Mllcg 3rd Gear March 4, 2012 Share March 4, 2012 too rich will piang too lean also will piang ↡ Advertisement Link to post Share on other sites More sharing options...
Weichien Clutched March 5, 2012 Share March 5, 2012 Rich will piang more or lean? Which 1 more % Link to post Share on other sites More sharing options...
KARTer 2nd Gear March 5, 2012 Share March 5, 2012 Hi folks, do exhaust backfire means I'm running too rich or lean? Experience backfire pop pop pop sound when I wot, experience a few time alr if under hard driving, workshop say its normal but I somehow find it strange. Could it be the exhaust too restrictive or too little fuel. Thanks in advance for the replies WOT pop pop sounds, maybe seldom WOT? if i WOT every often (like on track, every 400m etc), no pop pop, but if WOT only once or twice a month, sure pop pop..... normal? Link to post Share on other sites More sharing options...
Nooby Clutched March 5, 2012 Share March 5, 2012 Do we need to top up engine oil every month? Link to post Share on other sites More sharing options...
Weichien Clutched March 5, 2012 Share March 5, 2012 For mine no engine oil top up, but I dunno cos change 5k and so far new oil for 2k only no dip in oil leh. Got me worry and can't sleep Link to post Share on other sites More sharing options...
Roystance Neutral Newbie March 5, 2012 Share March 5, 2012 u driving a turbo car?? Link to post Share on other sites More sharing options...
Weichien Clutched March 5, 2012 Share March 5, 2012 Yah, is it normal? Actually the Poping sound only come when I push it extremely hard. Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 5, 2012 Share March 5, 2012 (edited) Hi folks, do exhaust backfire means I'm running too rich or lean? Experience backfire pop pop pop sound when I wot, experience a few time alr if under hard driving, workshop say its normal but I somehow find it strange. Could it be the exhaust too restrictive or too little fuel. Thanks in advance for the replies You are unlikely to be running a carburettor fed engine (which would have implied that your AFM is lean). Rather, the inference is that your AFM (Air Fuel Mixture) is too rich as you are probably running an internal combustion engine based on the Otto Heat Engine Cycle. My interpretation of what is happening is this. For some reason, your AFM has been tuned to run too rich. This doesn't pose a problem except at high engine revs. The duration in which the AFM is permitted to combust and thereby drive the piston becomes restrictive due to the excessive amount(s) of fuel. Hence, the exhaust phae of the Otto cycle kicks in causing substantial amounts of hydrocarbons to exit the exhaust manifold. The exhaust backfire occurs because one of the primary purposes intended for the Catalytic Converter is to burn off any unburnt hydrocarbons and the problem is that there is simply too much of them hence the backfire along with the accompanying popping noises. Edited March 5, 2012 by Happily1986 Link to post Share on other sites More sharing options...
Weichien Clutched March 5, 2012 Share March 5, 2012 You are unlikely to be running a carburettor fed engine (which would have implied that your AFM is lean). Rather, the inference is that your AFM (Air Fuel Mixture) is too rich as you are probably running an internal combustion engine based on the Otto Heat Engine Cycle. My interpretation of what is happening is this. For some reason, your AFM has been tuned to run too rich. This doesn't pose a problem except at high engine revs. The duration in which the AFM is permitted to combust and thereby drive the piston becomes restrictive due to the excessive amount(s) of fuel. Hence, the exhaust phae of the Otto cycle kicks in causing substantial amounts of hydrocarbons to exit the exhaust manifold. The exhaust backfire occurs because one of the primary purposes intended for the Catalytic Converter is to burn off any unburnt hydrocarbons and the problem is that there is simply too much of them hence the backfire along with the accompanying popping noises. Bro I thi I u are right although I'm not too sure about it, cos when there's backfire normally during full trottle when I hear the pop pop sound, my car seems stuck like can't accelerate at all speed not including, and I have to let go and if I go full throttle again the same thin happen, but if I depress halfway and full throttle again it goes. I have the cat no more too. Link to post Share on other sites More sharing options...
G4ED Neutral Newbie March 5, 2012 Share March 5, 2012 Yah, is it normal? Actually the Poping sound only come when I push it extremely hard. Like this? Anyway, that's part of it's feature. Anti-lag they call it. ↡ Advertisement Link to post Share on other sites More sharing options...
Advice on exhaust.
Advice on exhaust.
Intermittent rattling noise, car in ICU
Yusheng from Singapore, Malaysia or China
Strange Mural at Holland Drive Food Center
How to trace owner from vehicle registration number?
Black flakes from washing machine
No basis for employers to cut pay if flexi-work does not affect productivity: Gan Siow Huang
