Yeobh 4th Gear March 14, 2012 Share March 14, 2012 Apparently the engine fuel injection may have over exceed the fuel volume injected but fail to cut out resulting in engine over run . The out of balance rotating force may have caused one of the con-rod to crash against the engine block crankcase. ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 14, 2012 Share March 14, 2012 power sia................ Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 14, 2012 Share March 14, 2012 On 3/14/2012 at 11:27 AM, Yeobh said: Apparently the engine fuel injection may have over exceed the fuel volume injected but fail to cut out resulting in engine over run . The out of balance rotating force may have caused one of the con-rod to crash against the engine block crankcase. catastrophic failure indeed. is it a one time failure or could it be a cumulative failure i.e. progressive thinning of the cylinder till one fine day BAM! no idea of what sort of mod the fella did too. Cylinder reboring, NOS etc possible causes? Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 14, 2012 Author Share March 14, 2012 If the cause is not cause by engine over run, then the next possibilty is a loose con-rod bolt not properly torque or lock. Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 14, 2012 Share March 14, 2012 (edited) On 3/14/2012 at 12:31 PM, Yeobh said: If the cause is not cause by engine over run, then the next possibilty is a loose con-rod bolt not properly torque or lock. when you say engine over run, does it mean that the fella actually disable the engine rev limiter? how about hydro lock? possible? i know hydrolock have kaput many engine blocks because piston engines work on compression and water is darn hard to be compressed so during compression phase, BAM valves bent. Edited March 14, 2012 by Happily1986 Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 14, 2012 Author Share March 14, 2012 All engine programs have default on engine max rpm , fuel injection time etc Some after market programmer may try to exceed the max limit allowable hopefully to get more hp. Yes hydraulic lock is common when coolant leaks into the compression chambers.Since water cannot be compressed, some other mechanical parts must give way - most of the time resulting in damage pistons crown , bend con-rods and crack/wrap cylinder head. Link to post Share on other sites More sharing options...
Fu11thr0tt1e Turbocharged March 14, 2012 Share March 14, 2012 Remap Problems, cause and effect ? In an already overly saturated market place the Remap Engine Tuning industry has already seen its fair share of winners and losers, from catastrophic engine failure to minor niggles, all are unwelcome in the Remap Engine Tuning Arena. With so many companies out there it is difficult to know where to even start, never mind who you choose to trust with your 1 Link to post Share on other sites More sharing options...
Yuan 6th Gear March 14, 2012 Share March 14, 2012 On 3/14/2012 at 1:03 PM, Yeobh said: All engine programs have default on engine max rpm , fuel injection time etc Some after market programmer may try to exceed the max limit allowable hopefully to get more hp. Yes hydraulic lock is common when coolant leaks into the compression chambers.Since water cannot be compressed, some other mechanical parts must give way - most of the time resulting in damage pistons crown , bend con-rods and crack/wrap cylinder head. Together with your first post, thanks for sharing such information. Link to post Share on other sites More sharing options...
5936 1st Gear March 14, 2012 Share March 14, 2012 I always ave reservations abt disturbing engine program. This is just add to my list, and even more convinced to avoid at all cost. Link to post Share on other sites More sharing options...
MacDuck 1st Gear March 14, 2012 Share March 14, 2012 How about "stage 1" tune from reputable tuners? Esp conti makes. Link to post Share on other sites More sharing options...
Briansoh 1st Gear March 14, 2012 Share March 14, 2012 I think if they are from reputable dealers like ABT and so on they should be fine. However, you still have to ask some questions and be abit knowledgeable about these kinda things. Maps cant really be "universal" as each country/region has different parameters such as air temp, humidity etc that will play a part in how the car will perform. Knowing and controlling what goes into your car's ecu is ultimately your safest bet but if you dont have the technical knowledge, then of course reputable tuners are your next best alternative. Link to post Share on other sites More sharing options...
Mecontle 1st Gear March 14, 2012 Share March 14, 2012 i dont tune my car since i change brand new ride before warranty is up, tuning is best left for near scrap car where its either give it all u can or trash it entirely in the scrapyard Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 14, 2012 Share March 14, 2012 me know of a friend who lup a turbo into a NA car. End result is what exactly shown here cos he has over boost it to 2 bar............. Link to post Share on other sites More sharing options...
Kangadrool Supersonic March 14, 2012 Share March 14, 2012 Always stick to stock. If need performance, buy a performance car. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear March 14, 2012 Share March 14, 2012 Sometimes towing a car drown in a flood with its gears enganged can also result in almost similar damage to engine (seen one in a workshop after the first flooding at one basement carpark in Bukit Timah a few years back) Link to post Share on other sites More sharing options...
Lim1982 Neutral Newbie March 14, 2012 Share March 14, 2012 This looks like a failure Conrod breaking from force induction,looks like the 1nzfe to me.... Link to post Share on other sites More sharing options...
Yuan 6th Gear March 15, 2012 Share March 15, 2012 On 3/14/2012 at 4:35 PM, Kangadrool said: Always stick to stock. If need performance, buy a performance car. I agree. Sometimes it also depends on the driver and not the car. Link to post Share on other sites More sharing options...
Adrianli Hypersonic March 15, 2012 Share March 15, 2012 This looks exactly what happened to a marine engine when its con-rods bottom end bearing was not tightened properly. Was running in the completely re-built engine. At lower rpm, all was good. When at higher rpm, the con-rod gave way. Smashing thru the engine block. Had to scrap the whole engine. ↡ Advertisement Link to post Share on other sites More sharing options...
Piano - moving piano
Audi tuning by PA
Audi tuning by PA
SCHNELL Engine Oil 5W40
