Fennmax Clutched February 4, 2012 Share February 4, 2012 Anyone tried diy using contact cleaner to clean O2sensor at the maf housing? Any tips or precaution. ↡ Advertisement Link to post Share on other sites More sharing options...
Kb27 Supersonic February 4, 2012 Share February 4, 2012 I used Amsoil Power Foam, although it states not to use on MAF. I just found it is able to clean through tough coatings which contact cleaner cannot removed. I guess the precaution is not to spray on the MAF when it is hot. Let it cool off first if necessary. Do not switch on ignition. Spraying into the housing may not be effective either. I would take out the MAF and spray directly on the film or wire. Link to post Share on other sites More sharing options...
Congxdead Clutched February 4, 2012 Share February 4, 2012 sry for OT,but may i know how much does a o2 sensor cost? Link to post Share on other sites More sharing options...
Rb26dett Clutched February 5, 2012 Share February 5, 2012 i use this ows universal cleaner. so far so good.just spray , let it drip and let it dry .then put back. Link to post Share on other sites More sharing options...
Thedream 3rd Gear February 5, 2012 Share February 5, 2012 On 2/4/2012 at 10:46 AM, Kb27 said: I used Amsoil Power Foam, although it states not to use on MAF. I just found it is able to clean through tough coatings which contact cleaner cannot removed. I guess the precaution is not to spray on the MAF when it is hot. Let it cool off first if necessary. Do not switch on ignition. Spraying into the housing may not be effective either. I would take out the MAF and spray directly on the film or wire. I think this leaves a protective coating which is supposed to prevent rust/grease... but what you need is something that doesn't leave any residue, otherwise, your MAF sensor will not be able to sense the oxygen properly especially if you keep applying the foam... Link to post Share on other sites More sharing options...
Thedream 3rd Gear February 5, 2012 Share February 5, 2012 On 2/5/2012 at 4:18 AM, Rb26dett said: i use this ows universal cleaner. so far so good.just spray , let it drip and let it dry .then put back. yeah, my workshop uses this... Link to post Share on other sites More sharing options...
Kb27 Supersonic February 5, 2012 Share February 5, 2012 On 2/5/2012 at 5:12 AM, Thedream said: I think this leaves a protective coating which is supposed to prevent rust/grease... but what you need is something that doesn't leave any residue, otherwise, your MAF sensor will not be able to sense the oxygen properly especially if you keep applying the foam... That's true. After I used Amsoil Power Foam, I did go over with a no-residual contact cleaner. Thanks for the reminder. Link to post Share on other sites More sharing options...
Fennmax Clutched February 6, 2012 Author Share February 6, 2012 thanks. anyone use only non residue contact cleaner for elrctronic on the o2 sensor. due for major svc so intend to change all fluids n clean all essentials. Link to post Share on other sites More sharing options...
Gasguzzler 1st Gear February 6, 2012 Share February 6, 2012 I use CRC MAF sensor cleaner. Clean it once every 2 months. Link to post Share on other sites More sharing options...
Ckchong8 1st Gear February 6, 2012 Share February 6, 2012 On 2/6/2012 at 1:17 PM, Gasguzzler said: I use CRC MAF sensor cleaner. Clean it once every 2 months. Hi Bro, What the purpose of cleaning the 02 sensor ? Mind to show the knowhow too. many thanks Link to post Share on other sites More sharing options...
Gasguzzler 1st Gear February 6, 2012 Share February 6, 2012 (edited) On 2/6/2012 at 1:23 PM, Ckchong8 said: Hi Bro, What the purpose of cleaning the 02 sensor ? Mind to show the knowhow too. many thanks Actually, I don't quite understand what TS means by o2 sensor in the MAF housing. I'm just assuming it's the MAF that he is talking about. o2 sensor is normally located at the exhaust manifold area. I don't clean my o2 sensor, only the MAF sensor. Edited February 6, 2012 by Gasguzzler Link to post Share on other sites More sharing options...
Gasguzzler 1st Gear February 6, 2012 Share February 6, 2012 To clean the MAF sensor, simply unplug the electrical connector, remove the MAF sensor, spray it with a proper MAF sensor cleaner and reinstall it. I won't recommend CARB cleaner though I know many workshops use it (STP CARB cleaner). They don't sell CRC MAF cleaner in stores. You will have to order from the supplier. Link to post Share on other sites More sharing options...
Rb26dett Clutched February 13, 2012 Share February 13, 2012 On 2/5/2012 at 5:14 AM, Thedream said: yeah, my workshop uses this... BKS? Link to post Share on other sites More sharing options...
Thedream 3rd Gear February 14, 2012 Share February 14, 2012 On 2/13/2012 at 4:28 PM, Rb26dett said: BKS? Link to post Share on other sites More sharing options...
Steve111 Neutral Newbie February 14, 2012 Share February 14, 2012 To clean o2 sensor, Steps: Get under your car and remove the O2 sensor. If you are unsure how to do this, please see the Resources section. Check the O2 sensor for cut wires or other damage. If a visual inspection shows damage, then you will need to buy a new sensor. Place the O2 sensor into the canister. Pour in enough gasoline to cover the device. When done, close the lid so that the gasoline doesn't evaporate. Swirl the canister to agitate the gasoline. Doing so forces the gasoline into the O2 sensor and allows it to reach all the dirt and grime. Place the canister in a cool, dry place, and let it sit overnight. The next day, swirl the canister again to dislodge any dirt that has loosened in the sensor. Let sit another couple of hours. Put on a pair of rubber gloves and remove the O2 sensor from the canister. Use paper towels to dry off the device. Once dry, place the sensor back into the engine. Job done. Link to post Share on other sites More sharing options...
Drive 1st Gear February 14, 2012 Share February 14, 2012 On 2/6/2012 at 1:17 PM, Gasguzzler said: I use CRC MAF sensor cleaner. Clean it once every 2 months. Hi Where to buy this MAF cleaner locally? Link to post Share on other sites More sharing options...
Fennmax Clutched February 14, 2012 Author Share February 14, 2012 I bought Mr mckenic contact cleaner fm carrefour. Cleaned n installed. Works well. Link to post Share on other sites More sharing options...
Thedream 3rd Gear February 16, 2012 Share February 16, 2012 actually, my workshop doesn't charge me extra when i ask them to wash my MAF sensor. You guys may want to check with your workshop... ↡ Advertisement Link to post Share on other sites More sharing options...
Any recomendation for Robot cleaner??
SONAX rim cleaner
SONAX rim cleaner
DPF Cleaner
DPF Cleaner
Plastic Trim Cleaner and Restorer
STP fuel system cleaner vs HKS DDR
Dust Mite
Dust Mite
Vacuum Cleaner
Vacuum Cleaner
