Congxdead Clutched February 5, 2012 Share February 5, 2012 hi fellow mates . during cny period went to NSHW. My crusing speed was above average at 130km/h all the way till muar. Nothing happens till i rch sg. The engine check light appears. Went to my nearby workshop to diagnosis it and was given a error code as o2 sensor defaultive. I was told that my car has a 2 o2 sensor position? Everything ended within 3mins, and was told to paid a fee of $50?! just to check the error code. So i would like to ask if it is normal to pay these amt of fee just to check whats the error code? thanks in advance.and btw, o2 sensor costing ard 250 normal? ↡ Advertisement Link to post Share on other sites More sharing options...
5936 1st Gear February 5, 2012 Share February 5, 2012 (edited) On high side for 3min svc. That also included rental for the diagnostic equipment. Once electronic gadget is involved, its "professional svc" fee. now that you know it's O2 sensor, you can go to your choiced or preferred workshop. Edited February 5, 2012 by 5936 Link to post Share on other sites More sharing options...
Gnahp Turbocharged February 5, 2012 Share February 5, 2012 I bought this simple OBD II scanner from ebay for S$30+ Scan and erase codes to your heart's content. Link to post Share on other sites More sharing options...
Congxdead Clutched February 6, 2012 Author Share February 6, 2012 btw how much does a o2 sensor cost? Link to post Share on other sites More sharing options...
Solar Turbocharged February 6, 2012 Share February 6, 2012 On 2/5/2012 at 10:52 PM, Phang said: I bought this simple OBD II scanner from ebay for S$30+ Scan and erase codes to your heart's content. hey bro.. can scan and erase codes for all car types? i got an irritating intermittent CEL for a faulty cruise control, that i never use.. wanna go workshop erase but buay gam wan spend $$$ for a few minutes job Link to post Share on other sites More sharing options...
Kb27 Supersonic February 6, 2012 Share February 6, 2012 On 2/6/2012 at 3:53 AM, Solar said: hey bro.. can scan and erase codes for all car types? i got an irritating intermittent CEL for a faulty cruise control, that i never use.. wanna go workshop erase but buay gam wan spend $$$ for a few minutes job Most, if not all, OBDII reader can read error codes and erase CEL. However, it must first be able to talk to your car ECU with the right protocol. If it can't, then it's useless. Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 6, 2012 Share February 6, 2012 If you purchase code readers or scanners sold in US market, chances they are designed for the US manufactured cars including the Asian brands. They will not be able to fully communicate with cars manufactured in Europe, Asia, Japan export and Japan domestic. Europe cars are using EOBD protocol which is slightly different in the 16pin ODB2 socket configuration. Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 7, 2012 Share February 7, 2012 (edited) It is best not to 100% trust the code reader info. Since o2 sensor are expensive components, I suggest you request yr mech to do a o2 sensor simulation test ( chances of finding a shop with such tester maybe NIL). The problem can be due to other the fuel system components malfuctioning. Edited February 7, 2012 by Yeobh Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 7, 2012 Share February 7, 2012 Nobody works for free except one old man from Finland during christmas time Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged February 7, 2012 Share February 7, 2012 I am sure the car model plays a part in relation to the cost. I know if mazda mod or change exhaust, the cel will light up once a while Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 11, 2012 Share February 11, 2012 (edited) "Dealing with the Dreaded CEL "( Check Engine Light) http://toolmonger.com/2012/02/10/dealing-w...he-dreaded-cel/ Edited February 11, 2012 by Yeobh Link to post Share on other sites More sharing options...
Kianbeng Clutched February 11, 2012 Share February 11, 2012 There are so many causes that results in O2 Sensor CEL. How many km have you ran without changing O2 sensors? They are normally good for 100k. It could also be due to MAF sensor's fault. If you are quite inclined with these mechanical stuff, you might want to see which part is the cheapest and the oldest part in your car. If not, I think it's still best to send it to the workshop (most likely will tell you to change all 3 items). for my car, the MAF and the O2 sensors each cost $50+. Link to post Share on other sites More sharing options...
Congxdead Clutched February 14, 2012 Author Share February 14, 2012 On 2/11/2012 at 9:38 AM, Kianbeng said: There are so many causes that results in O2 Sensor CEL. How many km have you ran without changing O2 sensors? They are normally good for 100k. It could also be due to MAF sensor's fault. If you are quite inclined with these mechanical stuff, you might want to see which part is the cheapest and the oldest part in your car. If not, I think it's still best to send it to the workshop (most likely will tell you to change all 3 items). for my car, the MAF and the O2 sensors each cost $50+. my car o2sensors cost 250. reasonable? driving swift sports Link to post Share on other sites More sharing options...
Loveisallaround Neutral Newbie February 15, 2012 Share February 15, 2012 On 2/5/2012 at 12:39 PM, Congxdead said: hi fellow mates . during cny period went to NSHW. My crusing speed was above average at 130km/h all the way till muar. Nothing happens till i rch sg. The engine check light appears. Went to my nearby workshop to diagnosis it and was given a error code as o2 sensor defaultive. I was told that my car has a 2 o2 sensor position? Everything ended within 3mins, and was told to paid a fee of $50?! just to check the error code. So i would like to ask if it is normal to pay these amt of fee just to check whats the error code? thanks in advance.and btw, o2 sensor costing ard 250 normal? So far when I go to workshops to do a check for such checks, they don't charge me, especially if it is the workshop I frequent, I guess this workshop really want to carrot you....$50 for a 3 minute check seems abit excessive Link to post Share on other sites More sharing options...
Kianbeng Clutched September 17, 2012 Share September 17, 2012 On 2/14/2012 at 2:28 PM, Congxdead said: my car o2sensors cost 250. reasonable? driving swift sports Is this the price from the workshop or from the suzuki swift stockist? $250 for a O2 sensor is quite expensive. O2 sensors are usually quite similar in function/design. I dunno maybe just the size / screw thread is different? And maybe the cable length is different? There are also a few categories of O2 sensors but mine at $50, is already one with the built in heater..... I heard O2 sensors cost 200+ in JB but thats in Ringgit!! ↡ Advertisement Link to post Share on other sites More sharing options...
Man who removed bus stop bench to check its dimensions for f
Kia Cerato GT Line Owners Check In
