Elfenstar 3rd Gear December 20, 2011 Share December 20, 2011 (edited) so for my WRX, pump front more air or rear more air? WRX's naturally understeer, however i get the impression they are a little more susceptible to lift-off/snap oversteer which would put you in a little bit of a conundrum. If its what I described, try increasing the pressure all around by around 2psi (approx 240kpa altogether). The fronts to reduce the amount of dive on braking, and the rears to increase lateral grip. I wouldn't want you to oversteer less when you transfer weight to the front at the expense of more understeer under normal circumstances. If its just oversteering normally, then increase the pressure at the rears by 1psi and try, and if it feels better, then increase again and again by 1psi to the point you feel its handling becomes more neutral. As there is a limit to what tyre pressures can do, I would also suggest you read the following articles. I suspect this might be for your particular model of WRX as well. http://autospeed.com/cms/title_Impreza-WRX...75/article.html http://autospeed.com/cms/title_Impreza-WRX...76/article.html http://autospeed.com/cms/title_Impreza-WRX...77/article.html http://autospeed.com/cms/title_Impreza-WRX...78/article.html http://autospeed.com/cms/title_Impreza-WRX...79/article.html Edited December 20, 2011 by Elfenstar ↡ Advertisement Link to post Share on other sites More sharing options...
Mllcg 3rd Gear December 21, 2011 Share December 21, 2011 WRX's naturally understeer, however i get the impression they are a little more susceptible to lift-off/snap oversteer which would put you in a little bit of a conundrum. If its what I described, try increasing the pressure all around by around 2psi (approx 240kpa altogether). The fronts to reduce the amount of dive on braking, and the rears to increase lateral grip. I wouldn't want you to oversteer less when you transfer weight to the front at the expense of more understeer under normal circumstances. If its just oversteering normally, then increase the pressure at the rears by 1psi and try, and if it feels better, then increase again and again by 1psi to the point you feel its handling becomes more neutral. As there is a limit to what tyre pressures can do, I would also suggest you read the following articles. I suspect this might be for your particular model of WRX as well. http://autospeed.com/cms/title_Impreza-WRX...75/article.html http://autospeed.com/cms/title_Impreza-WRX...76/article.html http://autospeed.com/cms/title_Impreza-WRX...77/article.html http://autospeed.com/cms/title_Impreza-WRX...78/article.html http://autospeed.com/cms/title_Impreza-WRX...79/article.html i rather get understeer than oversteer. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear December 21, 2011 Share December 21, 2011 i rather get understeer than oversteer. Well all the info including tyre pressure stuff is there for you in the linked articles. Go read up lah Link to post Share on other sites More sharing options...
Carbine- Clutched December 23, 2011 Share December 23, 2011 so if want to sustain high speed, use more air? if on stock tires sizing, pump according to manufacturers suggested wont be wrong imo... Link to post Share on other sites More sharing options...
Eyke Supercharged December 23, 2011 Share December 23, 2011 i dont dare pump too high. scared burst u need to exceed the tyre's stated max pressure by quite a bit b4 it'll burst. proven by Mythbusters. so can safety pump to max w/o bursting Link to post Share on other sites More sharing options...
Hlkh Clutched December 27, 2011 Share December 27, 2011 No prob bro ... i should thanks you instead as you have teach me more which i didnt know about cheer!! Link to post Share on other sites More sharing options...
Caravan 5th Gear December 31, 2011 Author Share December 31, 2011 What one car manual writes: (from http://www.cadillacforums.com/forums/2004-...ed-driving.html) Link to post Share on other sites More sharing options...
EasyGoing 2nd Gear January 10, 2012 Share January 10, 2012 i'm running on 270kpa up to Genting and back... Even now as well.. Wah so high ah. I'm driving a Suzuki APV (it's a 8 seater MPV) and the side plate indicate laden load press for front/rear to be 240/300 kpa but I was advised not go beyond 260kpa by Champion Motors leh. Any cpmments ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Continental CSC 7.
Continental CSC 7.
Tyre puncture
Tyre puncture
Tyre Rotation and balancing
