How problematic is VW's 7 speed DSG?
Kar_lover
  On 10/18/2021 at 9:58 AM, Daniu82 said:
Just 1 question, what’s the difference between DSG and the s tronic used by Audi? How abt BMW’s steptronic and Merc’s DCT? I am comparing these gearboxs used by entry level cars by these brands? I searched online and saw that basically DCT, DSG and s tronic are the same, just different naming. Can anyone enlighten me?
Expand
Depends on what you are referring to. No complains for BMW gearbox so far. Most BMWs are using ZF8 speed gearbox which is not a dual-clutch transmission but it is damn solid.
  • Praise 2
Expand
yeah ... BMW high end model uses 8sp ZF ... awesome [thumbsup]
low end model uses 6sp Aisin (discontinue?) and now uses Getrag (7DCT) for BMW 1 & 2 series?
Edited by Wt_know
  On 10/18/2021 at 3:13 PM, Wt_know said:
yeah ... higher end model uses ZF ... lower end model uses Aisin (Japan) and Getrag
Expand
It kind of depends on which model you go for. For example F20 uses ZF8 even though it's the entry level model. My current and previous BMW use ZF8 and it is simply incredible.
But yes, most newer entry level models are using Getrag 7 speed DCT. So far haven't had bad stuff about it regarding reliability unlike VW...
Edited by CPT_James_T_Kirk
actually, all gearbox manufacturer are good ... the main problem is DRY vs WET
DRY ... fast shifting and A LOT cheaper to make
but ... DRY cannot last long .... WET better ... can push and push ... muahahahaha
Edited by Wt_know
@CPT_James_T_Kirk been driving my 218i for a while now. not sure if its aisin or getrag but its wayyy better than my previous A200 (despite the >20bhp difference)..
Reliability wise, so far no issue but maybe i should only give a judgment in a couple years time ðŸ˜‚
Edited by hsolo89
Expand
F22,218i.?or the latest Gran Coup.?
  On 10/18/2021 at 10:10 AM, Wt_know said:
it's the legendary DQ200 dry clutch gearbox
VW, Seat, Skoda and Audi ... all are affected if fitted with DQ200
not sure whether BMW and Merc got used "dry"
dry vs wet  ... that's the difference
for VW/Audi as long as the torque is above 250Nm ... no scare because it is not DQ200 (max torque 250Nm)
Expand
So you mean it's not only the DQ200 problem, if other brands like BMW, Merc or even more common brands like Hyundai or Kia using dry DCT, DSG etc also will have problem right?
Expand
that's my opinion only
but didn't heard much complain from the kimchi car
this mean kimchi make better DRY than amdk DRY ... lol
  • Haha! 1
  On 10/18/2021 at 3:09 PM, CPT_James_T_Kirk said:
The salesman will always say it was solved last year. The service was pretty good though, but reliability is insanely bad...
Expand
I agreed service is good. As long as you can demo the failure, VW will repair for you. For my experience, brought the car in 2018. Changed the clutch about 1 year later. There is a tong sound during gear change from 2-3. Change the MU last year. Practically stuck in 2nd gear. Cannot start the car. The display is saying move to Gear 1 to start car. Then toll back for repair. Practically every year "staycation" in service centre. Sold the car early this year.
Avoid DCT in my next car. If you know how dual clutch work, it is what it is. The constant pre-clutch engagement and disengagement is main cause of the failure. It helps on the FC and drive feel. DCT is cheap to the manufacturer. You need to accept the repair cost if you decided on DCT. It is not only on VW. My frd driving Alfa also having same problem.
However the repair is definitely cheaper. Made in China MU and Clutch is easily available. No longer rebuild the clutch locally. I see a repair on DSG from a Taiwan Youtuber. It is about S$1k for the component import from China. plus a few hundred for the clutch oil/fluid  and etc. Plus Manpower cost. After repair, it will last another 100k
  • Praise 2
Expand
Get normal gearbox car lah... why get stuck on the road while rushing to pick up your angry galfren?
  • Haha! 4
