$. 1 Link to post Share on other sites More sharing options...
Deckbuild 6th Gear March 26, 2012 Author Share March 26, 2012 IF the car isn't heavily modded, there shouldn't be any problems. There's knock sensor to retard the ignition timing when lower-octane fuel starts to cause the knocking/pinging. My friend even pumps in 95 in his stock SSS sometimes to save $$$. Ic, but still it's harmful to the piston right? thanks for your reply! Link to post Share on other sites More sharing options...
ER-3682 Supersonic March 26, 2012 Share March 26, 2012 Ic, but still it's harmful to the piston right? thanks for your reply! 1 octane is nothing...no problem,Malaysia got so many high performance cars,all pumped 97. Link to post Share on other sites More sharing options...
Dscheng 3rd Gear March 26, 2012 Share March 26, 2012 I also pump 97 for my Rex. I even see GTR pump at Jb too le. 1 Link to post Share on other sites More sharing options...
Zniper 2nd Gear March 26, 2012 Share March 26, 2012 come on la TS.... did u read ur manual??? i believe 95 oso can go as long as u dun tune ur car wif piggyback ECU which tune to only can use certain octance (usually is 98)... if so scare, pls dun drive... seen more higher end cars pump 97 or even 95 in sg b4... duhz... 1 Link to post Share on other sites More sharing options...
Longg8 Clutched March 26, 2012 Share March 26, 2012 come on la TS.... did u read ur manual??? i believe 95 oso can go as long as u dun tune ur car wif piggyback ECU which tune to only can use certain octance (usually is 98)... if so scare, pls dun drive... seen more higher end cars pump 97 or even 95 in sg b4... duhz... why are you so critical of a car lover? haha... good for the next owner... 1 Link to post Share on other sites More sharing options...
Route88 2nd Gear March 26, 2012 Share March 26, 2012 Anyone have any problem pumping RON 97 for their SSS? Why must it be any problem ? 1 Link to post Share on other sites More sharing options...
Deckbuild 6th Gear March 26, 2012 Author Share March 26, 2012 come on la TS.... did u read ur manual??? i believe 95 oso can go as long as u dun tune ur car wif piggyback ECU which tune to only can use certain octance (usually is 98)... if so scare, pls dun drive... seen more higher end cars pump 97 or even 95 in sg b4... duhz... Bro, haven't buy, don't get so worked up, Im planning, need to find out more :) Link to post Share on other sites More sharing options...
ER-3682 Supersonic March 26, 2012 Share March 26, 2012 No worries,Suzuki's engine quite tough,nothing will happen.... Link to post Share on other sites More sharing options...
Huntsman Neutral Newbie March 27, 2012 Share March 27, 2012 I have pumped RON 97 in Malaysia. And to satisfy my OCD I add a bottle of octane booster. I feel that V Power Racing in Malaysia works the best. I experienced a smooth ride, engine revvs faster. Link to post Share on other sites More sharing options...
Pocus Turbocharged March 27, 2012 Share March 27, 2012 I also pump 97 for my Rex. I even see GTR pump at Jb too le. REX / GTR compression ratio is lower at 8 to 9 due to their TC nature, so no issue. SSS is NA and tuned for higher octance fuel with compression ratio of 11.1 That's why it's more sensitive. Link to post Share on other sites More sharing options...
Cdior 1st Gear March 27, 2012 Share March 27, 2012 REX / GTR compression ratio is lower at 8 to 9 due to their TC nature, so no issue. SSS is NA and tuned for higher octance fuel with compression ratio of 11.1 That's why it's more sensitive. dont talk co(k lah stock car sure no problem. my frens with dc5r n celica ss2, both @ 11.5 no problem pumping 97. Link to post Share on other sites More sharing options...
ZaC71S 1st Gear March 27, 2012 Share March 27, 2012 Bro, haven't buy, don't get so worked up, Im planning, need to find out more :) hi bro. yeah SSS manual indicates ron 98 bdue to the compression ratio. but for me, i have been using petronas 97 since 2 years back and so far so gd bro. only once or twice a year i pump shell 98 or vpower if got promotion. as long as u avoid 95, shud be fine mah. den again, ppl can say any ron also can. yup can means can but at the end of the day if engine ping n spoil, u are the one paying for maintainence. so juz do wats deem right bro. Link to post Share on other sites More sharing options...
Huntsman Neutral Newbie March 27, 2012 Share March 27, 2012 Have heard from friends who experimented with lower RONs. 92 and 95 all produce knocking. Sounds like the pistons are knocking the bonnet. The car still runs but they tell me that it is not as responsive. Link to post Share on other sites More sharing options...
Cwk 1st Gear March 27, 2012 Share March 27, 2012 Have heard from friends who experimented with lower RONs. 92 and 95 all produce knocking. Sounds like the pistons are knocking the bonnet. The car still runs but they tell me that it is not as responsive. If there's any knocking, it's in the head. Petrol companies make fools of you people. Link to post Share on other sites More sharing options...
Cdior 1st Gear March 27, 2012 Share March 27, 2012 If there's any knocking, it's in the head. Petrol companies make fools of you people. it will knock with 92 & 95. we r not talking about family car here. Link to post Share on other sites More sharing options...
Pocus Turbocharged March 27, 2012 Share March 27, 2012 dont talk co(k lah stock car sure no problem. my frens with dc5r n celica ss2, both @ 11.5 no problem pumping 97. Hey wtf pal, I only say sensitive I never say cannot. why so hostile??? ↡ Advertisement Link to post Share on other sites More sharing options...
New Sports Hub Name
New Sports Hub Name
Feedback
Feedback
Swift Owners
Swift Owners
Congrats to Aloysius Yapp.New UK Nineball Champion 🙌🏻
Fuel Pump
Fuel Pump
McLaren entry level sports car, 570S and its related series
